POV-Ray : Newsgroups : povray.binaries.images : YATM Server Time
28 Mar 2026 08:10:13 EDT (-0400)
  YATM (Message 11 to 14 of 14)
Subject: Re: YATM
Date: 5 Jun 2008 22:00:00
Message: <web.48489920de6841fda5d4a01d0@news.povray.org>
Ok, here's my problem right now:
My tree and branches are made by following along a spline, placing vertices at a
specified radius in a circle around the spline.  In order for the branches to
have a consistent radius, I need the plane on which each circle of vertices
rests to be perpendicular to the the direction of the spline.
I thought that would be simple enough, but I'm having trouble.  I've been trying
to use vcross() to get an perpendicular axis to rotate a vector around, but
every time the spline changes direction, the axis will flip and therefore so
does the order of my vertices.  The result is an effect similar to twisting a
tube balloon.
Am I making any sense?  Any help?  Any simple solution that I'm just not seeing?
Subject: Re: YATM
Date: 6 Jun 2008 02:32:02
Message: <4848d9e2$1@news.povray.org>
"Kirk Andrews" <kir### [at] tektonartcom> wrote in message
news:web.48489920de6841fda5d4a01d0@news.povray.org...
> vertices at a
> to
> vertices
> trying
> but
> so
> twisting a
> tube balloon.
> seeing?
Yes. Keep a running note of the vector that you used to start the previous
circular sweep. Then use the VPerp_Adjust function in math.inc to adjust it
so that it is perpendicular to the direction of the spline for the next
step. This avoids suddenly getting a vector that points in completely the
opposite direction and should therefore avoid the irritating twisting
effect.
Chris B.
Subject: Re: YATM
Date: 6 Jun 2008 14:50:00
Message: <web.484985d0de6841fdb555cae70@news.povray.org>
> effect.
> Regards,
> Chris B.
Ah!  Thank you.  Works great.  I didn't think to look in math.inc for more
vector functions.
Subject: Re: YATM
Date: 6 Jun 2008 15:21:51
Message: <48498e4f$1@news.povray.org>
news:web.484985d0de6841fdb555cae70@news.povray.org...
>> previous
>> it
>> effect.
>> Regards,
>> Chris B.
> vector functions.
My pleasure. I remember it took me quite some time a few years ago to
discover it when I wanted to add some clothing around a limb and I don't
think I've ever used it for anything else since :o)
