POV-Ray : Newsgroups : povray.binaries.images : profile following a parametric curve Server Time
22 Nov 2026 06:34:47 EST (-0500)
  profile following a parametric curve (Message 1 to 12 of 12)
Subject: profile following a parametric curve
Date: 1 May 2025 06:22:42
Message: <68134b72@news.povray.org>
hello,
My first attempts.
Curves are defined with Cartesian parameters: x=f(t), z=g(t).
The profile is a simple polygon.
Basic texture, lighting with area_light.
Low resolution (800x600).
kurtz le pirate
compagnie de la banquise
Download 'param_limaconofpascal .png' (75 KB) Download 'param_hypotrochoidet.png' (173 KB) Download 'param_lemniscateofbernoulli.png' (86 KB)
Preview of image 'param_limaconofpascal .png'
Preview of image 'param_hypotrochoidet.png'
Preview of image 'param_lemniscateofbernoulli.png'
Subject: Re: profile following a parametric curve
Date: 1 May 2025 08:40:00
Message: <web.68136b97174259626563700825979125@news.povray.org>
Nice job with the profiles.
What's the arc-length of that lemniscate?   :D
- BE
Date: 1 May 2025 09:53:55
Message: <68137cf3@news.povray.org>
Simple. Here, half-width a = 24 = c√2.
                   2*π
Then, length = --------- * c
                M(1,1/√2)
With M(a,b) the arithmetic–geometric mean function.
kurtz le pirate
Date: 1 May 2025 10:34:16
Message: <68138668$1@news.povray.org>
On 5/1/25 06:22, kurtz le pirate wrote:
> My first attempts.
Cool!
Bill P.
Date: 1 May 2025 11:40:00
Message: <web.6813953c174259626563700825979125@news.povray.org>
>                    2*π
>                 M(1,1/√2)
Maybe not so simple?
https://en.wikipedia.org/wiki/Elliptic_function#History
(I only know that because I was trying to hunt down a good overview of
calculating the arc-length of a catenary, and move along the curve at regular
intervals.)
- BW
Date: 1 May 2025 12:01:32
Message: <68139adc$1@news.povray.org>
>>                     2*π
>>                  M(1,1/√2)
That's right.
But my answer is more of a joke and a simple copy/paste from Wiki
<https://en.wikipedia.org/wiki/Lemniscate_of_Bernoulli#Arc_length_and_elliptic_functions>
kurtz le pirate
Date: 1 May 2025 12:45:00
Message: <web.6813a418174259626563700825979125@news.povray.org>
> That's right.
Nice.  (I suspected)
"It therefore obviously follows that . . ."    ;)
- BW
Date: 2 May 2025 10:20:00
Message: <web.6814d401174259623d0038515cc1b6e@news.povray.org>
> hello,
> My first attempts.
> kurtz le pirate
Do you adjust the size of your profile object as you follow the curve, or does
it just have a very tiny thickness at each t step?  When I use this technique, I
struggle with getting the resulting object smooth if the curves are wide.
-- Chris R
Date: 2 May 2025 10:55:45
Message: <6814dcf1$1@news.povray.org>
> -- Chris R
Hello Chris.
In fact, my profile has no thickness !
The profile is only defined by points in an a array and doesn't really
exist.
For example, the profile for a triangle is defined like this:
#declare i = 0;
#while ( i < NumberOfVertices)
   #declare ShapePoints[i] = RotateX(<0, ShapeRadius, 0>, Angle*i);
   #declare i = i +1;
The shape is in the y-z plane.
I position the first profile for t=0;
Then I calculate the position for the second (t=t+epsilon) and build
triangles* that connect the two profiles.
* : using the true POV object : triangle { p0, p1, p2 }
kurtz le pirate
Download 'parametrique_limacon de pascal _connect_prof0.png' (124 KB)
Preview of image 'parametrique_limacon de pascal _connect_prof0.png'
Date: 3 May 2025 11:18:56
Message: <681633e0@news.povray.org>
A little more artistic, but this time using a curve defined by a polar
equation.
Profile : hexagon.
kurtz le pirate
Download 'polaire_trefle_connect_0.png' (264 KB)
Preview of image 'polaire_trefle_connect_0.png'
Date: 5 May 2025 09:35:00
Message: <web.6818bddb174259623a6dfc485cc1b6e@news.povray.org>
> > -- Chris R
> Hello Chris.
> exist.
> #declare i = 0;
>    #declare i = i +1;
> #end
> kurtz le pirate
Thanks for the explanation.  My brain is so focused on isosurfaces and
extrusions that I didn't even think of using triangles or a mesh.
-- Chris R
Date: 7 May 2025 04:42:42
Message: <681b1d02$1@news.povray.org>
more explanations on my website ;)
kurtz le pirate
