POV-Ray : Newsgroups : povray.binaries.images : Would you like a drink? Server Time
26 May 2026 14:07:11 EDT (-0400)
  Would you like a drink? (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Would you like a drink?
Date: 11 Feb 2026 12:44:11
Message: <698cbfeb$1@news.povray.org>
Am 11.02.26 um 17:18 schrieb kurtz le pirate:
> On 11/02/2026 11:04, kurtz le pirate wrote:
>> Hello,
>> One or more suggestions for further improvement ?
> Yes, the texture/material of the cardboard is not right.
> Numerous attempts have been made, but none have been very satisfactory.
> I am open to suggestions on this matter.
Jaime Vives Piqueres gave some beer coasters in (archived only):
https://web.archive.org/web/20120621193854/http://www.ignorancia.org/uploads/zips/barrabar.zip
Other nice cardboard-objects can be found in:
http://www.povcomp.com/entries/85.php
Best regards
Michael
Date: 12 Feb 2026 12:25:00
Message: <web.698e0bd52768637587570eabd4644d08@news.povray.org>
kurtz le pirate <kur### [at] freefr> wrote:
> Hello,
This looks really good. I think adding a small rounded bevel to the top of the
liquid will give it a more realistic surface tension effect.
Date: 12 Feb 2026 21:05:02
Message: <698e86ce@news.povray.org>
Something I whipped up this evening.
---%<-----%<--[BEGIN CODE]--%<-----%<---
intersection
{ cylinder
  { 0, 0.2 * y, 4.1
    pigment { rgb <1, 0.9, 0.6> }
    normal { bumps 0.1 scale 0.3 }
  cylinder
  { -0.1 * y, 0.3 * y, 4
    pigment { rgb 0.6 }
    normal
    { crackle -0.5
      scale <1, 0.1, 1> * 0.5
--->%----->%---[END CODE]--->%----->%---
Download 'kurtz-coaster.jpg' (27 KB)
Preview of image 'kurtz-coaster.jpg'
Date: 16 Feb 2026 06:40:00
Message: <web.699301382768637516086ed06830a892@news.povray.org>
> > Hello,
> kurtz le pirate
> compagnie de la banquise
Awsome work on the model, composition and texture placement ! It looks
promissing.
You should separate the side and top parts of the glass supporting cardboard,
giving them different textures, just as a real cutout showing the darker
cardboard structure (probably some round form factored crackle (aka circcular
celled voronoi) on the side of the cylinder, but the lighter more grainy (rough
phong with large fade out) currently almost there should be reserved for the top
facing printed paper aspect. it do more justice to it by contrast. (if there was
one in POV (can't remember) you may turn that to Oren Nayar Blinn with max
roughness/sigma everywhere)
About the table, It's diffuse color value is somehow too high :it does not show
the lighting of the room / specular of the table come into play...
Finally some effects :
maybe some photons based caustics could happen if light came proportionally more
from a narrow focused spotlight.
As an ultimate final step, maybe the very minimal atmospheric media in the room
would add to this also as per Blender exporter default settings:
type 1 Isotropic 35 samples with a very dark diffusion color <0.001, 0.001,
0.001> absorption scale 0.00002
Date: 22 Feb 2026 09:46:26
Message: <699b16c2@news.povray.org>
Hi(gh)!
Am 11.02.26 um 12:50 schrieb Bald Eagle:
>> Hello,
> Use the keywords "open" and "hollow" so that I can reach into the screen and
> taste it?
Don't drink and code! Programmers run on caffeine, not alcohol...
See you in Khyberspace!
Yadgar
VBI BENE, IBI BACTRIA!
Date: 19 Apr 2026 11:50:01
Message: <69e4f9a9@news.povray.org>
> Hello,
A few improvements. I'm working on it little by little.
The surface of the liquid isn't flat anymore, but it doesn't make much
of a difference. A new texture for the desk.
kurtz le pirate
Download 'whisky_glass_menisque.png' (1762 KB)
Preview of image 'whisky_glass_menisque.png'
Date: 19 Apr 2026 14:16:48
Message: <69e51c10$1@news.povray.org>
Much better and natural now, I see the coaster is also improved.
YB
Date: 20 Apr 2026 10:55:00
Message: <web.69e63d342768637516086ed06830a892@news.povray.org>
> > Hello,
> kurtz le pirate
Yes this liquid is much more nuanced and appealing. The scale of the new wood
texture seems too small : it features screws that we would expect to also appear
in a normal bumb, plus not reveal to repeat as much if bigger.
For smoked oak wood, the following page shows low reflectivity but the
interaction with bitmap is hard to assign. Maybe start with a grey material to
get the shininess right...?
https://gustafs.com/knowledge-hub/surfaces/ligt-reflection-values/
Date: 22 Apr 2026 12:44:41
Message: <69e8faf9$1@news.povray.org>
Light reflectance... interesting topic.
The next step is to figure out how to implement this feature in POV-Ray.
kurtz le pirate
Date: 24 Apr 2026 07:35:00
Message: <web.69eb547d2768637516086ed06830a892@news.povray.org>
> kurtz le pirate
From what I understand it's already there when using albedo options. as they
prevent the various components to go above 1 in the final sum, so if you put
albedo on all components, and fresnel with conserve_energy for transparent, then
it's just a choice of shaping the proportion of your reflectivity between these
diffuse, and more specular/reflective components... adding them to amount just
up to your reflectivity value. BUT... :-D BUT... when using diffuse textures,
the value component of colors act as a multiplier of this... so you would have
to sample your image to know  average value of its relevant parts to get closer
to your desired result. Any more expert opinion if I'm mistaken in all of this?
