POV-Ray : Newsgroups : povray.binaries.images : Stochastic render rig focal blur FIXED Server Time
16 Mar 2026 08:05:14 EDT (-0400)
  Stochastic render rig focal blur FIXED (Message 11 to 12 of 12)
Subject: Re: Stochastic render rig focal blur FIXED
Date: 23 Aug 2008 05:05:44
Message: <48afd2e8@news.povray.org>
Chambers wrote:
> I'd like to know, what is the difference between this and POV-Ray's inbuilt
> focal blur?
> Shouldn't the POV blur be faster, since it can use the adaptive level to skip
> some samples?
> And if this yields a better result than the inbuilt, how much work would it be
> to implement this version instead of POV's current version?
> ....Chambers
POV-Ray's focal blur is certainly faster than this technique - although
this method can give you shaped bokeh effect.
Where this method is sometimes a win is when you are using several
techniques together - for example I want to render some scenes that have
the following features:
   - Anti-aliasing
   - Focal Blur
   - High density light dome (100-1000 area lights sampled from an HDR
lightprobe)
   - Blurred reflection and refraction
Normally to do that you'd turn on AA and DoF, create all the lights
(say, 200 area lights), and use multi-texturing to average together a
large number (e.g. 256) of micro-facets on the blurred reflector and
refractor objects. The render times are huge in that case.
Instead of rendering a single image with all that turned on, I instead
render a large number of frames (anything from 50 to 1000 or even more)
with no AA, no DoF, one random 2x2 area light, and one random
micro-facet texture. Each frame renders quite quickly in that case.
Each frame has a different shear factor that, when averaged together,
gives a depth of field focal blur, a slight jitter of the camera
position to give (when averaged) anti-aliasing, as different light
source, so that the final averaged image has all the lights present, and
  a different micro-facet on every blurry surface to give a proper blur,
again when all the images are averaged together.
So it isn't useful to just replace a single feature, since POV-Ray
usually has adaptive techniques that would be faster, but it is useful
to reduce the render times of scenes with a particular combination of
features (like in the list above).
I really must come up with an example scene to try and show this off...
Cheers,
Edouard.
Date: 25 Aug 2008 16:26:47
Message: <48b31587$1@news.povray.org>
"stbenge" <THI### [at] hotmailcom> wrote in message
news:48af46e8$1@news.povray.org...
> What's RNG?
Random Number Generator :)
cu!
