Ha! Hahaha! Muwahahahaha!!
Bow down before your master!
j/k
Comments/criticisms?
Anyone care to guess how it was done (it's a macro of course)?
David Fontaine <dav### [at] faricynet> ICQ 55354965
Download 'fttor.jpg' (50 KB)
Preview of image 'fttor.jpg'
That! is! magnificent! :-)
+47 90 62 71 78 DoD#2101, DoDRT#017, NIC#015, PJ#006, OGM#007
azo### [at] dodno, Ducati M600 Ubesudlet: Aldri eid en J&%#PS.
Looks like you're calculating fewer points along the torus and drawing the
squares in and not smoothing your triangles ; )
Josh
> j/k
> Please visit my website: http://www.faricy.net/~davidf/
> [Image]
eng### [at] spiritonecom
actually, It can't be that easy, but I bet you are rotating and translating
instead of using a parametric equation
> Josh
> > j/k
> > [Image]
> Josh English -- Lexiphanic Lethomaniac
> The POV-Ray Cyclopedia http://www.spiritone.com/~english/cyclopedia/
Cool.
If you make the cylinders a dull silverish color and put a bumpy normal
on the red parts it would look more like a stained glass structure.
...just a thought.
Phil
David Fontaine <dav### [at] faricynet> wrote in message
news:396B7E41.DD2AD7EF@faricy.net...
Cool! Now darken the scene; make the panels semi-transparent with a good
ior; add in some funky turbulated emitting media (like glowing gas) inside
the object; add in point lights with a good fade_distance and fade_power in
the center of each segment; and hover the beasty over some rippling water in
a large copper dish in the center of an open-skied altar place with
moonlight trailing down on the scene.
or.. Just leave it like it is. :{)
David
Yappari David-sama wa Kami-sama desu!
And so on, and so forth...
Nope, that is the deceptively easy way, but I want quadrilaterals, not triangles,
and they have to be coplanar of course...
Um, thanks, I guess :)
I took that from a Japanese cartoon, all I did was replace "Shougo" for
"David". I means "I knew that the great David was a god!" :-)
