POV-Ray : Newsgroups : povray.binaries.images : Circumscribed sphere Server Time
5 Mar 2026 02:17:40 EST (-0500)
  Circumscribed sphere (Message 1 to 10 of 12)
Subject: Circumscribed sphere
Date: 6 Aug 2014 12:30:01
Message: <web.53e25769ad990c965e7df57c0@news.povray.org>
FractRacer:
Here's a visualization of the goal & problem.
I'm sure I must simply be doing something slightly wrong when I compute a vector
to rotate around, or a normal value, or something.
It all looks fine on paper - so it should work!   :D
If the red torus is the rim of an ice cream cone, then the green sphere should
sit in it perfectly, in full contact, like a scoop of ice cream.
#include "geom_tasks.inc"    <---   analytical_g.inc
#include "drawing.inc"       <---   just an inc I'm working on to make text
always face the camera, draw various kinds of arrows, vectors, shapes, etc.
#version 3.7;
global_settings { assumed_gamma 1.8 }
#include "debug.inc"
 Set_Debug (true)
#declare View_POV_Include_Stack = true;
#include "math.inc"
#include "shapes.inc"
#include "textures.inc"
#include "transforms.inc"
#declare verbose = true;
light_source { <2, 20,  5>  color rgb <1,1,1>}
#declare Camera_Origin = camera {
                            location  <0, 0, 0>
                            //right    x*image_width/image_height
                            look_at   <0, 0, 0.01>}
#declare Camera_Angle = camera {
                            location  <5 , 10, -15.0>
                            //look_at   <0, 0, 0>
                            look_at   <5, 5, 5>}
#declare Camera_Rear = camera {
                            location  <0.0, -100.0, -300.0>
                            look_at   <0, 0, 0>}
#declare Camera_Iso = camera {
                            location  <-50, 0, 0>
                            look_at   <0, 0, 0>}
#declare Camera_Top = camera {
                            location  <0, 8.5, 2>
                            look_at   <0, 0, 2>}
#declare Camera_Front = camera {
                            location <25, 4, -2>
                            look_at  <0, 0, 0>}
//camera {Camera_Front }
#declare Camera_Location = <-4, 6, 10>;
#declare Camera_Look_At  = <0, 0,   0>;
#declare LightVector = Camera_Location - Camera_Look_At;
light_source { LightVector*1.2  color rgb <1,1,1>} // Always above and behind
camera to illuminate screen objects
#include "screen.inc"
#declare SolidAmbient = 0.6;
#declare FadedAmbient = 0.4;
#declare FadedTrans = 0.7;
#declare SolidRed = texture { pigment {Red} finish {ambient SolidAmbient} };
#declare ShadedRed = texture { pigment {Red transmit FadedTrans} finish {ambient
FadedAmbient} };
#declare SolidYellow = texture { pigment {Yellow} finish {ambient SolidAmbient}
#declare ShadedYellow = texture { pigment {Yellow transmit FadedTrans} finish
{ambient FadedAmbient}  };
#declare SolidGreen = texture { pigment {Green} finish {ambient SolidAmbient} };
#declare ShadedGreen = texture { pigment {Green transmit FadedTrans} finish
#declare SolidBlue = texture { pigment {Blue} finish {ambient SolidAmbient} };
#declare ShadedBlue = texture { pigment {Blue transmit FadedTrans} finish
#declare SolidMagenta  = texture {pigment {Magenta} finish { ambient
SolidAmbient phong 1}}
#declare ShadedMagenta = texture { pigment {Blue transmit FadedTrans} finish
#declare SolidWhite = texture { pigment {White} finish {ambient SolidAmbient} };
#declare ShadedWhite = texture { pigment {White transmit FadedTrans} finish
#declare SolidGray = texture { pigment {Gray50} finish {ambient SolidAmbient} };
#declare ShadedGray = texture { pigment {Gray50 transmit FadedTrans} finish
#declare Line = texture { pigment {Blue} finish {ambient 0.4} };
#declare Line_W = 0.1;
#declare Point = texture { pigment {Blue} finish {ambient 1} };
#declare Point_W = 0.2;
#declare Object = texture { pigment {Yellow} finish {ambient 0.4} };
#declare Plane = texture { pigment {Green}  };
#declare Magenta  = texture {pigment {Magenta} finish { ambient 0.4 phong 1}}
//  Screen Overlay
#declare ScreenX = 0;
#declare ScreenY = 1;
#declare Line = 0;
#declare TextSize = 0.035;
#declare TextColor1 = texture {SolidYellow};
#declare TextColor2 = texture {SolidRed};
#declare TextCR = TextSize*1.1;
#declare Top1 = "The goal is to circumscribe the triangle and Point D (a
tetrahedron)"
#declare Top2 = "with a sphere.  The red torus is the correct circumscribed
CIRCLE,"
#declare Top3 = "but the sphere does not contact that circle all the way around,
as it should"
#declare Top4 = "The perpendicular bisector extended from Midpoint to the
centroid normal"
#declare Top5 = "ought to define the center and radius of the desired sphere.
