POV-Ray : Newsgroups : povray.binaries.images : gallery - gallery9_lowkb.jpg [0/1] Server Time
14 Apr 2026 02:31:09 EDT (-0400)
  gallery - gallery9_lowkb.jpg [0/1] (Message 31 to 34 of 34)
Subject: Re: gallery - gallery9_lowkb.jpg [1/1]
Date: 30 Mar 2001 13:36:25
Message: <MPG.152ef13160c648a59896aa@news.povray.org>
In article <3AC4CFC9.C901DE8F@inapg.inra.fr>, tra### [at] inapginrafr says...
> This could be the main culprit. I have found that a few (and even small)
> objects with ior used with radiosity could make a computer weep. I don't
> know about a whole pane...
If I just outcomment the "interior" part of the glass texture I get 1
PPS. But still with low quality radiosity...
If I disable the whole glass stuff -> ~12 PPS
with better quality its all 0 pps.
I fear there are simply too much slow things in this scene for radiosity.
Lutz-Peter
Date: 30 Mar 2001 14:23:08
Message: <3AC4DD18.3699943D@gmx.de>
Gilles Tran wrote:
> One at least, uploaded there on a temporary basis (others will come... someday
> http://www.oyonale.com/temp/classroom.jpg
Thanks, it looks quite realistic, the only thing i find a bit strange is
the missing bluish touch near the window, that would result from a blue
sky outside.  If you add a blue sky for getting that, this could strongly
influence the whole lighting situation, even more because of the increased
brightness.
Date: 30 Mar 2001 14:39:11
Message: <3AC4E0DE.6AB9CF83@gmx.de>
That comes near what i would expect, maybe try default radiosity settings
except recursion_limit 1, that would be faster than the values Gilles
suggested, but of course also lower quality.
'brightness' should not have any influence on speed BTW.
Furthermore you could try to optimize things, if the background mountains
are an isosurface, try a heightfield instead, if the water is an
isosurface, use only a normal statement.
And of course patience :-), 1 digit PPS rates or even 0 PPS are nothing
seldom when working with radiosity.
Date: 1 Apr 2001 09:14:57
Message: <3ac729d1$1@news.povray.org>
Yet another wonderful image, but does her left arm intersect with her chest?
Kev
http://perso.libertysurf.co.uk/kevin.ellis
