POV-Ray : Newsgroups : povray.binaries.images : LegoRoad macro v2.5.0 Server Time
26 Jul 2025 08:13:27 EDT (-0400)
  LegoRoad macro v2.5.0 (Message 1 to 6 of 6)
Subject: LegoRoad macro v2.5.0
Date: 20 Dec 2008 22:50:00
Message: <web.494dbbd7e71b3bc929983cd0@news.povray.org>
I've updated my LegoRoad macro to version 2.5.0.
Fixes:
2.50
- All road objects are now solid and can be used within CSG operations.
- Added optional road embankments. The angle of the embankment is
  determined by the embankment slope and sky vector.
- Fixed the bug in flat intersections where gaps would appear at corners
  when roads intersected at angles greater than 180 degrees.
- The curve formed when roads intersect at angles greater than 180
  degrees now is more logical. The curve is continuous and no longer
  wastes space.
- Hermite spline roads can now accept any number of end and tangent
  points. Previously there was a limit of two of each.
- The height of flat intersections can now be specified.
- Spiral and elliptical roads can now have a minimum and maximum height
  instead of just a maximum.
- The entire texture for each road component (i.e. road surface,
  road stripe, shoulder stripe, etc.) can now be specified explicitely
  instead of only the pigment.
- Certain macro parameters have been removed and changed into globally-
  declared variables instead.
- Certain macro parameters have been changed so that indices start at 0
  instead of 1.
- Debug marker objects have been re-enabled or added if missing, and can
  be toggled on and off by setting the debug level to greater than 1.
- The texture macros have been modified slightly. They now all check for
  the road type.
- Many of the local variables have been renamed to be more consistent.
- The placement of the crosswalks in intersections is now more accurate.
- The macros now quit with an error and description of the problem in
  certain instances.
- Many other internal changes to the macros, including a heavier use of
  arrays to store pre-calculated information.
Download 'legoroad.png' (93 KB)
Preview of image 'legoroad.png'
Subject: Re: LegoRoad macro v2.5.0
Date: 21 Dec 2008 18:45:00
Message: <web.494ed43f83e8951df798649f0@news.povray.org>
divide by zero warnings?
I've never *been able* to divide by zero and have it still work like you can.
Truly amazing.
#declare LRoad_RoadWidth =  array[3] {280,306,360,}
#declare LRoad_StripeInterval =  array[3] { 64, 64, 64,}
#declare LRoad_CornerRadius =  array[3] { 23, 36, 63,}
#declare LRoad_MajorArc =  array[3] { 52,  0, 10,}
#declare LRoad_WalkDistance =  array[3] { 75, 75, 75,}
#declare LRoad_WalkWidth =  array[3] {234,234,234,}
#declare LRoad_WalkLength =  array[3] { 60, 60, 60,}
#declare LRoad_WalkStripeWidth = array[3] { 25, 25, 25,}
#declare LRoad_DistanceUnit =   10;
#declare LRoad_RoadColor =  color rgb <0.682353,0.682353,0.682353>;
#declare LRoad_EdgeColor =  color rgb <0.117647,0.627451,0.227451>;
#declare LRoad_StrpColor =  color rgb 1;
#include "LegoRoad_macro.inc"
#declare roads = array[2] { < -50000,0,0 >,< 50000,0,0 > }
object { LRoad_Intersection_Macro(roads,1,0) scale < .4,1,.5 > translate
<32,0,-126> }
Date: 22 Dec 2008 16:25:00
Message: <web.495004a183e8951db0bcadd30@news.povray.org>
The bug should be fixed now.
-Mike
Date: 23 Dec 2008 11:50:01
Message: <web.495115b283e8951dfa62dc780@news.povray.org>
> -Mike
googled download legoroad and 2.5.2 came up
what happened to the crosswalk?
/*  (  2.15
  array,
  1,
  no,
( 2.5.2    with Lego finish
  roadCoo,
  roadHgh,
  roadTyp,
  showCrs,
  showBed,
#include "LegoRoad_macro252.inc"
//#include "LegoRoad_macro215.inc"
object { LRoad_Intersection_Macro252(roads,.1,1,1,0) scale < .4,1,.5 > translate
<32,0,-126> }
//object { LRoad_Intersection_Macro(roads,1,0) scale < .4,1,.5 > translate
<32,0,-126> }
-aQ
Download 'lego_pool_04a.png' (138 KB)
Preview of image 'lego_pool_04a.png'
Date: 23 Dec 2008 20:00:00
Message: <web.495188a783e8951d289e01370@news.povray.org>
> > -Mike
The macro syntax changed in 2.5.0. Check the demo scene that comes with it.
-Mike
Date: 24 Dec 2008 09:15:01
Message: <web.4952433c83e8951dd0a728390@news.povray.org>
> > > -Mike
> -Mike
more like mistakenly reversed without testing
#declare LRoad_WalkWidth = array[3] {234,234,234 }
#declare LRoad_WalkLength =  array[3] { 60, 60, 60 }
Vs.
    #declare LRoad_WalkWidth =    array[3] { 60,60,60 }
    #declare LRoad_WalkLength =   array[3] {234,234,234}
Usually when ppl dont know what they are talking about, they dont.
This guy didn't think it thru or wouldnt be trying to dvide by zero.
I am trashing the whole thing and making a new one with correct logic.
2.15 tried to set all pigs then do a finish, gong show bell.
So I textured 2.15 since 2.5.2 is all messed up.
pigment {color LRoad_RoadColor}
finish { ambient 0.1 phong .5 phong_size 450 roughness 0.05 metallic brilliance
0.75 reflection 0.05 } }
Here's the new 2.15 finish to match Lego.
Download 'lego_pool_04c.png' (675 KB)
Preview of image 'lego_pool_04c.png'
