POV-Ray : Newsgroups : povray.binaries.images : CSG: difference: artefacts Server Time
31 Jan 2025 15:04:35 EST (-0500)
  CSG: difference: artefacts (Message 1 to 3 of 3)
Subject: CSG: difference: artefacts
Date: 17 Mar 2016 14:35:00
Message: <web.56eaf81c50adcc127a3e03fe0@news.povray.org>
ParticleSystem_Sphere_shape.inc:
//numbers spheres = 1000
#declare data_ParticleSystem_Sphere_shape_ob = union{
object {data_Sphere_shape_001_ob scale 0.1 translate
<1.602048,2.176796,0.704082>}
<-2.709654,0.306427,-0.592914>}
<-2.061681,1.452029,1.206769>}
<1.646683,1.532989,-1.656775>}
texture{Default_texture}
Povscene .pov:
#version 3.7;
global_settings {
    assumed_gamma 1.000000
    max_trace_level 20
    charset utf8
sky_sphere {
    pigment {rgb<0.050, 0.050, 0.050>}
#declare Default_texture = texture{pigment {rgb 0.8}}
#declare data_Sphere_shape_ob = sphere { 0,1
#declare data_Sphere_shape_001_ob = sphere { 0,1
#include "ParticleSystem_Sphere_shape.inc"
difference{
object {data_Sphere_shape_ob
    texture {Default_texture}
    matrix <2.798619, 0.000000, 0.000000,  0.000000, -0.000000, -2.798619,
0.000000, 2.798619, -0.000000,  0.000000, 0.000000, 0.000000>
object {data_ParticleSystem_Sphere_shape_ob texture{Default_texture}
light_source {
    <5.07,5.58,4.28>
    color rgb<1, 1, 1>
    fade_distance 25.0000000000
    fade_power 1
    perspective
    location  <0,0,0>
    look_at  <0,0,-1>
    right <-1.7777777777777777, 0, 0>
    up <0, 1, 0>
    angle  49.134343
    rotate  <-27.098163, 46.688390, -0.903519>
    translate <7.481132, 5.343666, 6.507640>
Render result:
Download 'artefacts.jpg' (61 KB)
Preview of image 'artefacts.jpg'
Subject: Re: CSG: difference: artefacts
Date: 17 Mar 2016 16:30:00
Message: <web.56eb1044e45cefaffd6b6fe10@news.povray.org>
> Povscene .pov:
> #version 3.7;
> global_settings {
>     max_trace_level 20
>     charset utf8
> sky_sphere {
> difference{
> light_source {
>     <5.07,5.58,4.28>
>     color rgb<1, 1, 1>
>     fade_power 1
> camera {
>     perspective
>     location  <0,0,0>
>     look_at  <0,0,-1>
>     up <0, 1, 0>
>     angle  49.134343
> Render result:
looks like a coincident surface of two small spheres in the same place.
If it were me, I'd add each new sphere to a union and test successive ones
against being inside that union.
e.g.
#declare testObj =
union {
    sphere { 0.0, 1.0 }
difference {
    sphere { 0.0 1.0 }
#declare A = 0;
#declare missCount = 0;
#while(A < 1000)
// generate a new point P...
    #if(!inside(testObj, p))
        #declare testObj =
            union {
                testObj
                sphere { 0.0, 0.1 translate p }
        sphere { 0.0, 0.1 p }
        #declare A = A + 1;
    #else
        #declare missCount = missCount + 1;
    #if(missCount = 100)
        #break
Guaranteed to give you 1000 small cutouts.
If you want to limit the amount of overlap, you can increase the size of the
spheres you add to the union.
A.D.B.
Date: 18 Mar 2016 10:45:01
Message: <web.56ec1301e45cefaf7a3e03fe0@news.povray.org>
> Regards,
> A.D.B.
Thank you! :))))))
Yes.
It turned out that some coordinates of particles are identical.
I set check. The repeating objects don't register the exporter now.
Download 'empty.jpg' (70 KB)
Preview of image 'empty.jpg'
