POV-Ray : Newsgroups : povray.binaries.images : billboard tint Server Time
27 Jul 2024 08:06:00 EDT (-0400)
  billboard tint (Message 1 to 10 of 21)
Subject: billboard tint
Date: 3 Nov 2023 12:55:00
Message: <web.654524992e6f6abcf22cdb33dabc9342@news.povray.org>
After taking some time off from POV, I'm ready to tackle a few new scenes I have
in mind. One involves a landscape with some foreground vegetation. I started
collecting some 2D sprite images of moss, grasses, and weeds thinking that I
could populate the ground with them. I've run into a problem with the
transparent portion of the png when turning on fog. The fog is tinting the
billboard shape. I've removed the finish and have tried a variety of things in
the shader with no success. I can fall back on 3D models if I can't get the
sprites to work.  Below is what I used to texture this example. I understand
that the bump statement will not have much of an effect without a finish. Any
help would be appreciated.
Thanks,
Mike.
#declare imgDiffuse = "plants/grass_A.png"
#declare imgBump    = "plants/grass_A.png"
#declare M_grass_A =
material {
            image_map {
                png imgDiffuse premultiplied 0 gamma 2.2
                map_type 0
                interpolate 4
    normal  {
        bump_map {
            png imgBump premultiplied 0 gamma 2.2
            map_type 0
            interpolate 4
        bump_size 5
    finish {
        phong 0
        phong_size 0
        ambient 0
    scale <1,1,1>
    translate <-.5,0,0>
#declare sprite = box {<-.5,0,-.01>,<.5,1,.01> } ;
object { sprite material {M_grass_A} scale <30,40,1> translate <0,-1,0>}
Download 'plant_sprite_fog_problem.jpg' (252 KB)
Preview of image 'plant_sprite_fog_problem.jpg'
Subject: Re: billboard tint
Date: 3 Nov 2023 14:57:13
Message: <65454289$1@news.povray.org>
> billboard shape.
The fog feature is a faked effect which works, solely, with initial
camera rays. More specifically fog is added using the distance from the
camera to the first intersection - or effective infinity (2,000,000
units?). Those initial camera rays will intersect the billboards whether
the pigment is transparent or not.
So, I'm not surprised the bill board tint is different, but at this
moment, I don't understand why it appears to be more foggy rather than
less. Most probably your fog is set up to be more dense at distance (not
ground fog)?
Maybe we'd get what you see, if using ground fog that is not oriented
correctly? Not sure. Could be some bug too - there are some in the
official POV-Ray code - and probably some unknown ones still in my
playpen code too. Faked effects are tricky.
In any case, distance based features will struggle with a "billboards
technique".
Bill P.
Date: 3 Nov 2023 16:45:00
Message: <web.65455b99310e11ef22cdb33dabc9342@news.povray.org>
> > billboard shape.
> ground fog)?
> technique".
> Bill P.
Thanks Bill,
I'll mess around with it a bit more before giving up. I'll let you know if I
find a solution before using triangle mesh for these plants. :)
Best regards,
Mike.
Date: 3 Nov 2023 17:19:21
Message: <654563d9$1@news.povray.org>
> Thanks,
> Mike.
> material {
>      texture {
>         pigment {
>              image_map {
>                  map_type 0
>                  interpolate 4
>      normal  {
>          bump_map {
>              map_type 0
>              interpolate 4
>          bump_size 5
>      finish {
>          phong 0
>          phong_size 0
>          ambient 0
>      scale <1,1,1>
>      translate <-.5,0,0>
The fog is more visible between the billboards because there is less of
it. It's evaluation stops at the billboard.
You may try adding hollow to those. Not sure that it'll work with fog in
this case, but it can make a huge difference with media.
Adding hollow MAY allow the evaluation of the fog behind the billboards.
But, then, the fog could become more intense in those areas. Hard to tell.
Try
#declare sprite = box {<-.5,0,-.01>,<.5,1,.01> hollow} ;
or
<0,-1,0>hollow}
Date: 3 Nov 2023 17:45:52
Message: <65456a10$1@news.povray.org>
Alain just mentioned media -and his opening comment makes me think I'm
assuming the billboards position incorrectly...
With media - where we almost always use contained media these days - we
sometimes forget we can still implement global media.
It might be worth a try in your case. As long as the billboards have
enough depth POV-Ray can track whether inside or outside the billboards,
but not a depth appreciable enough(a) to greatly affect the media
results - I think it might work.
(a) Try to stick with more perpendicular billboards with respect to the
initial camera rays.
You'll need a complete scene backstop shape at "media fog" end effect
distance. In other words, you cannot have only 'background' or a
'skysphere', global media needs rays which eventually terminate
somewhere with a final intersection.
Bill P.
Date: 3 Nov 2023 18:20:00
Message: <web.65457017310e11ef22cdb33dabc9342@news.povray.org>
> > Thanks,
> > Mike.
> > material {
> >      texture {
> >         pigment {
> >              image_map {
> >                  map_type 0
> >                  interpolate 4
> >      normal  {
> >          bump_map {
> >              map_type 0
> >              interpolate 4
> >          bump_size 5
> >      finish {
> >          phong 0
> >          phong_size 0
> >          ambient 0
> >      scale <1,1,1>
> >      translate <-.5,0,0>
> Try
> or
> <0,-1,0>hollow}
Thanks Alain - I gave that a shot. It didn't seem to work.
Date: 3 Nov 2023 18:25:00
Message: <web.65457245310e11e1f9dae3025979125@news.povray.org>
"Mike Miller" <mil### [at] gmailcom> wrote:
> I've run into a problem with the transparent portion of the png when turning on fog.
https://wiki.povray.org/content/Reference:Fog
I think that you're going to have a hard time with the fog since it's purely
distance based.
Also, there's no really good way to make a "cutout" from the transparent image.
You could do a few things.
Try and make a custom prism from the image with a macro.
Make a heightfield from the sprite and difference away a box, leaving just the
visible portion.
fake the fog using a large upward-curving surface toward the rear of the scene
and pigmented using a distance-based function.
Try a thin wedge with a white pigment and slight filter value that gets higher
toward the rear.  The filter may mimic the fog/media effect and be cheaper.
If you need to speckle it like real media, maybe use a noise pattern to make a
texture with white / clear.
Do a 2-pass render with the plants billboarded over the fogged scene afterward.
That's all I got for now.
- BW
Date: 3 Nov 2023 18:30:00
Message: <web.6545736a310e11ef22cdb33dabc9342@news.povray.org>
> Bill P.
Thanks Bill,
my scene is enclosed/surrounded with a mapped sphere object. I did try Alain's
idea....same results. I added depth to the billboards but it renders both front
and back resulting in a double image. Is there backface culling in POV? ...don't
see it in the help files. I'll try a clipped plane just to test.
Mike.
Date: 3 Nov 2023 18:57:16
Message: <65457acc$1@news.povray.org>
There is interior_texture{}.
I think you could make the normal texture{} completely transparent and
the interior_texture{} your image map. It should be the first
intersection on the billboard uses the exterior texture{} and the second
interior_texture{}.
Aside: By default texture{} gets used for the interior texture of shapes
too - if you only specify a texture{}.
Bill P.
Date: 3 Nov 2023 19:45:00
Message: <web.654585b5310e11ef22cdb33dabc9342@news.povray.org>
> interior_texture{}.
> Bill P.
I'll give that a shot...keep you posted. Mike
