POV-Ray : Newsgroups : povray.binaries.images : Ringworld Server Time
15 Mar 2026 09:45:44 EDT (-0400)
  Ringworld (Message 12 to 21 of 61)
Subject: Re: Ringworld
Date: 12 Oct 2013 03:22:20
Message: <5258f8ac$1@news.povray.org>
On 12-10-2013 9:07, Thomas de Groot wrote:
> On 11-10-2013 19:05, Alain wrote:
>> You need to use artistic liberty by not using realistic proportions if
>> you want the ring and the sun to be both visible.
> I think that is the answer indeed. From earlier attempts here to model
> space objects to scale, that same conclusion was drawn iirc.
...I know. This seems to contradict my earlier question ;-) I just
forgot about how huge space really is, and about those earlier attempts.
Date: 12 Oct 2013 04:23:34
Message: <52590706$1@news.povray.org>
>> Looking good imo. Land/sea distribution is much better than the
>> randomness in my macro. What K do you use for the sun colour? Around
>> 6200 or lower fairly yellow, but indeed may not look as such in space,
>> or from the surface. The glare makes it white I suppose.
>> One question though: are the overall proportions of the system right?
>>   From the image I suspect that the Ringworld is much too wide compared
>> to its diameter. See attached table.
>> Thomas
> Thanks!
> I'm using 6500 for the K.
   Then it's logical for it to be white, as the default Lightsys
whitepoint is exactly 6500K, IIRC. Try changing the whitepoint to 7500K
or so, and you should get it more yelowish.
Jaime
Date: 12 Oct 2013 12:00:01
Message: <web.5259716df2e6f38c306548240@news.povray.org>
Perhaps I'm missing something, but wouldn't it be more logical to use the Sun's
actual temperature (~5800K) than to change the white point?
Date: 12 Oct 2013 14:40:00
Message: <web.5259965bf2e6f38c41a177270@news.povray.org>
"Cousin Ricky" <rickysttATyahooDOTcom> wrote:
> The Sun's surface temperature is about 5800K.  I read some time ago that it is
> slightly bluer than a black body of the same temperature, but I cannot now find
> information about that.
> The Sun does look whiter in space than from Earth, because from Earth, the
> atmosphere scatters out some of the shorter wavelengths.  That's why the sky is
> blue.  If you combine the blue of the sky with the yellowish-white of the Sun,
> you'll get roughly the actual color of the Sun (although not exactly, because
> the atmosphere does absorb some color).
> Note that even from Earth, the Sun is not as yellow as most people think it is.
> A sheet of white paper in direct sunlight indoors (where the blue from the sky
> is mostly blocked) still looks white, doesn't it?  That the Sun is thought to be
> yellower than it really is seems to be some psychological effect that to my
> knowledge there's no definitive explanation.
What value for lumens should I use? 1 lumens seems a little dark, so I set it to
2 instead.
Mike
Message: <web.5259972af2e6f38c41a177270@news.povray.org>
Here's another render. The sun shields are not in place yet. I also want to move
the camera a bit closer to the ring.
Mike
Download 'ringworld_new_scaled.png' (83 KB)
Preview of image 'ringworld_new_scaled.png'
Date: 12 Oct 2013 18:40:01
Message: <web.5259cf41f2e6f38cb9c369c00@news.povray.org>
> Thomas
One thing I'd like to know is how many shadow squares are there supposed to be?
If they're supposed to be 2500000 miles long and 13000000 miles from the center
of the sun, then there should be 41 of them assuming they're spaced equally
apart.
Is that right?
Date: 12 Oct 2013 18:45:01
Message: <web.5259d02cf2e6f38cb9c369c00@news.povray.org>
> apart.
> Is that right?
Damn my math!
That should be ~16 not 41.
Mike
Date: 12 Oct 2013 18:55:01
Message: <web.5259d24cf2e6f38c306548240@news.povray.org>
> 2 instead.
That I don't know, although it's been on my to-do list.
Date: 12 Oct 2013 20:40:00
Message: <web.5259eb4ff2e6f38cb9c369c00@news.povray.org>
> > 2 instead.
Also, does the light have a falloff rate? How do you configure falloff with
Lightsys IV?
Date: 13 Oct 2013 02:15:01
Message: <web.525a3998f2e6f38cb9c369c00@news.povray.org>
Here's a render from 1 mile above the surface. Lots of stuff are messed up.
There should be clouds and an atmosphere above my head. The ground texture cuts
out as it starts curving upward. Yuck!
I'll post the scene file in povray.text.scene-files.
Mike
Download 'ringworld_new_scaled_05.png' (43 KB)
Preview of image 'ringworld_new_scaled_05.png'
