![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello everyone,
Maybe this is already a documented issue, but if not here are two images
rendered from the exact same scene file, one rendered with v3.6.1a and the
other rendered with 3.6.2.
Dave Blandston
Download 'temp.png' (22 KB)
Preview of image 'temp.png'
![temp.png](/povray.binaries.images/attachment/%3Cweb.4a7c246da399eaf3df22a6900%40news.povray.org%3E/temp.png?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Dave Blandston schrieb:
> Hello everyone,
It *might* be helpful if you also disclosed the scene source code :P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Hello everyone,
> Regards,
> Dave Blandston
Where is the source scene file?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Alain
I'll post the source in POV-Ray Text Files - scene-files.
Dave Blandston
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Alain
After having boiled down the scene to about 60 lines, I found that the
only fault of POV-Ray 3.6.2 and 3.7 (but probably also of POV-Ray 3.6.1)
is that they don't warn you about pathological cylinders (and similarly
pathological tori) you're building in the BeveledCylinder macro; try the
following change:
#macro BeveledCylinder (Top, Bottom, Radius, EdgeRadius)
union {
cylinder {<Top.x, Top.y, Top.z + EdgeRadius>, Bottom, Radius}
-> #if (Radius > EdgeRadius)
cylinder {Top, Bottom, Radius - EdgeRadius}
torus {
Radius - EdgeRadius, EdgeRadius
rotate 90 * x
translate <Top.x, Top.y, Top.z + EdgeRadius>
sturm
} //torus
-> #else
-> sphere {<Top.x, Top.y, Top.z + EdgeRadius>, EdgeRadius}
-> #end
} //union
#end //#macro BeveledCylinder
POV-Ray 3.6.2 and 3.7 do indeed behave strange in such a case
(apparently creating an object which, when intersected with another one,
gets *bigger*), but what do you expect when working with infinitely thin
cylinders ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> following change:
> union {
> torus {
> rotate 90 * x
> sturm
> } //torus
> -> #else
> -> #end
> } //union
> cylinders ;-)
Yes, that was the problem - thanks! That's a very interesting situation.
Dave Blandston
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
