POV-Ray : Newsgroups : povray.binaries.images : Ringworld re-re-revisited Server Time
5 Apr 2026 00:22:35 EDT (-0400)
  Ringworld re-re-revisited (Message 3 to 12 of 32)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Ringworld re-re-revisited
Date: 27 Oct 2005 08:51:22
Message: <4360cd4a@news.povray.org>
news:web.4360929f30852916731f01d10@news.povray.org...
> Just in case any of you were getting bored of ringworlds...
> This is a substantial improvement on my previous effort. The ring is
pretty
> much the dimensions stated in the book (and elsewhere here) - 90 million
> miles in radius (although it should be 95 I believe), with 20 shadow
> squares orbiting 12 million miles from the sun. The sun is an area_light 1
> million miles in diameter.
> The atmospheric effects are of course the most difficult, and in this
regard
> I cheated somewhat - the haze is merely a ground fog, and the blue sky is
a
> semitransparent sky sphere about a million miles wide, i.e. between the
> camera and the arch.
> I think the landscape is of realistic dimensions, but sadly the clouds are
> slightly exaggerated - they are 200 miles in the air, with the camera at
an
> altitude of 100 miles. The reason for this is that I couldn't place the
> camera any lower without some kind of precision artifact creeping into the
> lower half of the image (I'll post an example in a bit).
Excellent images, both of them! The atmosphere is much better than in my own
experiments. I am afraid that we have to cheat a bit to get it really right.
In truth, because of the dimensions, the whole *foreground* is a landscape
in itself, almost separate from the background arch.
Date: 27 Oct 2005 21:04:48
Message: <43617930$1@news.povray.org>
Both of your WIPs are great.
I've been thinking a bit about having a go
at Rama.. But, I need to read it again
before that.
Both these posts inspired me to
get in gear :)
"Thomas de Groot" <t.d### [at] internlnet> skrev i meddelandet
news:4360cd4a@news.povray.org...
> "Bill Pragnell" <bil### [at] hotmailcom> schreef in bericht
> pretty
>> 1
> regard
> a
>> are
> an
>> the
> own
> right.
> Thomas
Date: 28 Oct 2005 02:51:13
Message: <4361ca61$1@news.povray.org>
"Stefan Persson" <azy### [at] hotmailcom> schreef in bericht
news:43617930$1@news.povray.org...
> before that.
> get in gear :)
Excellent! That is what these forum's (fora?) are for!!
Date: 28 Oct 2005 04:22:07
Message: <4361dfaf$1@news.povray.org>
forums!
SCNR   ;-)
Date: 28 Oct 2005 07:20:01
Message: <web.43620927ca18a3ea731f01d10@news.povray.org>
> before that.
It's useful having such technically-minded authors - they provide complete
blueprints in prose, with dimensions and everything. It's almost as if they
knew that one day ppl like us would sit down in front of our difference
engines and build their creations as virtual realty...
> get in gear :)
Why did I come back to using POV after 4+ years of inactivity? Inspiration
gained from lurking here, of course... :)
Bill
Date: 28 Oct 2005 08:00:00
Message: <web.4362127eca18a3ea731f01d10@news.povray.org>
Right, just to illustrate this suspected precision glitch, here's 7 images
of a simplified Ringworld (please excuse the crudity of the composite).
The Ring is a hollow open cylinder 1 million units tall and 90 million units
in radius, with a light at the centre. I've translated it by 90 million y
so that the origin lies on the Ring surface with the x axis at a tangent.
The first three images are, left to right, a camera y = 100, 10, 1.
The middle image is camera y = 0.
The final three images are, left to right, a camera y = -1, -10, -100.
Firstly, Thomas, do you see the same thing with your Ring?
Secondly, can anyone clarify what exactly is happening here? Is it a
precision problem, or something else?
code:
camera { location <0, 100, 0>
         up <0, 1, 0>
         right <4/3, 0, 0>
         direction <0, 0, FoV_75>
         look_at <-1000, 0, 0> }
#declare Ring = union {
  light_source { <0, 0, 0> color White }
  cylinder { <0, 0, -500000>, <0, 0, 500000>, 90000000 open hollow
             pigment { color SkyBlue }
             finish { ambient 0.5 } } }
object { Ring translate <0, 90000000, 0> }
Bill, confused.
Download 'ringtest.png' (9 KB)
Preview of image 'ringtest.png'
Date: 28 Oct 2005 21:35:15
Message: <4362d1d3$1@news.povray.org>
they
Yep, and I need to get the images back in my head.
All I remember is that it's a 5x2 km cylinder .. hehe
But, yes, Clarke usually desbribes everything in a most
detailed technical way. On the other hand authors like Asimov
leaves more to the imagination.. I don't know which is better
from the artists point of view. I mean, the first, like you said,
provide almost blueprints.. but that also means that you have
less freedom.
Date: 29 Oct 2005 02:48:51
Message: <43631b53@news.povray.org>
news:web.4362127eca18a3ea731f01d10@news.povray.org...
units
Yes, Bill. The same happens with my Ring. If I lower my camera towards the
surface I get exactly the same artifacts.
Date: 29 Oct 2005 07:36:56
Message: <43635ed8$1@news.povray.org>
> Thomas
I've run into problems like this before.  POVRay is designed for
rendering scenes of "normal" sizes where "normal" is in the range of
arount 100,000 units from the origin.
When using floating point numbers, you can't test for exactly 0 because
floats are always slightly inaccurate.  Instead, you have to test for
numbers smaller than some epsilon value.
There's a value called EPSILON (see frame.h) which defines a small value
and anything smaller would be considered 0 in some of the calculations.
  This value is set to 1e-10 which is dangerously close in magnitude to
1 / 90,000,000 (the scale of Ringworld).
To solve this problem, you may have to try decreasing the epsilon value
and recompiling POVRay.  You may still run into problems, though,
because doubles may not have enough precision to handle the
calculations.  You may come up with calculations like
	90,000,000.00000012 - 90,000,000.0000001
The correct answer should be 0.00000002, but the numbers just can't
represent 90,000,000.00000012 accurately.  That's the nature of limited
precision floating point calculations. It's bad news for people trying
to render Ringworld, though.
Hope this helps
David Buck
Date: 29 Oct 2005 09:27:23
Message: <436378bb@news.povray.org>
"David Buck" <dav### [at] simberoncom> schreef in bericht
news:43635ed8$1@news.povray.org...
Would more scaling down help? My model has currently a radius of 95,000 pov
units, but also translated 95,000 units to keep the camera near the origin.
It is possible to scale everything down more of course, without changing the
aspect of the scene...
