I only just now saw both your diamond renders. Especially these last
ones look really good.
I have to agree on what Jaime wrote, most images of brilliants I've
seen look more like the image he linked than the one you posted.
I was trying to do some brilliant cut diamonds two weeks ago and managed
to google up some extra information:
The ior and dispersion settings should be correct, reflection is a bit
off I think; I found information (don't have the link but can probably
google it up again if you need it) that diamond reflects around 17% at a
0 degree incident angle and nearly 100% at a 90 degree angle.
I don't know how much influence this has on the output image but I
remember it made the my renders better after adjusting the reflection
settings, allthough it could be I fiddled with another knob and this had
nothing to do with it.
I included an image of one of my renders ( I don't have the source for
this exact scene any more as I continued to play around with it, but I
still have the settings for the diamond texture, interior and finish)
Mind you, I think your renders look a lot better, the colors in my
version are way to flat(?) and seems to be to harshly lit, but I do like
the characteristic blue and yellow streaks (scintillation ?).
I hope this helps any and is not just a wast of bandwidth ;-).
Rob
Marc Champagne wrote:
> Here is a new render of the diamonds
> 1- new render
> 2- previous render
> 3- real
Download 'jg_brilliant_test.jpg' (24 KB)
Preview of image 'jg_brilliant_test.jpg'
Jaime Vives Piqueres <jai### [at] ignorancia org> wrote in
news:3d79ac53@news.povray.org:
> Perhaps is not a very good reference photo. Take a look at that other:
> http://www.gia.org/giaresearch/images/Diamonds.jpg
> Aren't these much more similar to your ones? :)
shesh, almost identical, i have added your reference photo to my
collection!!
(MIKA) Marc Champagne
marcch.AT.videotron.DOT.ca
Montreal, CANADA
"Theo Gottwald *" <The### [at] t-online de> wrote in
news:3d799119@news.povray.org:
> I'd really like to render them myself adding more
> halogen-lights around (more photons) - like in the Jewelers-shop.
I will post the code, but not right away! hang in there....
MIKA
Rob Hoopman <rob### [at] tuna nl> wrote in news:3d7a448a@news.povray.org:
> managed to google up some extra information:
> a 0 degree incident angle and nearly 100% at a 90 degree angle.
I Agree, I was unable to find any info on reflection properties and
assumed that such a dense and highly polished stone would have a lot
of relfection.
A quote from the works of Marcel Tolkowsky, 1919:
| In a diamond, the amount of light reflected from the surface is much
| smaller than that penetrating into the stone ; moreover, a diamond is
| practically perfectly transparent, so that all the light that passes
| into the stone has to pass out again. This is why lustre may be
| ignored in the working out of the correct shape for a diamond, and why
| any variation in the amount of light reflected from the exposed
| surface due to a change in that surface may be considered as
| negligible in the calculations
> had nothing to do with it.
> like the characteristic blue and yellow streaks (scintillation ?).
I also googled quite a bit and coperniced also (to learn the art
of diamond cutting).
I'm getting close to my goal and all input is appreciated, thanks.
I will post the code soon enough.
MIKA
<snip>
In that case:
http://www.gemology.ru/3dbook/eng/crypted/dif.html
seems like really detailed reflection data on diamonds, I wanted to use
this, but apart from the 17% value that could I took from the graph,
adjusting the exponent in an attempt to match this graph resulted in
worse results.
Another page with some info also refers to the 17% value:
http://www.christian-bernard.com/diamonds/brildef.htm
little tidbits about a number of optical properties of diamonds.
Rob
Rob Hoopman <rob### [at] tuna nl> wrote in news:3d7a4f93$1@news.povray.org:
> In that case:
> use this, but apart from the 17% value that could I took from the
> graph, adjusting the exponent in an attempt to match this graph
> resulted in worse results.
All taken into consideration, I had found everything (I believe) except
any mention of the reflection aspect of a diamond, this will surely help
a great deal.
Thanks
Montreal, CANADA
Just a thaught, try setting the stones in a more typical environment, such
as a light well lit jewlers shop window tray (if if your feeling patient,
throw in a little focal blur)
I was trying jemstones myself a while back, but never managed to get
anything good enough to post, but looking at yours again now, I think that
might have been because the items were out of context
PGP Public Key
Version: 6.0.385 / Virus Database: 217 - Release Date: 05/09/2002
Wonderfully done! Great.
The site Rob referred gives good data on the polarization effect of the
diamond.
I'll appreciate it how I could incorporate the parallel and perpendicular
polarization data for the POV-Ray raytracing.
Jong
"Marc Champagne" <nos### [at] please com> wrote in message
news:Xns### [at] 204 213 191 226...
> > In that case:
> a great deal.
> Thanks
> Montreal, CANADA
"Jong" <jjk### [at] mm ewha ac kr> wrote in news:3d7d3898$1@news.povray.org:
> the diamond.
> perpendicular
> Jong
I will surely have a closer look!
Montreal, CANADA
> the diamond.
> perpendicular polarization data for the POV-Ray raytracing.
The site was http://www.gemology.ru/3dbook/eng/crypted/dif.html
Jong, how did you interpret these graphs, I'm having a hard time making
sense of them, any clue?
Marc
