POV-Ray : Newsgroups : povray.binaries.images : Doghouse Server Time
30 Mar 2026 23:08:07 EDT (-0400)
  Doghouse (Message 11 to 20 of 30)
Subject: Re: Doghouse
Date: 22 Oct 2007 14:52:32
Message: <471cf170$1@news.povray.org>
web.471cecaf1319a9ad88727a860@news.povray.org...
> "M_a_r_c" <jac### [at] wanadoofr> wrote:
> There's a 50-50 chance it's already in your email inbox.
> - Ricky
Though is it (there & !there) till I open the box?
Marc
Date: 22 Oct 2007 17:13:35
Message: <8cgvu4-k1r.ln1@badulaque.unex.es>
Among other things, Thomas de Groot saw fit to write:
> Let me make a guess... I think not  :-)
> Look at this image: just one render!
Or look at my signature :-D
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 22 Oct 2007 23:30:00
Message: <web.471d69b71319a9ad2c72a4960@news.povray.org>
"triple_r" <rre### [at] hotmailcom> wrote:
> both made in Wings3D.  Very useful program.
>  - Ricky
well first off, its home page says,
Povray 3.5 export plug-in
Download it from KayosIII's Wings Plugin Page.
and you get:
Not Found
The requested URL /~rgcoy/software.html was not found on this server.
User Manual 1.6.1 (PDF) crashes
are there any solutions to these issues?
otherwise, I'd say, almost useful.
Date: 22 Oct 2007 23:50:01
Message: <web.471d6f1a1319a9ad2c72a4960@news.povray.org>
home page link for manual has issues
google: wings 3D user manual
http://en.wikibooks.org/wiki/Wings_3D:_User_Manual
Document source:
http://dl.sourceforge.net/sourceforge/wings/wings3d_manual1.6.1.pdf
         DRAFT 1.61
(Current as of Rev. 0.98.10d)
        June 12, 2003
      by Jon M. Strother
       by Jason McAlpin
  with contributions from the
  Wings3D user community.
now where is the POV "export plugin"
Date: 23 Oct 2007 00:20:01
Message: <web.471d759c1319a9ad2c72a4960@news.povray.org>
latest version
http://sourceforge.net/project/showfiles.php?group_id=33028&package_id=25098&release_id=465654
http://www.wings3d.com/ just sucks.
Jim uploaded to:
http://hendersj.googlepages.com/wingspov-0.98.28_v1.tgz
ref:
http://news.povray.org/irtc.animations/thread/%3C46466cc4$1@news.povray.org%3E/
Date: 23 Oct 2007 00:25:00
Message: <web.471d77561319a9ad88727a860@news.povray.org>
> and you get:
> Not Found
Well I'm not sure about the manual.  Search for Blender or Silo tutorials
and you can probably pick up the basics as it's fairly universal.  Or maybe
a different PDF viewer.
I never got any kind of plugin to work.  Instead, I tried the various file
formats by trial and error.  It turns out that the .obj file is identical
in format to a mesh2 object.  It comes down to parsing and writing the data
with only formatting differences.  I have a lengthy and SLOW shell script I
could send you, and I'm also tinkering with a c program that does the same.
 Neither are extremely robust, but it works fine for uv-mapping too.  Try
exporting a .obj file for a cube or something simple and notice the
formatting.  'v' lines are vertices, 'vn' lines are vertex normals, and
1//1 2//2 3//3 lines contain face and normal indices (usually the same).
What the hey--here's the shell script I've been using.  Now I'll go hang my
head in shame.  It's that bad.  It basically parses the file multiple
times, separating the contents into different files.  Then it recombines
them into a mesh2 object.  Works fine for moderately-sized object.  Just
export a .obj file with triangulation and run the script.  I guess I've
been assuming you use Linux, so if this doesn't work, I might be able to
get my c parser pared down.  Right now it does some other stuff for a
specific purpose.  I'm sure someone else will post the plugin and this will
fall into a void, but I'm a do-it-yourself-er.  Hope it's worth something to
someone.
 - Ricky
input=object.obj
output=`echo "$input" | sed -e 's/.obj/.pov/'`
name=`echo "$input" | sed -e 's/.obj//'`
echo "converting '$input' to '$output'."
rm -f $output
cat $input | sed -e 's/////1//g' > $output
mv $output $input
#VERTICES:
echo "Saving vertex vectors..."
vertices=`echo "$input" | sed -e 's/.obj/.vert/'`
vertices2=`echo "$input" | sed -e 's/.obj/.vert2/'`
cat $input | grep "^v " | sed -e "s/v *([[:digit:].e+-]*)
*([[:digit:].e+-]*) *([[:digit:].e+-]*).*/<1,2,3>,/g" > $vertices
vertlines=`wc -l $vertices | sed -e 's/[ t]*([[:digit:]]*).*/1/g'`
vertlines1=`expr $vertlines - 1`
head -n $vertlines1 $vertices > $vertices2
tail -n 1 $vertices | sed -e 's/,$//g' >> $vertices2
mv $vertices2 $vertices
#VERTEX NORMALS
echo "Saving vertex normals..."
vertexn=`echo "$input" | sed -e 's/.obj/.vertn/'`
vertexn2=`echo "$input" | sed -e 's/.obj/.vertn2/'`
cat $input | grep "^vn " | sed -e "s/vn *([[:digit:].e+-]*)
*([[:digit:].e+-]*) *([[:digit:].e+-]*).*/<1,2,3>,/g" > $vertexn
nvertlines=`wc -l $vertexn | sed -e 's/[ t]*([[:digit:]]*).*/1/g'`
nvertlines1=`expr $nvertlines - 1`
head -n $nvertlines1 $vertexn > $vertexn2
tail -n 1 $vertexn | sed -e 's/,$//g' >> $vertexn2
mv $vertexn2 $vertexn
#UV VECTORS
#echo "Saving uv vectors..."
