![](/i/fill.gif) |
This is my first attempt with making something nice with isosurfaces (and
first image post here). I think it looks pretty good. :D
I'm planning on making a water type faucet and sticking it in the side with
some liquid dripping out. Weee!
#include "textures.inc"
#declare debugin = false;
global_settings{
max_trace_level 5
#if (debugin = false)
radiosity {
pretrace_start 0.08
pretrace_end 0.04
count 20
nearest_count 5
error_bound 0.2
recursion_limit 1
low_error_factor 0.5
gray_threshold 0.0
minimum_reuse 0.015
brightness 1
adc_bailout 0.02
background{White}
location<1, 1.6,-2.5> look_at<0,0,0> //topish view
light_source {
<-200,320,15>, rgb 0.7 //adaptive 1
union{
difference{
isosurface { //whole trunk and bark
function{-f_cylindrical(x,y,z)-f_agate(x*5,y*1.43,z*5)/8 + 0.2}
threshold 0
contained_by{box {<-1,-1,-1>,<1,1,1>}}
max_gradient 3
pigment { //color bark depending on radius
wood
color_map{
//dark ring color divided by 2.3
[0.0 color rgb 2*<0.5019, 0.25, 0>/2.3]
//dark ring color divided by 3.5
[1.0 color rgb 2*<0.5019, 0.2, 0>/3.5]
//test colors to show gradient
//[0.0 color rgb<1, 0, 0>] //red
//[1.0 color rgb<0, 0, 1>] //blue
scale 0.08
rotate x*90
rotate y*30
turbulence 0.06
phase pi/2 //adjust so highest are dark
finish{reflection 0.001 diffuse 0.4 crand .3 ambient 0}
isosurface { //cut out trunk
function{-f_cylindrical(x,y,z)-f_agate(x/.2,y/.7,z/.2)/14+.26}
threshold 0
contained_by{box {<-1,-1.1,-1>,<1,1.1,1>}}
max_gradient 2
pigment{Tan} //give cut mark tan color in hopes of sap appearence
isosurface { //add trunk back in with different texture
threshold 0
contained_by{box {<-1,-1,-1>,<1,1.1,1>}}
max_gradient 2
wood
color_map{
[0.0 color rgb 2*<0.5019, 0.25, 0>]
[0.4 color rgb 2*<0.5019, 0.25, 0>]
[1.0 color rgb 2*<0.5019, 0.2, 0>/2]
scale 0.08
rotate x*90
rotate y*30
turbulence 0.04
finish{diffuse 0.4 crand .2 ambient .1}
normal{
average
normal_map{
[0.2 wrinkles 1 scale 1 scale y*2]
[1.4 granite 1 scale 0.08 scale y*0.45]
Download 'log_single.jpg' (60 KB)
Preview of image 'log_single.jpg'
![log_single.jpg](/povray.binaries.images/attachment/%3Cweb.42301e81754917e6f6440bf00%40news.povray.org%3E/log_single.jpg?preview=1)
![](/i/fill.gif) |
![](/i/fill.gif) |
"dan B hentschel" <dan### [at] alum rit edu> wrote:
> The shape of the trunk is very nice. The texture isn't great, though, and
> kind of ruins the effect. The color is too orange, and there are not enough
> rings: only 11 indicates that this tree was eleven years old when it died.
> This doesn't match with the very rough/rugged looking bark on the trunk.
> - dan B hentschel
Thanks dan, you told it like it was. I appriciate that. :)
You're right about the rings. I was going for redwood bark, so, I should
probably add a couple thousand more :P
Recalibrating my lcd made the brightness and color problems obviouse. Looks
much better now.
Thanks,
brandon
![](/i/fill.gif) |
