POV-Ray : Newsgroups : povray.binaries.images : Eat my dust Godel, Escher, Bach Server Time
14 Apr 2026 00:29:15 EDT (-0400)
  Eat my dust Godel, Escher, Bach (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Eat my dust Godel, Escher, Bach
Date: 12 Nov 2008 21:05:00
Message: <web.491b8a3a625722e11940c01c0@news.povray.org>
"Woody" <nomail@nomail> wrote:
> Comments? Suggestions? Constructive Criticisms? Apprehensions? Coagualtions?
If you could upload a macro to the Object Collection I'd be thankful.
-Mike
Date: 13 Nov 2008 11:40:33
Message: <491c5881$1@news.povray.org>
Darren New wrote:
> Cool. I tried to do this once using CSG to cut the letters out of a
> block and gave up before I could get it working. Looks like your method
> works better.
I'll have to play with this at home, but I think it should be feasable
with intersection ... I'll see if I can get my initials in a block like
that.
~Mike
Date: 13 Nov 2008 17:00:01
Message: <web.491ca2aa625722e149b4acd50@news.povray.org>
> > works better.
> that.
> ~Mike
I will try to get the source up as soon as I get home on Friday, to show you the
technical method.
Until then I can just say that each "letter" outline is not random. It's alot
easier to do it with only two letters, but when there are three its a lot less
controllable.
Originally the vertical bar for the J was in the center, but this messed up the
G. I also had the J and W, E and O, F and O, F and D in the same cubes, that is
only 4 with no solid squares. This also produced some funky shapes.
Date: 13 Nov 2008 19:30:01
Message: <web.491cc582625722e1791522d50@news.povray.org>
Ah, so it can't be done with arbitrary strings or fonts? That's too bad.
-Mike
Date: 13 Nov 2008 20:55:50
Message: <491cdaa6@news.povray.org>
>> method works better.
> that.
I decided to try with my initials (LEH) and came up with this _VERY_
simplified test image.  Just a single block with the three initials.
Fortunately, my initials were very easy to implement as simple unions of
boxes.  These were then differenced from a cube.  Note, difference not
intersection.
I don't know if this shape is physically possible, there might be
'floating' chunks in the middle someplaces.  But it works as a POV image.
I did end up using rounded boxes instead of regular boxes, and I
probably should change to spotlights as well.  But as I said, this was
just a simple initial test.
      -=- Larry -=-
Download 'leh.png' (24 KB)
Preview of image 'leh.png'
Date: 13 Nov 2008 23:25:00
Message: <web.491cfc4f625722e185de7b680@news.povray.org>
Surname in two parts, with high-ambient object and radiosity.
The third dimension looks to be a challenge; the differing widths of the letters
don't make for a straightfoward vertical cut.
Download 'call_wood.jpg' (44 KB)
Preview of image 'call_wood.jpg'
Date: 14 Nov 2008 15:50:01
Message: <web.491de04a625722e185de7b680@news.povray.org>
I was surprised at how well this turned out.  Only some of the letters were
clipped at the lower right corner--due, no doubt, to W, O, and D not having
lower right corners.
Since (through no fault of my own) I have no middle initial, I used my first
initial and split my surname into 2 parts.
Download 'r_call_wood.jpg' (45 KB)
Preview of image 'r_call_wood.jpg'
Date: 16 Nov 2008 19:20:01
Message: <web.4920b827625722e11695baba0@news.povray.org>
I put the scene file in the binaries at
<web.4920b79c1a0225801695baba0@news.povray.org>
Date: 16 Nov 2008 20:50:01
Message: <web.4920ccf0625722e1aa6c76d10@news.povray.org>
So the only requirements for the technique to work in every case are that the
font be monospace and that each letter touch all four edges at some point?
Do you mind if I work on the scene and upload it in macro form to the Object
Collection?
-Mike
Message: <web.4920cd16625722e11695baba0@news.povray.org>
>   Why aren't the objects illuminated by the same lights that are
> illuminating the surrounding walls?
Answer to save face:
That was part of the illusion intended.
Answer demonstraing ignorance:
I couldn't find a way to illuminate all sides of each cube (see attached).
I suppose in retrospect i could of put a light source within the larger blocks.
But I suspect it wouldn't give very distinguishable results.
-Jeff
Download 'namesake.2008.11.15.e.png' (39 KB)
Preview of image 'namesake.2008.11.15.e.png'
