POV-Ray : Newsgroups : povray.binaries.images : Anaglyph (red/cyan), Hinge reinforcement plate Server Time
3 Feb 2025 02:14:53 EST (-0500)
  Anaglyph (red/cyan), Hinge reinforcement plate (Message 1 to 1 of 1)
Subject: Anaglyph (red/cyan), Hinge reinforcement plate
Date: 1 Apr 2011 22:40:00
Message: <web.4d968c15edabccf958f1bff20@news.povray.org>
A gray scale anaglyph viewable with red/cyan 3d glasses.
A door hinge attachment plate that would be welded on the inside of a steel
frame. Both sides of the same style. This would be called a convertible hinge
plate. A standard weight hinge will fit ontop of the bumps (with dimple) and
removing the bumps (grinder or drill) would accommodate a heavy weight hinge.
The four bumps on the ends are for resistance spot welding.
To be fixed:
Four of the holes should be threaded.
The slot in the 90 degree bent part needs fixing. I should be using only half of
the  sheared cone.
Comments welcome:
Stephen S
Download 'hinge_4p5_dr370_anaglyph_a.png' (93 KB)
Preview of image 'hinge_4p5_dr370_anaglyph_a.png'
