POV-Ray : Newsgroups : povray.binaries.images : Find the Easter Egg Server Time
5 Apr 2026 14:16:06 EDT (-0400)
  Find the Easter Egg (Message 12 to 21 of 51)
Subject: Re: Find the Easter Egg
Date: 26 Jan 2008 16:17:30
Message: <479ba36a$1@news.povray.org>
bluetree wrote:
> There is a picture in the picture.
> Can you find it? :-)
> Regards
>                bluetree
The picture on the left wall appears very similar to the main scene
itself (though not identical).
...Ben Chambers
www.pacificwebguy.com
Date: 26 Jan 2008 18:05:12
Message: <o4fnp3pinfijmijdjoadvmkhjmmkmf6f97@4ax.com>
On Sat, 26 Jan 2008 13:17:27 -0800, Chambers <ben### [at] pacificwebguycom> wrote:
>> Regards
>>                bluetree
Could it be a mirror?
Regards
Date: 26 Jan 2008 20:34:45
Message: <479bdfb5$1@news.povray.org>
>>> Regards
>>>                bluetree
> Regards
> 	Stephen
Hmm, yes.  Then I would guess that he's either referencing the picture
of the family with the dog, or the "P" symbol on the wall.
...Ben Chambers
Date: 27 Jan 2008 13:10:00
Message: <web.479cc87861577883b72b7b3e0@news.povray.org>
Jan Dvorak <jan### [at] centrumcz> wrote:
> Your modelling is very good.
> To remove the flatness (the trees look like they are not shaded) add
> more light sources and decrease ambient
> if you don't mind to wait (expect minutes to tens of minutes for the
> final render) use radiosity. We'll aid you learn it if you need to.
> Without radiosity a realism is nearly impossible for indoor scenes.
> Good reflections can help a lot but your scene doesn't contain many
> objects that could reflect (none at all, to be exact).
> You've got a potential
Thank you very much!!
(For your nice words and all advices! ^^)
It would be great to get help on radiosity!
The plants at the floor are reflecting, but using such dark conditions, it
cannot be seen.
I'll try to change the tree barks and to add some normal maps...
Date: 27 Jan 2008 13:10:01
Message: <web.479cc89861577883b72b7b3e0@news.povray.org>
"alphaQuad" <alp### [at] earthlinknet> wrote:
> "bluetree" <nomail@nomail> wrote:
> > Tell me everything I have to improve (as I know, that this scene doesn't look
> > very *real*).
> Realism is over rated and content is more or less everything
> IMO
> aQ
But if it looks too artificial and not at all artistic, it's not very good,
isn't it?
Message: <web.479cc8c661577883b72b7b3e0@news.povray.org>
Stephen <mcavoysATaolDOTcom@> wrote:
> On Fri, 25 Jan 2008 14:10:20 EST, "alphaQuad" <alp### [at] earthlinknet>
> >> very *real*).
> >IMO
> >aQ
> And visual effect.
> I like pointillism and that's not photo- realistic.
> Bluetree:
> As Jan said your modelling is good.
> I don't like the shadow of the table so I would be tempted to try either making
> the candle lights, no_shaddow  or use Light Fading or a mixture of both. It is a
> cheat, I know, but we can try to render what we want to see.
> The rugs could use some more normals in their texture as could the floor.
> A bit of reflection on the plant pots. You can use a different texture for the
> inside by putting one texture on the difference group and one on the subtracting
> object.
> The carpet at the back and the cushions are too dark in my view try upping the
> ambient until you get the lighting sorted out.
> Seriously I wish my first interior had been as good. I like the placement of
> objects in the room and the colour of the walls make a nice mood. There is a
> story there.
> Drat! I just read what nemesis said about the cat face. Ignore what I said about
> the candle light. Did you mean that?
> Regards
>  Stephen
Wow, thanks! I have to change quite a lot, I see.
One reason why I hardly didn't dare to post it at first. Thanks for the detailed
advices.
I made the mistake to put the candle lights inside two different sphere sweeps,
so the walls get this colour...
To tell the truth, the walls are blue with normal map, which should imitate a
stucco structure.
So these colours are from the candle lights. ^^
A nice side effect, that I didn't change, because I also liked it more than the
blue walls before.
I didn't know what to do with the plant pots. That's a very good idea. I'll
change it immediately.
Yes,  (sheepish), I meat that construction on the floor....
Message: <web.479cc8e461577883b72b7b3e0@news.povray.org>
nemesis <nam### [at] gmailcom> wrote:
> surely that big cat face in the middle? oops...
Yes... ^^
 (too obvious, I finally know)
Next time it will be quite harder to notice, I'll promise! :)
Date: 27 Jan 2008 13:15:00
Message: <web.479cc90461577883b72b7b3e0@news.povray.org>
"dlm" <me### [at] addressinvalid> wrote:
> "nemesis"  wrote in message news:479a3ee9$1@news.povray.org...
> Isn't that Max the rabbit of Sam & Max fame.
> DLM
In reality there is no face...
no construction of a face...
it's all, what your brain makes you thinking of. :)
Date: 27 Jan 2008 13:15:01
Message: <web.479cc91f61577883b72b7b3e0@news.povray.org>
Nicolas Alvarez <nic### [at] gmailisthebestcom> wrote:
> That's totally amazing to be your first.
> You need better lighting though :)
Thanks!
It's my first interior, but I have tried to do simple things before.
I shouldn't get too many compliments. ^^
Message: <web.479cc94561577883b72b7b3e0@news.povray.org>
> Nothing really wrong with this image, you know. A first scene? Infinitely
> better than my first ever!
> Try radiosity, just the default values, and see where it gets you. You will
> get help on the way.
> Thomas
That would be wonderful! Thank you!
I read a little about radiosity, but I'm not sure about all options and how to
use them exactly.
I'll try it. Should I post the result (better: can I post it? The images are
very big in size. I don't know why...)
