I sampled an image_map pigment of a photo of my son with eval_pigment, and
plotted the resulting vectors in RGB-space (step 10 in x and y).
The scanning takes 33 sec (2448 x 3264).
I want to find a way to "cluster" similar values - I'm experimenting with
rounding the RGB channels, etc.
I also made a sort of "parametric" RGB map - translate along x by gray, rotate y
by green, then x by red, then z by blue
Download '3dimageanalysis.png' (300 KB)
Preview of image '3dimageanalysis.png'
On 07/17/2016 02:41 AM, Bald Eagle a dit:
I've done something like that, but with some C and shell coding.
Original video is here :
http://la.buvette.org/photos/myrys/20ans/avance-rapide.avi
(gory) C code is here :
http://la.buvette.org/vrac/colorcube.c
And the result is here :
http://la.buvette.org/photos/myrys/20ans/fx/colorcube.avi
I'va also done (a long time ago) some search in this field
Mmmm, sound nice :)
http://weblog.mixart-myrys.org/?post/2016/03/De-la-temporalisation
That's quite a fascinating video!
I do believe I'll be watching that many more times as I investigate all of the
ways to manipulate and analyze color and it's usage in my scenes.
It's quite interesting to see how your graph is so similar to mine - that long,
unvarying stretch across the "gray diagonal" and then you get a rising of a
"spine" in the Green, and some clusters in the Red and Purple, and a big blob in
the Yellow and Orange at certain points.
I may see if plotting colors in HSV or other "color spaces" gives more
interesting results. Given some more work, I think some of the graphs of color
are nice looking things in their own right.
Very nice work - I really like the overlay of the color graph on the video.
Thanks for sharing! :)
Subject: Re: Sampled photo in RGB space
Date: 24 Jul 2016 00:07:12
Message: <57943ef0@news.povray.org>
Hi(gh)!
Stunning! As I also started experimenting with time-lapse videos, I
would like to ask you:
- how long was the timespan the camera filmed (obviously all through the
night and a good part of the bright daytime before and after)?
- which picture rate did you use?
- and how was the camera powered? Plugged to a car battery?
This is the longest time-lapse video I created so far, a three-hour
bicycle ride around Cologne, Germany, but with several stops for battery
change: https://www.youtube.com/watch?v=0A9ASULLEN8
See you in Khyberspace!
Yadgar
> Hi(gh)!
http://la.buvette.org/photos/myrys/20ans/fx/raytraced.avi
From saturday 3PM to sunday 5PM, approximatively
Around twenty secons between frames, iirc.
No, pictures are grabed on a Linux box, with a
playstation's USB camera.
> Yadgar
