clipka <ano### [at] anonymous org> wrote:
> Am 21.11.2016 um 00:39 schrieb omniverse:
> I need the scene (ideally trimmed down to the bare minimum showing the
> problem).
Found out what makes the change happen. Camera blur messes with both the area
light and subsurface.
Couldn't easily post all that's in the scene and include files so luckily this
was simple enough.
/* test of UberPOV area_light and adaptive.
DOF=on causes jittered area light shadows.
POV-Ray 3.7.1.1 alpha has smooth shadows. */
#version 3.7;
// features to use
#local Rad=on; // slow
#local SSS=on; // very slow
#local ArL=on; // slow
#local DOF=off; // very slow
global_settings
assumed_gamma 1 // chess scene not preadjusted for srgb here
#if (Rad=on)
radiosity{
recursion_limit 1
brightness 1
gray_threshold 0.67
normal on
brilliance on
#if (SSS=on)
subsurface on
#if (SSS=on)
subsurface {samples 40,20}
mm_per_unit 10
sky_sphere
pigment
function {abs(y)}
color_map
[0 srgb <1,0.8,0.5>]
[0.1 srgb <0.6,0.9,1>]
[0.2 srgb <0.5,0.8,1>]
[0.5 srgb <0.2,0.6,0.9>]
[1 srgb <0.1,0.5,0.9>]
plane { y, -2 pigment { srgb 1 } normal { crackle 0.7 } }
light_source
-z*111, rgb <0.8,0.7,0.6>
#if (ArL=on) // check using adaptive 3 or 4
area_light <8,0,0>,<0,8,0>,6,6 adaptive 0 circular orient
rotate <45,200,0>
light_source
-z*111, rgb <0.2,0.3,0.4>
#if (ArL=on)
area_light <8,0,0>,<0,8,0>,4,4 adaptive 0 circular orient
rotate <60,-30,0>
camera
up y
right image_width/image_height*x
location -z*25
look_at <0,-2,-4>
angle 50
#if (DOF=on)
focal_point <0,4,4>
aperture 1.33
blur_samples 15,20
/* // no noticeable difference using this
bokeh {
hexagon rgb <0.5,0,0.25>, rgb <0.75,1,0>, rgb <0.25,0.75,0>
rotate <25,40,0>
sphere
0, 5
pigment
rgb <1,1,1>
finish
specular 0.5 roughness 0.05
subsurface
translucency <1,1,1>
reflection
0, 0.5
fresnel on
exponent 0.8
conserve_energy