It doesn't."
#declare Screen_Text = text { ttf "arial.ttf", Top1, 0.01, <0, 0> scale TextSize
texture {TextColor1} }
 Screen_Object ( Screen_Text, <ScreenX, ScreenY-Line>, <0.04, 0.02>, true, 0.1 )
 #declare Line = Line + TextCR;
#declare Screen_Text = text { ttf "arial.ttf", Top2, 0.01, <0, 0> scale TextSize
#declare Screen_Text = text { ttf "arial.ttf", Top3, 0.01, <0, 0> scale TextSize
#declare Screen_Text = text { ttf "arial.ttf", Top4, 0.01, <0, 0> scale TextSize
#declare Screen_Text = text { ttf "arial.ttf", Top5, 0.01, <0, 0> scale TextSize
#declare ScreenX = 0.18;
#declare ScreenY = 0.58;
#declare Bottom1 = "#declare Tangent = Triangle_Normal ( Corner_3, Middle,
PointD );"
#declare Bottom2 = "#declare Perp = vcross (PointD-Corner_3, Tangent);"
#declare Bottom3 = "#declare PerpN = vnormalize (Perp);"
#declare Bottom4 = "#declare PerpV = vtransform (Perp*2, transform {translate
Midpoint} );"
#declare Bottom5 = "#declare Adjacent = vlength (Midpoint - PointD);"
#declare Bottom6 = "#declare Theta = VAngleD (Midpoint - PointD, Middle -
PointD);"
#declare Bottom7 = "#declare Opposite = Adjacent * atan (Theta);"
#declare Bottom8 = "#declare Center = vtransform (Midpoint, transform {translate
PerpN * Opposite} );"
#declare Bottom9 = "(I must be using the \"Lucas\" version of screen.inc   ...
:O"
#declare Screen_Text = text { ttf "arial.ttf", Bottom1, 0.01, <0, 0> scale
TextSize texture {TextColor2} }
#declare Screen_Text = text { ttf "arial.ttf", Bottom2, 0.01, <0, 0> scale
#declare Screen_Text = text { ttf "arial.ttf", Bottom3, 0.01, <0, 0> scale
#declare Screen_Text = text { ttf "arial.ttf", Bottom4, 0.01, <0, 0> scale
#declare Screen_Text = text { ttf "arial.ttf", Bottom5, 0.01, <0, 0> scale
#declare Screen_Text = text { ttf "arial.ttf", Bottom6, 0.01, <0, 0> scale
#declare Screen_Text = text { ttf "arial.ttf", Bottom7, 0.01, <0, 0> scale
#declare Screen_Text = text { ttf "arial.ttf", Bottom8, 0.01, <0, 0> scale
#declare Screen_Text = text { ttf "arial.ttf", Bottom9, 0.01, <0, 0> scale
TextSize texture {SolidBlue} }
sky_sphere { pigment { gradient y color_map {
            [0.0 rgb <1, 1, 1>]
            [0.8 rgb <1, 1, 1>] } } }
// Origin
sphere {o, 0.1 pigment {White} }
//  Gridlines and axes
#macro Raster(RScale, HLine)
 #local Lightness = 0.6;
 pigment{ gradient x scale RScale
                color_map{[0.000   color rgbt<0,0,1,0> * Lightness]
                          [0+HLine color rgbt<0,0,1,0> * Lightness]
                          [0+HLine color rgbt<1,1,1,1>]
                          [1-HLine color rgbt<1,1,1,1>]
                          [1-HLine color rgbt<0,0,1,0> * Lightness]
                          [1.000   color rgbt<0,0,1,0> * Lightness]} }
       finish {ambient 0.1 diffuse 0.9}
#end// of Raster(RScale, HLine)-macro
#macro Grid (RasterScale, RasterHalfLine, Background_pigment)
 plane{<0, 1, 0>, 0      // uses layerd textures!!!!
