POV-Ray : Newsgroups : povray.binaries.images : Averaged normals vs. averaged textures Server Time
6 Mar 2026 00:17:26 EST (-0500)
  Averaged normals vs. averaged textures (Message 1 to 4 of 4)
Subject: Averaged normals vs. averaged textures
Date: 9 Aug 2011 14:05:01
Message: <web.4e4175bb14a73acc85de7b680@news.povray.org>
I was trying to create a stand-alone normal for blurred reflections.  The sphere
on the left uses an averaged texture, as illustrated in the Knowledgebase.  The
sphere on the right uses an averaged normal applied to a base texture.
_____________________________________________________________
#version 3.7;
global_settings
{  assumed_gamma 1
   max_trace_level 10
camera
{  location <-8, 1.5, -8>
   look_at y
   angle 30
sky_sphere
{  pigment
   {  gradient y color_map
      {  [0 rgb <0.7, 0.8, 0.9>]
         [1 rgb <0.2, 0.3, 0.6>]
light_source
{  <-1, 2, 0> * 1000 rgb 1
   parallel point_at 0
plane { y, 0 pigment { checker rgb 0.05 rgb 1 } }
#declare t_Brass = texture
{  pigment { rgb <0.80, 0.57, 0.23> }
   finish
   {  reflection { 0.5 metallic }
      diffuse 0.4 ambient 0.05
      specular 1 metallic 0.95 roughness 0.015
      brilliance 6.75
#declare S = seed (0);
sphere
{  y, 1
   texture
   {  average texture_map
      {  #declare I = 0;
         #while (I < 10)
            [1 t_Brass
               normal
               {  bumps
                  translate <rand(S), rand(S), rand(S)> * 100
                  scale 1000
            #declare I = I + 1;
   translate <-1, 0, 1>
sphere
{  y, 1
   texture
   {  t_Brass
      normal
      {  average normal_map
         {  #declare I = 0;
            #while (I < 10)
               [1 bumps
                  scale 1000
               #declare I = I + 1;
   translate <1, 0, -1>
By my understanding of SDL, the two spheres should be identical.  Obviously, my
understanding is wrong, but I cannot figure out where the difference is.  Why
are the two spheres different?
I am using version 3.7RC3.
Download 'averagendemo.jpg' (51 KB)
Preview of image 'averagendemo.jpg'
Subject: Re: Averaged normals vs. averaged textures
Date: 9 Aug 2011 15:11:25
Message: <4e41865d$1@news.povray.org>
   When you average textures, POV-Ray will calculate each texture
independently and then average the results. If you average normals, the
resulting normals are average of the given normals, and used only once.
It's just how it has been implemented.
Date: 9 Aug 2011 15:16:27
Message: <4e41878b@news.povray.org>
I had the same assumption as you. I also did notice that with both
version 3.6 and 3.7.
I don't know why, but as the result did not change between 3.6 and 3.7,
I must assume that's by design.
Date: 9 Aug 2011 17:35:00
Message: <web.4e41a718b9efd2685de7b680@news.povray.org>
I see.  Thanks.
