POV-Ray : Newsgroups : povray.binaries.images : find the Santa Claus Server Time
22 Oct 2025 07:46:05 EDT (-0400)
  find the Santa Claus (Message 1 to 8 of 8)
Subject: find the Santa Claus
Date: 23 Dec 2016 18:45:01
Message: <web.585db643351d89f49c5d6c810@news.povray.org>
Made a Merry Christmas picture and by pure coincidence ol' St. Nick seems to
have been reflected in some of the red ornaments. Not done on purpose. Just
snow-reflected light.
For the curious, adding scene here:
/* treeless ornaments around "warm" glow */
//cmd:+am2 +a0.2 +j1
#version 3.7;
global_settings{assumed_gamma 1.0
 radiosity{count 123 normal on media on}
light_source{<100,100,-100>,<0.2,0.4,0.6>*0.7
 area_light <5,0,0>,<0,0,5>,4,4
 area_illumination
 media_interaction off
 media_attenuation off}
light_source{<0,7.5,0>,<0.9,0.5,0.3>*0.9
 area_light <0.5,0,0>,<0,0,0.5>,6,6 circular orient
 area_illumination
 fade_distance 9 fade_power 2
 media_interaction on
camera{location <0,2.4,-24>
 up y right image_width/image_height*x
 look_at <0,5,0>}
// starry sky
#declare StarY = function {
 pigment { brick rgb <1,1,0> rgb 0 mortar 0.001 }
sphere{0,360 // stars
 hollow on
    function { StarY(x,y,z).red}
    turbulence 3 scale 33
    finish { diffuse 0 ambient 1 emission 1 }
texture{pigment{rgbf<1,1,0,1>}}
 radiosity {importance 0.1}
sphere{0,1 // sky color
 hollow on
 pigment{
  function {abs(y)}
  color_map{
   [0 rgbt <0.6,0.1,0.2,0.3>]
   [0.1 rgbt <0.3,0.1,0.5,0.7>]
   [0.3 rgbt <0.2,0.4,0.9,0.8>]
   [1 rgbt <0.1,0.3,0.9,1>]
 finish{diffuse 0 ambient 1 emission 1}
 scale 333
 radiosity {importance 0.5}
// localized air haze
media{method 3 samples 200 scattering{1,0.03}
density{spherical density_map{[0.93 rgb 0][1 rgb 0.67]}}
scale 334}
// ornaments
#for(It,0,36,1)
sphere{<3-It/12,1+It/3,0>, 1-It/40
 rotate y*(360*It/6)
 material{
  texture{
 pigment{rgb <0,1,0>}
 finish{fresnel 1.33
  ambient 0
  brilliance 3
  diffuse albedo 0.5
  specular albedo 0.9 roughness 0.01
  reflection{0,1 fresnel on falloff 0.9 exponent 2}
  interior{ior 1.5}
 radiosity {importance 1}
 rotate y*(145+360*It/6)
 material{
  texture{
 pigment{rgb <1,0,0>}
 finish{fresnel 1.2
  ambient 0
  brilliance 4
  diffuse albedo 0.5
  reflection{0,1 fresnel on falloff 0.9 exponent 3}
  interior{ior 1.5}
#end // ornaments
// ground snow
height_field {
  function 2000,2000 {
    pattern {
      bozo scale 0.1
  translate -0.5
  scale <67,3,67>
  texture{
  pigment{rgb 1}
  normal{bumps 0.1 scale 0.3}
  finish{ambient 0.15 diffuse albedo 0.9
   specular albedo 3 roughness 0.01
   crand 0.1
  texture{
  pigment{bumps color_map{[0 rgb 1][0.2 rgbt 1]} scale 0.02}
  //normal{bumps 0.1 scale 0.3}
  finish{ambient 0.15 emission 0.05 diffuse albedo 9
   specular albedo 9 roughness 0.01
   //crand 0.1
  interior{ior 1.34}
  translate y*0.25
 radiosity {importance 0.75}
Download 'ws no tree snow warm glow.png' (619 KB)
Preview of image 'ws no tree snow warm glow.png'
Subject: Re: find the Santa Claus
Date: 24 Dec 2016 02:45:01
Message: <web.585e26f8a436ddeb9c5d6c810@news.povray.org>
I posted that scene file in haste and neglected to warn about it using
unofficial 3.7 feature fresnel finish. And to say it's a slow render. Maybe this
would be better:
#version 3.7; // 3.7 or use 3.71 with alpha or UberPOV
#local Radiosity=on;
#local Media=on;
#local Subsurface=off;
 max_trace_level 8
 #if(Radiosity=on)
 radiosity{count 123
  adc_bailout 2/1
  normal on media on
 } #end
 #if(Subsurface=on)
 subsurface{samples 60,40 radiosity on}
 //mm_per_unit 50
// moonlight
 area_illumination
// warm glow light
 area_light <0.33,0,0>,<0,0,0.33>,8,8 circular orient
 area_illumination
 media_attenuation on}
 look_at <0,5,0>}
// starry sky
sphere{0,333.33 // stars
 hollow on
