POV-Ray : Newsgroups : povray.binaries.images : Markov Chain Server Time
26 Jan 2026 02:50:42 EST (-0500)
  Markov Chain (Message 1 to 5 of 5)
Subject: Markov Chain
Date: 28 Jun 2021 06:39:55
Message: <XnsAD5780D5FF3BDseed7@news.povray.org>
The result of an attempt to create Markov Chains.
https://ingoogni.nl
Download 'markov_scene.gif' (309 KB) Download 'markov_scene.pov.txt' (3 KB) Download 'markov.inc.txt' (9 KB)
Preview of image 'markov_scene.gif'
Subject: Re: Markov Chain
Date: 30 Jun 2021 04:29:11
Message: <60dc2b57$1@news.povray.org>
ingo wrote on 28/06/2021 12:39:
Interesting result.
I was used to see Markov Chains with nodes and arrows, but your image is
visually prettier.
Paolo
Date: 1 Jul 2021 07:45:00
Message: <web.60ddaa903c46af395e0fed26cde94f1@news.povray.org>
hi,
thanks, interesting.  like PG I've not seen Markov Chains used to generate
graphics/patterns, only knew of an application which generates "gibberish" text.
regards, jr.
Date: 1 Jul 2021 14:00:45
Message: <XnsAD5ACB91B6306seed7@news.povray.org>
in news:web.60ddaa903c46af395e0fed26cde94f1@news.povray.org jr wrote:
> hi,
> generate graphics/patterns, only knew of an application which
Oh, they are used for all kinds of things, page rankings, weather
prediction (in a simple way). In generative music they are used for
(beat)pattern generation and chord progression.
Here's an other one. Although I didn't feel like hand filling the chances
in a 256 point transition matrix so I condensed it a bit.
I used a simple kind of domino like shape. Square with cutouts, 5 shapes,
with rotations resulting in 16 shapes.
Placed in a grid with random choise of shape but within rule set:
   - start bottom left, then progress row by row
   - left side of next shape is same as right side of left neighbour.
   - bottom side of a next shape is same as top side of neighbour below.
   - if the last piece is within the range of possible pieces, given the
     neighbours shapes increase its chance (in a naive way)
The Markov chains can also be used for texture generation. Instead of the
simple shapes I used you can use square of textures with very simmilar
forms.
An other application is adding vegetation to a landscape. Use some rules
to select a range of vegetation types. Then use markov to select a tree
from the bunch. A rule can be to have a look at the trees in the
neighbourhood and then increase the chance on the same tree. The higher
the order of the transition matrix the more "clumping" of the same type
you get.
https://ingoogni.nl
Download 'domino2.pov.txt' (10 KB) Download 'domino2.png' (274 KB)
Preview of image 'domino2.png'
Date: 12 Jul 2021 03:59:51
Message: <60ebf677$1@news.povray.org>
ingo wrote on 01/07/2021 20:00:
>> hi,
> forms.
> you get.
A starting point for a lot of new ideas... thank you,
Paolo
