POV-Ray : Newsgroups : povray.binaries.images : Ivy Generator Server Time
23 Apr 2026 15:22:38 EDT (-0400)
  Ivy Generator (Message 9 to 18 of 29)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Ivy Generator
Date: 4 Jul 2009 12:14:20
Message: <4a4f7fdc$1@news.povray.org>
Tim Attwood schrieb:
>> Please leave comments on how to increase realism
> Real ivy gets little hair roots where it attaches to things,
> they're a little yellower than the main vine.
> It looks perty good already though.
> Here's a link with a good photo...
> http://www.moplants.com/blog/?p=1081
Thanx, I didn't know this before, but I think this would increase the
scene complexity too much, but I will think about this :-)
hobBIT
Date: 4 Jul 2009 12:22:21
Message: <4a4f81bd$1@news.povray.org>
Anthony D. Baye schrieb:
> Plants will grow towards a light source, it's called phototropism (which I
> learned about a long time ago and never thought to find a use for).  you'll find
> that in a dark room with light coming through a hole in the ceiling, vines will
> grow along the floor toward the light, and will generally try to find the hole
> in the ceiling. Perhaps your model could account for the direction of the light
> source as well.  It would be a matter of weighting the probability of a split in
> a given direction by the amount of light in that direction or the probability of
> reaching light by growing in that direction.
> Otherwise, I think it's excellent work, and I wonder if it could be applied to
> other plant life, like trees and shrubs.
> Are you predetermining the starting location, or is it random?
> A.D.B.
> "Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote:
>> "Christian Froeschlin" <chr### [at] chrfrde> schreef in bericht
>> news:4a4e1f30$1@news.povray.org...
>>> Also, there is a lot of ivy on top of the objects while the
>>> walls are more thinly covered. I'm no expert on ivy but this
>>> seems a bit odd (but probably it just needs more starting
>>> points to cover a wall).
>> In some way, real ivy seems to concentrate on the top of walls/objects,
>> maybe because sunlight is stronger there. At least, that is what I observe
>> in my garden, so the ivy generator is doing a good job :-)  Thomas Luft's
>> generator shows exactly the same phenomenon.
>> Thomas
At the moment, growing is weighted by 4 factors:
1. follow direction of last segment
2. random
3. gravity
4. "up",
while the last can be seen as growing towards light. It's easy to add
another weight which grows to a given vector, but growing to "light" can
be very complex, depending on scene complexity, maybe a path can help
out to accomplish this.
The starting point and primary growing direction are input parameters.
I think about a total replace of the current growing algo, as it always
clamps to any object, so hanging ivy is not really possible atm.
hobBIT
Date: 4 Jul 2009 12:31:54
Message: <4a4f83fa$1@news.povray.org>
Thomas de Groot schrieb:
> "hobBIT" <bla### [at] gmxde> schreef in bericht
> news:web.4a4e17009a7f7b0e28c001c10@news.povray.org...
>> last week I started to write a little ivy generator which can interact
>> with
>> every povray object. I was a bit inspired by the generator by Thomas Luft
>> (http://graphics.uni-konstanz.de/~luft/ivy_generator/) which only work
>> with
>> mesh objects. Please leave comments on how to increase realism,
> This is already looking really good! When you say 'every povray object' you
> mean 'including mesh2'? That is what I understand.
> Thomas
Thanx :-),
Imho mesh2 should work, I'm not that pov expert. The algorithm is quite
easy:
- calculate direction from current position, this can be manipulated by
different weight factors
- find nearest intersection to the given object instance, this is done
using 'trace', so it should work with mesh2
   (but this can heavily increase parsing time, I've implemented a
little macro which searches in all directions, so 96 traces for every
twig step can result in horrible parsing times if objects are too
complex, I thought about saving this to a file, so re-reandering with
the same params will go much faster)
- the resulting end position is than moved to this intersection
position, leaving a little distance into normal direction of the
intersection
hobBIT
Date: 4 Jul 2009 13:51:40
Message: <4a4f96ac@news.povray.org>
hobBIT schrieb:
> last week I started to write a little ivy generator which can interact with
> (http://graphics.uni-konstanz.de/~luft/ivy_generator/) which only work with
> many thanks,
> hobBIT
If someone is willing to try it, here's the current state, info on how
to use it can be found in ivytest.pov, near eof around the macro call
itself, good luck and show us your results :-)
hobBIT
Download 'ivygen.zip' (57 KB)
Date: 4 Jul 2009 15:35:00
Message: <web.4a4fadc0e71b54f15d563be30@news.povray.org>
> hobBIT
It started out being a 9/16 inch socket ;-)
I may not be able to control the growth, but I can stick a box and cylinder in
the way and see what happens.
Stephen S
Download 'tool_set_ive.png' (99 KB)
Preview of image 'tool_set_ive.png'
Date: 4 Jul 2009 15:53:17
Message: <lmcv451pd22ocdu0qu5c8hv0b14shqhm6f@4ax.com>
>> hobBIT
It's Modern Art Stephen :-)
Did you do it in Pov or B3D?
Regards
Date: 4 Jul 2009 18:47:54
Message: <4a4fdc1a@news.povray.org>
>> hobBIT
> Stephen S
Little update,
I modified the random part, so higher weights don't change the result
extremly anymore. Additionally, I've changed the leaf rotation, so it
looks more realistic. To the image: The big one shows the new leaf
positioning, the 3 smaller images use the same weights, but different
seeds, they tend to the same region, but with different look now, the
old version would create extremly different results here. Next step is
to rotate the leafs a bit more, so their "end" targets a bit more down
to follow the rules of gravity. But I have to go to sleep now, my son
wakes me up in 4-5 hours :-)
hobBIT
Download 'ivygen_up0.jpg' (211 KB) Download 'ivygen_up1.zip' (6 KB)
Preview of image 'ivygen_up0.jpg'
Date: 4 Jul 2009 21:20:00
Message: <web.4a4fff0fe71b54f177397ed0@news.povray.org>
Well both of course :-)
I've come to except, the best use of my time is useing the tools that work for
me. Not all of my problems are nails :-)
Stephen S
Date: 5 Jul 2009 03:02:42
Message: <4a505012$1@news.povray.org>
news:4a4f83fa$1@news.povray.org...
> easy:
>   (but this can heavily increase parsing time, I've implemented a little
> macro which searches in all directions, so 96 traces for every twig step
> can result in horrible parsing times if objects are too complex, I thought
> about saving this to a file, so re-reandering with the same params will go
> much faster)
> - the resulting end position is than moved to this intersection position,
> leaving a little distance into normal direction of the intersection
Yes, mesh2 objects will work indeed.
I think that writing away the end positions to file would be an excellent
idea. I do this too for planting on a large height_field for instance. Saves
a lot of time in the end.
Date: 5 Jul 2009 03:11:31
Message: <4a505223$1@news.povray.org>
news:4a4f81bd$1@news.povray.org...
> 2. random
> 3. gravity
> 4. "up",
> be very complex, depending on scene complexity, maybe a path can help out
> to accomplish this.
"up" is probably enough for most  outdoor cases as "light" can be
interpreted as the sun but also as the bright sky. Growing indoors however,
would need a vector, representing a window for instance, or several vectors
for several vectors, where a "brightness" parameter would additionally bias
the growth more or less.
Hanging ivy should be implemented indeed as this happens in real life as
soon as the branches overtop their support.