#uv=`echo "$input" | sed -e 's/.obj/.uv/'`
#uv2=`echo "$input" | sed -e 's/.obj/.uv2/'`
#cat $input | grep "^vt " | sed -e "s/vt *([[:digit:].e+-]*)
*([[:digit:].e+-]*).*/<1,2>,/g" > $uv
#uvlines=`wc -l $uv | sed -e 's/[ t]*([[:digit:]]*).*/1/g'`
#uvlines1=`expr $uvlines - 1`
#head -n $uvlines1 $uv > $uv2
#tail -n 1 $uv | sed -e 's/,$//g' >> $uv2
#mv $uv2 $uv
#FACE INDICES
echo "Saving face indices..."
faces=`echo "$input" | sed -e 's/.obj/.faces/'`
faces2=`echo "$input" | sed -e 's/.obj/.faces2/'`
cat $input | grep "^f " | sed -e "s/f
*([[:digit:]]*)/([[:digit:]]*)/([[:digit:]]*)
*([[:digit:]]*)/([[:digit:]]*)/([[:digit:]]*).*/<1-1,4-1,7-1>,/g" > $faces
nfaces=`wc -l $faces | sed -e 's/[ t]*([[:digit:]]*).*/1/g'`
nfaces1=`expr $nfaces - 1`
head -n $nfaces1 $faces > $faces2
tail -n 1 $faces | sed -e 's/,$//g' >> $faces2
mv $faces2 $faces
#UV INDICES
#echo "Saving uv indices..."
#uvi=`echo "$input" | sed -e 's/.obj/.uvi/'`
#uvi2=`echo "$input" | sed -e 's/.obj/.uvi2/'`
#cat $input | grep "^f " | sed -e "s/f
*([[:digit:]]*)/([[:digit:]]*)/([[:digit:]]*).*/<2-1,5-1,8-1>,/g" > $uvi
#nuvi=`wc -l $uvi | sed -e 's/[ t]*([[:digit:]]*).*/1/g'`
#nuvi1=`expr $nuvi - 1`
#head -n $nuvi1 $uvi > $uvi2
#tail -n 1 $uvi | sed -e 's/,$//g' >> $uvi2
#mv $uvi2 $uvi
#NORMAL INDICES
echo "Saving normal indices..."
normal=`echo "$input" | sed -e 's/.obj/.normal/'`
normal2=`echo "$input" | sed -e 's/.obj/.normal2/'`
*([[:digit:]]*)/([[:digit:]]*)/([[:digit:]]*).*/<3-1,6-1,9-1>,/g" > $normal
nnormal=`wc -l $normal | sed -e 's/[ t]*([[:digit:]]*).*/1/g'`
nnormal1=`expr $nnormal - 1`
head -n $nnormal1 $normal > $normal2
tail -n 1 $normal | sed -e 's/,$//g' >> $normal2
mv $normal2 $normal
#ASSEMBLING POV-RAY FILE
echo "Saving POV-Ray output file..."
echo "#declare $name=mesh2{" > $output
echo 'vertex_vectors{' `wc -l $vertices | sed -e 's/[t
]*([[:digit:]]*).*/1/g'`, >> $output
cat $vertices >> $output
echo '}' >> $output
echo 'normal_vectors{' `wc -l $vertexn | sed -e 's/[t
cat $vertexn >> $output
echo '}' >> $output
#echo 'uv_vectors{' `wc -l $uv | sed -e 's/[t ]*([[:digit:]]*).*/1/g'`, >>
$output
#cat $uv >> $output
#echo '}' >> $output
echo 'face_indices{' `wc -l $faces | sed -e 's/[t ]*([[:digit:]]*).*/1/g'`,
>> $output
cat $faces >> $output
echo '}' >> $output
echo 'normal_indices{' `wc -l $normal | sed -e 's/[t
cat $normal >> $output
echo '}' >> $output
#echo 'uv_indices{' `wc -l $uvi | sed -e 's/[t ]*([[:digit:]]*).*/1/g'`, >>
$output
#cat $uvi >> $output
echo '}' >> $output
Date: 23 Oct 2007 00:35:00
Message: <web.471d79cb1319a9ad2c72a4960@news.povray.org>
> could send you,
naw, but thanks anyway. I can write script or compile C code to format any
data I want.
was just hoping for a pov page export. I can work around it, if this plugin
I found fails.
Tanks again,
aQ
Date: 23 Oct 2007 03:26:14
Message: <471da216$1@news.povray.org>
"M_a_r_c" <jac### [at] wanadoofr> schreef in bericht
news:471cf170$1@news.povray.org...
>> - Ricky
> Marc
paradox. In my parallel probability universe (from which I am mailing you),
Date: 23 Oct 2007 05:50:00
Message: <web.471dc2b41319a9ad731f01d10@news.povray.org>
If we get all your parallel personae to bang randomly on their keyboards and
email the result to this forum, would one of them produce a reflective
sphere on a checkered plane?
Date: 23 Oct 2007 06:00:00
Message: <web.471dc58e1319a9adc4e49fa40@news.povray.org>
> >> - Ricky
> > Marc
> Thomas
Have you looked?