 texture{Background_pigment  finish { phong 0.1}}
 texture{Raster( RasterScale, RasterHalfLine) rotate<0, 0, 0> }
 texture{Raster( RasterScale, RasterHalfLine) rotate<0, 90, 0>}
       scale 1}
#macro Axis_( AxisLen, RedTexture, WhiteTexture) // ---------------------
 union{
  cylinder {<0,-AxisLen,0>,<0,AxisLen,0>,0.05 texture{checker
texture{RedTexture} texture{WhiteTexture} translate<0.1,0,0.1>}}
  cone{<0,AxisLen,0>,0.2,<0,AxisLen+0.7,0>,0 texture{RedTexture}}
       } // end of union "Axis"
#end // of macro Axis (AxisLen)
#macro AxisXYZ (AxisLenX, AxisLenY, AxisLenZ, TexRed, TexWhite)
 union{
  object{Axis_(AxisLenX, TexRed, TexWhite) no_shadow  rotate< 0,0,-90>}   //
x-Axis
  object{Axis_(AxisLenY, TexRed, TexWhite) no_shadow  rotate< 0,0,  0>}   //
y-Axis
  object{Axis_(AxisLenZ, TexRed, TexWhite) no_shadow  rotate<90,0,  0>}   //
z-Axis
  text{ttf"arial.ttf", "x", 0.15, 0 no_shadow texture{TexRed} scale 0.5
translate <AxisLenX + 0.05, 0.20, -0.12>}
  text{ttf"arial.ttf", "y", 0.15, 0 no_shadow texture{TexRed} scale 0.5
translate <-0.35, AxisLenY + 0.50, -0.05>}
  text{ttf"arial.ttf", "z", 0.15, 0 no_shadow texture{TexRed} scale 0.5
translate <-0.75, 0.2, AxisLenZ + 0.50>}
  } // end of union
#end// of macro "AxisXYZ(...)"
//  Draw Gridlines
object{ Grid ( 1, 0.01, texture {pigment{color rgb <0.5, 0.5, 1>} finish
{ambient 0.3 diffuse 0.9}} )  rotate<0,0,0>}
//  Draw x, y, & z Axes
#declare Tex_Dark  = texture {pigment {color rgb<0, 0, 0.45>} finish { ambient
0.4 phong 1}}
#declare Tex_White = texture {pigment {color rgb<1,1,1>} finish { ambient 0.4
phong 1}}
object{ AxisXYZ (5, 5, 5, Tex_Dark, Tex_White)}
//  Start Scene description here:
#declare Corner_A_1 = <0, 0, 0>;
#declare Corner_A_2 = <4, 0, 0>;
#declare Corner_A_3 = <4, 4, 0>;
#declare H = 1;
#local AT = text {
ttf "arial.ttf", "A", 0.02, 0.0 // thickness, offset
pigment{ color rgb<1,1,1>*0.5 }
#local BT = text {
ttf "arial.ttf", "B", 0.02, 0.0 // thickness, offset
#local CT = text {
ttf "arial.ttf", "C", 0.02, 0.0 // thickness, offset
#local DT = text {
ttf "arial.ttf", "d", 0.02, 0.0 // thickness, offset
pigment{ color rgb<1,0.5,0.5> }
scale 0.75
#local MT = text {
ttf "arial.ttf", "m", 0.02, 0.0 // thickness, offset
scale 0.75
#local Plane = texture {
pigment {color rgb 0.7}
#local Object = texture {
pigment {color rgb <0.7,0.3,0.1>}
#local Tex_Dark = texture {
pigment {color rgb <0.17,0.13,0.81>}
#local Shaded   = texture {
pigment {color rgb <0.2,0.2,0.2> filter 0.87}
#local Rayon = 0.125;
#macro Circumscribed_Sphere (Corner_1, Corner_2, Corner_3, Height)
 union{
  //cylinder {Corner_A_1-0.15*z, Corner_A_1+0.1*z, Rayon  texture {Object} }
  //object {AT translate Corner_A_1-x*1-y*0.5}
  sphere {Corner_A_1, Rayon texture {SolidBlue} }
  object {LabelPoint (Corner_A_1, "A", 0.5) texture {SolidRed} }
  //cylinder {Corner_A_2-0.15*z, Corner_A_2+0.1*z, Rayon  texture {Object} }
  //object {BT translate Corner_A_2+x*0.5-y*0.5}
