POV-Ray : Newsgroups : povray.binaries.images : Marching Squares on Irregular Grid Server Time
26 May 2026 12:47:10 EDT (-0400)
  Marching Squares on Irregular Grid (Message 1 to 1 of 1)
Subject: Marching Squares on Irregular Grid
Date: 23 Aug 2025 21:12:48
Message: <68aa6710$1@news.povray.org>
My attempts to get Wave Function Collapse to work on the irregular grid
didn't go so well. The wave function collapses the cells and removes all
possibilities. I either need backtracking or I need to figure out how to
overlap tiles.
So I tried marching squares instead. I have discovered my original tile
set is deficient so I need to add one more tile. However, I found a
configuration that lets me use this algorithm.
The idea is each point is given a calculated value, and each 4-sided
cell is then determined by the values of the four corners. With only two
choices for each point, I can calculate a value of 0 to 15 and map to
one of my tiles.
Here is a sample that avoids the gaps in my tileset.
Documentation and clean code one day, I promise.
Josh
Download 'marching_cubes_graph.png' (37 KB)
Preview of image 'marching_cubes_graph.png'
