POV-Ray : Newsgroups : povray.binaries.images : Floating - WIP Server Time
19 Mar 2026 12:38:39 EDT (-0400)
  Floating - WIP (Message 5 to 14 of 25)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Floating - WIP
Date: 15 Apr 2024 13:05:00
Message: <web.661d5ddc239499c91dbe6626f712fc00@news.povray.org>
"RATH, CHRISTOPHER A" <car### [at] comcastnet> wrote:
> This is a work-in-progress inspired by a photo I took of my grandson
> chasing soap bubbles in his yard.  As usual, it was supposed to be a
> brief doodle, but has morphed beyond that.  I have started adding other
> things that "float" in various ways to model in the scene as well.
> -- Chris R
I like the way you play. Why not use Iridescence on the soap bubbles?
That is what it was made for.
Have Fun!
Date: 15 Apr 2024 15:31:08
Message: <661d807c$1@news.povray.org>
> Are those floating objects intended to be bubbles?  They look like solid water
> droplets.  Hollow bubbles do not invert the scene behind them.
> The cracks in the pink granite blocks are conspicuously regular, but I'm sure
> you already have plans for those.
I fixed the issue with the bubbles.  The objects were defined to allow
for a variable wall thickness between 0.33 and 2 microns.  In my
experiments the test bubbles were all 1 micron or more thick and they
always looked right.  However, when I used a value < 1, I was running
into the floating point range problem that was giving very weird results.
So, I changed the thickness range so no bubble is ever less than 1
micron thick and now they look much better.
I'm playing with the fountain crack and the balloon texture now and will
post an update later.
-- Chris R
Date: 15 Apr 2024 22:51:06
Message: <661de79a$1@news.povray.org>
On 4/15/24 15:31, RATH, CHRISTOPHER A wrote:
> However, when I used a value < 1, I was running into the floating point
Moving to a smaller isosurface accuracy setting(a) might well help too,
if you've not already tried it.
Bill P.
(a) - As a rough rule, accuracy values of 1e-5 / 1e=6 are about the best
we can actually achieve with isosurfaces.
Date: 16 Apr 2024 06:35:00
Message: <web.661e53dd239499c91f9dae3025979125@news.povray.org>
This is looking great - I think what you need for the balloon is
transparency/filter, double_illumination, and SSLT.
How did you make that cracked brick?   It looks awesome!
Date: 16 Apr 2024 08:19:32
Message: <661e6cd4$1@news.povray.org>
More like back side illumination + radiosity with recursion_level 3 or
4. That would simulate the thin walls of a balloon way better than SSLT.
Yes, add a small amount of filter.
pigment{Yellow filter 0.1}//maybe even less
Date: 16 Apr 2024 09:35:59
Message: <661e7ebf$1@news.povray.org>
>> -- Chris R
> Have Fun!
The bubbles do have iridescence; the bug in the shape is probably making
it too hard to see.  I will probably put a few bubbles closer to the
camera so you can see it better in the final image.
-- Chris R
Date: 16 Apr 2024 09:40:00
Message: <661e7fb0$1@news.povray.org>
> Bill P.
I'm actually using 1e-7, which seems to make a difference from 1e-6.
I'm not getting any artifacts at 1e-7, but there are a few on the front
of bubbles at 1e-6.
-- Chris R
Date: 16 Apr 2024 09:45:29
Message: <661e80f9$1@news.povray.org>
I'm playing with a bunch of suggestions for the balloon.  Currently the
texture is:
     #local _p1  = pigment { color rgbf <0.6, 0.6, 0.005, 0.7> }
     #local _p2  = pigment { color rgbf <0.6, 0.6, 0.005, 0.6> }
         material {
                     bozo
                     pigment_map {
                         [0.0 _p1]
                         [0.5 _p1]
                         [0.8 _p2]
                         [1.0 _p2]
                     warp { turbulence 0.9 }
                     scale 2
                 //normal { bumps 0.01 scale 0.01 }
                 finish {
                     fresnel 0.4
                     specular albedo 1.0
                     roughness 0.005
                     diffuse albedo 1.0
                     reflection { 0.4 }
             interior { ior 1.5 }
I'm working out how to get a more realistic reflection and will look at
the suggestions provided here.  I haven't tried rendering this with
radiosity yet.
-- Chris R
Date: 16 Apr 2024 09:48:04
Message: <661e8194$1@news.povray.org>
As for the brick, (which is changing slightly in the updated version), I
do almost everything with isosurfaces.  The bricks are just slices of a
cylindrical tube, and I subtract out a pigment function based on the
marble pattern.  In the first version, each block had its own random
cracked marble pattern applied to it.  In the new one, there is a global
crack pattern that gets applied to the foundation and each block so
there is consistency with the way the fountain is cracking.
-- Chris R
Date: 17 Apr 2024 08:29:19
Message: <661fc09f@news.povray.org>
>>> -- Chris R
>> Have Fun!
This is a ways from being done, but I wanted to share the updated image
with the bubbles fixed.  The balloon texture is still not quite right,
even when I render with radiosity (which this version does not).
-- Chris R
Download 'scene.png' (3793 KB)
Preview of image 'scene.png'