  sphere {Corner_A_2, Rayon texture {SolidBlue} }
  object {LabelPoint (Corner_A_2, "B", 0.5) texture {SolidRed} }
  //cylinder {Corner_A_3-0.15*z, Corner_A_3+0.1*z, Rayon  texture {Object} }
  //object {CT translate Corner_A_3+x*0.5+y*0.5}
  sphere {Corner_A_3, Rayon texture {SolidBlue} }
  object {LabelPoint (Corner_A_3, "C", 0.5) texture {SolidRed} }
 // POINT P / Middle
 #declare Middle =  Triangle_M_out (Corner_A_1, Corner_A_2, Corner_A_3);
 #declare Radius =  Triangle_R_out (Corner_A_1, Corner_A_2, Corner_A_3);
 #declare Normal =  Triangle_Normal(Corner_A_1, Corner_A_2, Corner_A_3);
 #local TMC = Triangle_Mass_Center(Corner_A_1, Corner_A_2, Corner_A_3);
 //cylinder {Middle-0.15*z, Middle+0.25*z, Rayon  translate Normal texture
{Shaded}}
 //object {MT translate Middle-x*0.5}
 sphere {Middle, Rayon texture {SolidBlue} }
 object {LabelPoint (Middle, "m", 0.5) texture {SolidRed} }
 //cylinder {TMC-0.15*z , TMC +0.1*z, Rayon translate Normal texture {Tex_Dark}}
 sphere {TMC, Rayon texture {SolidBlue} }
 #declare PointD  =  vtransform (Middle, transform {translate Normal*Height});
 object {LabelPoint (PointD, "D", 0.5) texture {SolidRed} translate
Normal*Height}
 //  object {DT translate PointD}
 object {Distance_Marker(Corner_A_1, Corner_A_2, 0.025) texture {SolidMagenta}}
 object {Distance_Marker(Corner_A_2, Corner_A_3, 0.025) texture {SolidMagenta}}
 object {Distance_Marker(Corner_A_3, Corner_A_1, 0.025) texture {SolidMagenta}}
 object {Distance_Marker(Corner_A_1, PointD, 0.025) texture {SolidMagenta}}
 object {Distance_Marker(Corner_A_2, PointD, 0.025) texture {SolidMagenta}}
 object {Distance_Marker(Corner_A_3, PointD, 0.025) texture {SolidMagenta}}
 #declare Midpoint = (Corner_A_3 + PointD)/2;
 sphere {Midpoint, Rayon texture {SolidRed} }
 #declare Tangent = Triangle_Normal ( Corner_3, Middle, PointD );
  // Perpendicular to triangle containing sphere center
  #declare PerpRef = vtransform (Tangent*5, transform {translate Corner_3} ); //
Just a big tangent
  //object {Vector (Corner_3, PerpRef, 0.05) texture {Plane}}
  #declare PerpV = vtransform (Perp*2, transform {translate Midpoint} );
  object {Vector (Midpoint, PerpV, 0.05) texture {SolidGreen}}
 #declare Theta = VAngleD (Midpoint - PointD, Middle - PointD);
 #declare Center = vtransform (Midpoint, transform {translate PerpN * Opposite}
  object {Vector (PointD, Center, 0.05) texture {SolidGreen}}
 #declare SRayon = vlength (Center - PointD);
 torus { SRayon,0.05 rotate x*90 translate Middle texture {SolidRed} no_shadow}
 sphere {Center, SRayon texture {ShadedGreen}}
 }  // end union
#declare  Sphere = object {Circumscribed_Sphere (Corner_A_1, Corner_A_2,
Corner_A_3, H) no_shadow};
Sphere
Download 'fractracerfix.png' (235 KB)
Preview of image 'fractracerfix.png'
Subject: Re: Circumscribed sphere
Date: 6 Aug 2014 14:20:00
Message: <web.53e271833cb258895e7df57c0@news.povray.org>
Grrr.   I wrote "centroid" when I knew I meant "circumcenter".
