POV-Ray : Newsgroups : povray.binaries.images : Crater field update - Mars Server Time
13 Mar 2026 17:52:23 EDT (-0400)
  Crater field update - Mars (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Crater field update - Mars
Date: 15 Jul 2006 10:39:47
Message: <44b8fe33@news.povray.org>
RusHHouR wrote:
> Your screen is upside down.
   Reversed as in inverted: The crater walls look like they are going
down into the ground, and the plateaus look like hills.
   No matter how long and how I look at the image, I can't see the
crater walls going up.
Date: 15 Jul 2006 14:11:20
Message: <44b92fc8@news.povray.org>
Warp nous apporta ses lumieres en ce 15/07/2006 04:53:
>   Why does it look like the craters are reversed?
The light is comming from the BOTTOM left.
Christian Science #2: Shit happening is all in your mind.
Date: 15 Jul 2006 14:20:13
Message: <44b931dd$1@news.povray.org>
   No matter how long I look at it, I see bubbles, not craters.
   Perhaps one problem is that the crater walls don't cast shadows.
Date: 15 Jul 2006 14:45:22
Message: <44b937c2$1@news.povray.org>
Warp nous apporta ses lumieres en ce 15/07/2006 14:20:
They do cast slight shadows, toward the TOP and a little to the right, and ONLY on the
ground
outside of the craters. Those shadows are what make you see them as inverted.
Gossip is when you hear something you like about someone you don't.
Date: 15 Jul 2006 23:10:01
Message: <web.44b9ad23b22ae34910f27a7b0@news.povray.org>
"EagleSun" <nomail@nomail> wrote:
> "Mike Sobers" <sob### [at] mindspringcom> wrote:
> > I compiled the crater field generator code by PM 2Ring with a few
> > modifications:
> Hmm....  Did your program make this image?  (Originally 4000x4000-16bit)
Probably, but it's not my program.  I only modified it to add some more
details.  And it only puts out 8-bit (for now).
Mike
Date: 16 Jul 2006 05:40:11
Message: <incpo3-5df.ln1@badulaque.unex.es>
Among other things, Warp saw fit to write:
No matter how long I look at it, I see craters, not bubbles. ;)
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 16 Jul 2006 06:56:00
Message: <44ba1b40$1@news.povray.org>
   Deducing from your smiley I assume it's not true.
Date: 16 Jul 2006 08:40:12
Message: <kdmpo3-oov.ln1@badulaque.unex.es>
No, it's true, even though the light comes from below, I have no problem
seeing craters and I just can't get my brain to "see" bubbles.
Date: 16 Jul 2006 09:42:32
Message: <44ba4248$1@news.povray.org>
   It's just so strange. Even when I make great efforts to force my
brain to see craters instead of bubbles, I can't. I concentrate on
one of the circles, visualize the light coming from below (and a
bit from the left), adamantly think "ok, starting from below the
circle, the terrain goes *up* and gets more lighted, then there's
a sharp edge after which the terrain goes *down* as is thus darker,
after which there's a large depression in the ground, after which
the terrain goes again *up*, there's a sharp edge and goes *down*
again", it doesn't help. My brain still sees the exact opposite:
A bubble with its borders dug into the ground. No matter how hard
I try, I cannot get my brain to see a crater. Strange.
   I wonder what would happen if the image was re-rendered with the
light coming from the opposite side.
Date: 16 Jul 2006 14:22:02
Message: <44ba83ca$1@news.povray.org>
I tried once again, this time occluding parts of the crater I was
concentrating on, suddenly my brain flipped the image and now I see
craters instead of bubbles!
   Ironically, now that I see craters I'm unable to see the bubbles...
