Hello,
Another Matmod example: “Mesh Torus”.
Not easy to transcode. I've had quite a few difficulties.
The description refers to POV :
"Mesh Torus ( reference : http://www.povray.org/ ) by Abderrahman Taha
02/11/2019". I couldn't find the link :)
Fast rendering.
max_gradient calculated by POV is really small: 0.62.
kurtz le pirate
compagnie de la banquise
Download 'meshtorus.png' (421 KB)
Preview of image 'meshtorus.png'
hi,
kurtz le pirate <kur### [at] free fr> wrote:
> Hello,
and I can't stop looking at it. thanks. [insert superlatives here] :-). since
you, with the "maths" and all did find it difficult to achieve, there'd be .. no
hope for me, anyway, so, would you consider making the code/object public ?
regards, jr.
On 26/12/2024 17:58, jr wrote:
> hi,
The code ? Yes, of course !
The source is attached to this post.
Have fun ;)
kurtz le pirate
Download 'prettyball_3.pov.zip' (3 KB)
hi,
merci beaucoup, much obliged.
> Have fun ;)
looks like the weekend has been taken care of.. ;-)
regards, jr.
> > hi,
> Have fun ;)
> kurtz le pirate
I'd be interested to know what the "p" parameter was intended to be used for? I
looked through the code and it gets passed everywhere as an argument, but is
never used in the body of any of the function definitions.
-- Chris R
> Fast rendering.
That is spectacular and beautiful. And with a max_gradient of only 0.62?? Wow.
> > [from jr:]
> The source is attached to this post. [Prettyball_3]
Your Prettyball_3 code produces a different result than your "Mesh Torus"
image-- although this example is quite beautiful as well! Did you mean to post
the Mesh Torus code instead? Like jr, I would love to see how you created it.
Download 'prettyball_3_by_kurtz__kw.jpg' (27 KB)
Preview of image 'prettyball_3_by_kurtz__kw.jpg'
>> Fast rendering.
>>> [from jr:]
_ ____ _ _
| | / __ \| | | |
| |___| |__| | |____ |_|
|______\____/|______| (_)
I made a mistake and uploaded the wrong file.
I now put the code for "MeshTorus".
This makes two samples.
Sorry...
kurtz le pirate
Download 'meshtorus.pov.zip' (3 KB)
hi,
> >> Fast rendering.
> >>> [from jr:]
> _ ____ _ _
> | | / __ \| | | |
hey, thanks KW & KlP for saving the weekend :-).
regards, jr.
Good observation Chris.
The 'p' parameter corresponds to the 't' parameter in Mathmod. It can be
used for animations and, in some cases, directly for isosurfaces.
For exemple in 'Holed Spheres', the 'ThickIso' function use this fourth
parameter : "ThickIso=max(Iso2(x,y,z,1), Iso2(x,y,z,-1))".
To keep my questions to a minimum, I've chosen to always use all 4
parameters, even if they're not all used, and then I want to test the
animations, so that's all ready.
kurtz le pirate
> > hi,
> Have fun ;)
I've now modified this file so that it runs a bit faster.
See the attached SDL file.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Download 'prettyball_1_at_klp_tok.pov.txt' (4 KB)
> > > hi,
> > Have fun ;)
Here it is again. This time with Kurtz name spelled correctly. Sorry about that.
There's also some other minor changes.
Tor Olav
http://subcube.com
hi,
> > > Have fun ;)
thanks, will you post code for the "candy-stripe" version too ? tia.
regards, jr.
> _ ____ _ _
> | | / __ \| | | |
Attached is my rewritten version.
Tor Olav
http://subcube.com
Download 'meshtorus_at_klp_tok.pov.txt' (6 KB)
"jr" <cre### [at] gmail com> wrote:
> hi,
> > > > Have fun ;)
See my recent post to povray.binaries.scene-files.
Tor Olav
http://subcube.com
A bit ?
Indeed, it's three times faster. Really impressive.
Bravo
kurtz le pirate
Also three times faster.
But, why this declaration : #declare tau = 2*pi; ?
kurtz le pirate
hi,
> A bit ?
looking at the 'prettyball' image, the object's three "components", has me
wonder (naively) if that is a 3D version of the "triply periodic minimal
surface" patterns that Bald Eagle played with some months ago. is the
prettyball "related" ?
again, thank you, both.
regards, jr.
I noticed that too. It is probably there for v3.7 users; the 3.8 betas now have
a built-in 'tau' keyword.
Yes, that's why. I'm still at v3.7.
Tor Olav
http://subcube.com