I was also having some issues depicting the surface normals of the 3 triangles
formed with the original vertices and PointD.
Date: 7 Aug 2014 14:56:37
Message: <53e3cbe5@news.povray.org>
> FractRacer:
I will take some times to see your code.
If I understand, the point D is not in the same plane as the triangle,
the torus is - but I may be wrong - the equator of the sphere on which D
is.
Lionel
Do not judge my words, judge my actions.
http://www.avast.com
Date: 7 Aug 2014 17:00:01
Message: <web.53e3e8753cb258895e7df57c0@news.povray.org>
> is.
Correct - D is NOT in the same plane of the triangle.  It is a point H units
away from the triangular plane.
The center you are using, the "centroid"
is not the center used for finding the tangent circle.
The "circumcenter"
is the one to use - it also happens to lie on the midpoint between Corner_A_1
and Corner_A_3, because it is is a right triangle, and so it bisects the
hypotenuse.
I think maybe the rotation vectors I'm using are incorrect, or the trigonometry
is off, but I cannot see how.   Hopefully I can do more to understand what is
wrong tonight.
Date: 8 Aug 2014 09:35:01
Message: <web.53e4d15f3cb258895e7df57c0@news.povray.org>
I've gotten this far - the only thing unknown or in error at this point is the
radius of the sphere.
A nice discussion with good diagrams, in any event.
http://www.verniana.org/volumes/02/HTML/SphericalGeometry.html
Date: 8 Aug 2014 11:35:01
Message: <web.53e4ed2c3cb258895e7df57c0@news.povray.org>
http://www.answers.com/topic/tetrahedron
"If OABC forms a general tetrahedron with a vertex O as the origin and vectors
a, b and c represent the positions of the vertices A, B, and C with respect to
O, then ... the radius of the circumsphere is given by:
R = |pow(a,2) * |bxc| + pow(b,2) * |cxa| + pow(c,2) |axb| | / 12V
where:
6V = |a.(bxc)|
Circumcenter O = |pow(a,2) * |bxc| + pow(b,2) * |cxa| + pow(c,2) |axb| | / 2a *
(bxc)
If I knew more about Delaunay triangulation or Voronoi cells, this might help me
out:
http://wias-berlin.de/software/tetgen/1.5/doc/manual/manual002.html
"In ℝ3, the vertices of the Voronoi diagram are the circumcenters of the
tetrahedra of the Delaunay tetrahedralization."
Date: 8 Aug 2014 12:15:19
Message: <53e4f797$1@news.povray.org>
If I got your problem correctly:
1. you have 4 points: A,B,C,D, not coplanar, and not even aligned by
group of 3. (A,B,C,D define a non-degenerated tetrahedron)
2. you want to find the sphere whose surface includes all the points.
You need additional constraint on D, or the sphere does not exist.
Notice that A,B,C & D are exchangeable. The sphere hold the ABC circle,
but also the ABD, ACD and BCD circles.
The normal going through the centre of all circles meets at the center
of the sphere.
So, one possible solution to check if there is a solution is:
 1. compute the circle for ABC: Center K, normal N.
 2. compute the circle for ABD (or any of the two others): Center L,
normal M.
 3. compute the smallest distance W between (K,K+N) line and (L,L+M) line
 4. if W is not null, there is no intersection, hence no solution.
 5. if W is null, the intersection I is the center of the sphere, and
the radius is IA, IB, IC or ID.
