POV-Ray : Newsgroups : povray.binaries.images : discharge Server Time
4 Mar 2026 09:18:16 EST (-0500)
  discharge (Message 1 to 4 of 4)
Subject: discharge
Date: 1 Dec 2017 00:45:00
Message: <web.5a20ebbd110bb0b77e12b7e70@news.povray.org>
Give you
#version 3.7;
global_settings{
max_trace_level 3
assumed_gamma 1.0
adc_bailout 0.007
mm_per_unit 1000 //important for subsurface
radiosity{
 pretrace_start 64/image_width
 pretrace_end   4/image_width
 count 60
 nearest_count 6
 error_bound 0.64
 recursion_limit 8
 low_error_factor 0.5
 gray_threshold 0.0
 brightness 1
 media off
default{
texture{
    pigment {rgb<0.2,0.2,0.2>}
    finish{ambient 0 diffuse 0}
//---------------------background------------------------
background{rgb <0,0,0>}
//-------------------settings--------------------------------
//--------------------light source-----------------------------
light_source {
<-4, -2.5, 4>*100
color rgb <1.0, 0.88, 0.76>*1.75
parallel
point_at <0.0, 0.0, 0.0>
rotate <0,0,106>
sky_sphere{
    pigment {rgb <0.35,0.55,1>*0.6}
camera{
location <10,5,6>
look_at <0, 0, 0>
right <-4/3,0,0>
sky <0,0,1>
angle 32
//ground
#declare t_soil1=
texture{
    pigment{rgb<0.2,0.164,0.1>*0.8}
    finish{ambient 0 diffuse 1}
plane{
<0,0,1>,0
texture{t_soil1}
//media
#declare coverage = 0.30; // can adjust it
#declare coverage2 = 0.32; // can adjust it
#include "functions.inc"
#declare f_test =
function(x,y,z) {
coverage2*sum(i, 0, 4, pow(abs(f_noise3d(x*pow(2, i)/0.2, y*pow(2, i)/0.2,
z*pow(2, i)/0.2)), 2.5)/pow(2.0, i) )
#declare f_cloud_base =
function(x,y,z) {
0.5 - f_test(x,y,z)*3*3*z*exp(-3*z) - coverage*3*3*z*exp(-3*z)
#declare dens_cloud =
density{
    function{0.5 - 0.2*f_cloud_base(x,y,z)}
    color_map{
        [0   rgb 0]
        [0.5 rgb 0]
        [0.51 rgb 1]
        [1   rgb 1]
box{
<-20.0, -1.0, 0.0>, <20.0, 1.0, 1.0>
hollow
    material{
        texture{
            pigment{rgbt<0,0,0,1>}
        interior {
            media{
                samples 12
                scattering{
                1, rgb< 0.5, 0.75, 1.5 >*10.0
                extinction 1.0
                density {
                dens_cloud
scale <1.6, 1.6, 1.0>
translate <0,0,0>
//water
box{
<-20.01, -1.0, 0.1>, <20.01, 1.0, 0.45>
material{
    texture{
        pigment{rgbf<1,1,1, 0.99>}
        finish{
        ambient 0 diffuse 1 fresnel reflection{0.01, 1 fresnel }conserve_energy
    interior{
    ior 1.33
//ditch
difference{
box{
<-20.0, -1.05, 0.0>, <20.0, 1.05, 1.0>
box{
<-20.01, -1.0, 0.1>, <20.01, 1.0, 1.01>
texture{
    pigment{rgb<0.4,0.4,0.4>}
translate <0,0,0>
Download 'discharge.png' (92 KB)
Preview of image 'discharge.png'
Subject: Re: discharge
Date: 1 Dec 2017 06:20:00
Message: <web.5a213a96a4c96bf15cafe28e0@news.povray.org>
"And" <49341109@ntnu.edu.tw> wrote:
> Give you
These are the very first clouds on the bare scrith framework of Larry Niven's
Ringworld!  :D
Date: 1 Dec 2017 07:25:00
Message: <web.5a21495aa4c96bf17e12b7e70@news.povray.org>
> > Give you
> Ringworld!  :D
novel?
Date: 1 Dec 2017 10:15:00
Message: <web.5a21714da4c96bf1c437ac910@news.povray.org>
> > > Give you
> > Ringworld!  :D
> novel?
Yes :)  Actually, a series of novels.
https://en.wikipedia.org/wiki/Ringworld
and very closely linked with POV-Ray (there was a special version of POV-Ray
where the source code was altered to allow calculation of the (truly)
astronomical numbers needed to render the structure.)
http://news.povray.org/povray.binaries.images/thread/%3C43635ed8%241%40news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3C4c24a930%241%40news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5257d43d472428ca41a177270%40news.povray.org%3E/?mtop=387468
and lots more...
https://www.google.com/search?q=povray+ringworld&rlz=1C1CHFX_enUS633US634&oq=povray+ringworld