    turbulence 3 scale 33 // bricks into stars
 hollow on
 pigment{
  function {abs(y)}
  color_map{
   [0.1 rgbt <0.3,0.2,0.5,0.5>]
 scale 333
 radiosity {importance 0.8}
#if(Media=on)
media{method 3 samples 50,50
 jitter 0.1
 scattering{1,0.03}
scale 334}
// ornaments
#for(It,0,36,1)
 rotate y*(360*It/6)
 material{
  texture{
 finish{
  #if(version>3.7)fresnel 1.33 #end
  ambient 0 emission 0.05
  brilliance 3
  diffuse albedo 0.5
  interior{ior 1.5}
 material{
  texture{
 finish{
  #if(version>3.7)fresnel 1.2 #end
  brilliance 4
  diffuse albedo 0.5
  interior{ior 1.5}
#end // ornaments
// ground snow
height_field {
  function 500,500 {
    pattern {
      bozo scale 0.1
  translate -0.5
  scale <67,3,67>
  texture{
  pigment{rgb 1}
  finish{ambient 0.15
   brilliance 0.8
   diffuse albedo 0.9
   crand 0.1
   subsurface{translucency <0.8,0.9,1>}
  texture{
   brilliance 0.4
   diffuse albedo 9
   //crand 0.1
  interior{ior 1.34}
  translate y*0.25
Date: 24 Dec 2016 18:00:00
Message: <web.585efddfa436ddeb6ae7df010@news.povray.org>
Hey, that's pretty cool! Merry Christmas!
Dave Swaim
Date: 25 Dec 2016 02:40:01
Message: <web.585f7704a436ddeb9c5d6c810@news.povray.org>
> Regards,
> Dave Swaim
Thanks Dave! I can't seem to post the scene file without leaving an error or
problem but I will try a third time anyway:
#version 3.71; // 3.7 or use 3.71 with alpha or UberPOV
#local Media=on;
#local Subsurface=on;
 max_trace_level 8
 #if(Radiosity=on)
 radiosity{count 123
  adc_bailout 1/32 // fix for blank/black areas,
                // seen with 1/128, for example.
                // This was 2/1 before and meant to be 1/2, oops!
                // Something about HF or isosurface when used
                // with radiosity?
  normal on media on
 } #end
 #if(Subsurface=on)
 //mm_per_unit 50
// moonlight
 area_illumination
// warm glow light
 area_illumination
 look_at <0,5,0>}
// starry sky
 hollow on
 hollow on
 pigment{
  function {abs(y)}
  color_map{
 scale 333
#if(Media=on)
media{method 3 samples 50,50 // increase to reduce banding
 // jitter 0.1  // too messy?
 scattering{1,0.03}
scale 334}
// ornaments
#for(It,0,36,1)
 rotate y*(360*It/6)
 material{
  texture{
 finish{
  brilliance 3
  diffuse albedo 0.5
  interior{ior 1.5}
 material{
  texture{
 finish{
  brilliance 4
  diffuse albedo 0.5
  interior{ior 1.5}
#end // ornaments
// ground snow
intersection { // add thickness for subsurface scattering
 box{<-0.01,0.01,-0.01>,<0.99,1.01,0.99>}
height_field {
  function 333,333 {
    pattern {
      bozo scale 0.1
  smooth
} // HF
  translate -0.5
  scale <67,3,67>
  texture{
  pigment{rgb 1}
  finish{ambient 0.15
   brilliance 0.8
   diffuse albedo 0.9
   crand 0.1
  texture{
   brilliance 0.4
   diffuse albedo 9
   //crand 0.1
  interior{ior 1.34}
  translate y*0.25
} // intersection
Date: 25 Dec 2016 04:26:43
Message: <585f90d3@news.povray.org>
I don't think that is Santa but the Grinch. :-)
It is good, though.
Happy Christmas to one and all.
Regards
Download 'grinch.png' (323 KB)
Preview of image 'grinch.png'
Date: 25 Dec 2016 17:39:32
Message: <58604aa4@news.povray.org>
You can also see Frosty.
Date: 25 Dec 2016 20:45:01
Message: <web.586075f1a436ddeb9c5d6c810@news.povray.org>
> It is good, though.
Thanks Stephen. I should have thought of Grinch too, yeah.
Wow, that lit up air sure is trouble to render. As is the snow if subsurface
scattering is used.
And always my main complaint, it's slooooow to render! ;)  Although radiosity
alone is fast for this.
Yep, maybe frosty was getting in there too. All like anti-vampires, can't see
them just their reflections.
Date: 30 Dec 2016 11:15:01
Message: <web.58668778a436ddebd00459b0@news.povray.org>
A nice scene, Merry Xmas!
Paolo