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Date: 8 Aug 2014 12:50:00
Message: <web.53e4fec23cb258895e7df57c0@news.povray.org>
Just so I can learn some conversion of standard vector math notation, I turned
that all into (Corner_A_1 is already at the origin):
 #declare Vo = Corner_A_1;
 #declare Va = Corner_A_2;
 #declare Vb = Corner_A_3;
 #declare Vc = PointD;
 //  6V = |a.(bxc)|
 #declare V = vdot (Va, vcross (Vb, Vc) ) / 6;
 #debug concat ( "V = ", str (V, 3, 1), "\n")
 //  R = |pow(a,2) * |bxc| + pow(b,2) * |cxa| + pow(c,2) |axb| | / 12V
 #declare CircumRadius = vlength (
  pow(vlength (Va),2) * vcross (Vb, Vc) +
  pow(vlength (Vb),2) * vcross (Vc, Va) +
  pow(vlength (Vc),2) * vcross (Va, Vb)
  ) / (12 * V);
 #debug concat ( "CircumRadius = ", str (CircumRadius, 3, 1), "\n")
 //  O = |pow(a,2) * |bxc| + pow(b,2) * |cxa| + pow(c,2) |axb| | / 2a * (bxc)
 #declare PointO = vlength (
  ) / (2 * vlength (Va) * vcross (Vb, Vc) );
 #debug concat("PointO = <", vstr(3, PointO, ", ", 0, 1), "> \n")
V and CircumRadius look plausible, PointO is somewhere under the plane at z =
AlphaCentauri.   :(
Correct.
Right.  I define H, which is the height above the centroid of the triangle where
D exists.  (Within reason:) When H is small, D sits close to the triangle, and
the sphere is large.  When H gets larger, the radius of the sphere becomes
smaller.
Correct.
> of the sphere.
I thought that might be true, but hadn't gotten around to a way of implementing
it.
> normal M.
I see that 3 is the key.
I'm fuzzy on exactly how to do that.  I don't mind the exercise - I'm just not
that alert of a reader at the moment...   ;)
Can I define a plane that contains the original triangle's center and PointD and
then use trace along one of the lines to find the intersection?
I'm assuming that there's no "line" object to use for testing an intersection,
and rounding errors might cause a miss anyway....
I'll try the plane and then a tiny cylinder.
Thanks my friend.
Date: 8 Aug 2014 14:28:29
Message: <53e516cd$1@news.povray.org>
Am 08.08.2014 18:15, schrieb Le_Forgeron:
I don't think that's true: Constraint 1. is sufficient.
Every non-degenerate triangle has exactly one circumscribed circle, so
obviously there exists exactly one circle touching ABC. Let O be that
circle.
Let N be the rotational axis of O. If D is on N, Let P be an arbitrary
plane trough N; otherwise, let P be the plane through D and N. Note that
in either case both D and N are on P.
Note that P intersects O in two points; let these be E and F. Also note
that D is not on the line EF, otherwise ABCD would be coplanar. Thus,
DEF is a non-degenerate triangle, and itself has a circumscribed circle.
Let Q be that circle.
Note that E and F have equal distance to N, thus N runs through the
center of Q, so rotating Q about N defines a sphere. Let S be that
sphere. Note that D lies on Q and hence on S; also note that E and F
both lie on Q, and their rotation about N yields O, thus O lies on S.
Note that ABC all lie on O, and therefore also on S.
=> ABCD all lie on S.
Finally note that if P if ambiguous, the case is entirely rotationally
symmetric except for the positions of ABC, and thus S is the same for
all possible choices of P.
=> S is unambiguous.
=> For any non-degenerate tetrahedron ABCD, there exists exactly one
circumscribed sphere.
Date: 8 Aug 2014 15:10:00
Message: <web.53e51f643cb258895e7df57c0@news.povray.org>
True in general, But the way I define what D _IS_, is that it is the
circumcenter of ABC offest in the normal direction by some distance H.
That way the whole system is parameterized so that for any triangle ABC, I can
vary how much of sphere S "pokes through" circle O.
> circle.
I did manage to follow all of that after 3 or 4 tries, and you are of course,
correct.   Oh, if only my mind still worked as clearly as yours.
After a few false starts, I got it all to work out and am cleaning up all of the
accumulated dross in the code.
I must say I was rather surprised how little information is readily available
(internet-wise) on practically accomplish this otherwise-simple task.
