POV-Ray : Newsgroups : povray.binaries.images : A povr fork test image for new dens_object pattern. Server Time
18 Oct 2025 14:10:41 EDT (-0400)
  A povr fork test image for new dens_object pattern. (Message 1 to 10 of 11)
Subject: A povr fork test image for new dens_object pattern.
Date: 2 Sep 2023 10:37:00
Message: <64f3488c$1@news.povray.org>
Attached an image from one of the dens_object pattern tests. Suppose
X-ray vision - or something.
Bill P.
Download 'dens_object_01.png' (116 KB)
Preview of image 'dens_object_01.png'
Subject: Re: A povr fork test image for new dens_object pattern.
Date: 3 Sep 2023 15:55:00
Message: <web.64f4e461b1d4735c16bed5696e741498@news.povray.org>
> Bill P.
That's a very nice and smooth result. I haven't been following, but how does it
work? And have you tried using as a surface normal, to fake rounded edges?
Sam
Date: 3 Sep 2023 21:49:54
Message: <64f537c2$1@news.povray.org>
>> Bill P.
> Sam
Hi Sam,
Thanks. The core bit of POV-Ray (povr) code for the image is:
#declare ColorMap = color_map {
     [  -1 Orange ]
     [   0 ClearBlack100 ]
     [ 0.6 Yellow ]
     [   1 Yellow ]
#declare TextR = text {
     ttf "timrom.ttf" "R"
     0.1, 0
     translate <0,0,-0.05>
#declare PigListObj = pigment {
     dens_object {
         TextR
         exponent 1.2
         radius 0.044
         recursion_limit 12
         samples 44
     function_interval
     color_map { ColorMap }
The dens_object pattern does a series of spherical inside tests starting
at the radius and shrinking on each 'recursion' (actually a loop as
implemented, but the keyword matches another pattern called
hard_object{} where recursion is used.) The center of the spherical
tests is at each ray-surface intersection. Sum up all the tests inside,
divide by the number of tests and return a value in the -1 to 1 range;
flat parts come out around 0.0. The aim of this pattern is as a
'proximity' pattern stand in.
I had the thought to do another render where I use an inside cyan
pigment to make it clearer which 'edges' are inside, but suppose
something for another day.
As for using the pattern to perturb raw normals to make things look more
rounded(a). I'd not thought about it, but I will. I've played quite a
bit with perturbed normal methods in the povr fork. My guess is
something based on the surface density measure could work OK for the
'far side' edges, but might be problematic where the edge faces the
incoming rays. There would likely be a visible discontinuity in that
case. That said, I'll think about it. It's an interesting idea(b).
(a) - There is in the povr fork 'soft_object' which can be used to
create an actual rounded isosurface, but with results that are often a
little lumpy - often looking like one of your recent ray marching images.
(b) - In part because the density measured can be other than the shape /
  surface where the normals are being perturbed. In other words, it
might be possible to use unseen shapes as normal perturbation magnets -
thinking aloud.
Bill P.
Date: 3 Sep 2023 22:21:08
Message: <64f53f14$1@news.povray.org>
And on hitting send, I thought, why not just try Sam's idea...
Attached is an image where I turned the pigment plain white - this the
image on the left. I then used the existing dens_object set up as a
normal{} block value pattern. This the image in the middle - the
polarity of the -1..1 function interval is wrong. Well povr has an
'inverse' scalar value pattern wave modifier. Added it and we get the
image on the right - and, dang Sam, that looks pretty good as a quick go
at it! :-) Thanks for the idea!
Bill P.
Download 'samsnormalidea.jpg' (27 KB)
Preview of image 'samsnormalidea.jpg'
Date: 5 Sep 2023 19:05:00
Message: <web.64f7b2dfb1d4735c16bed5696e741498@news.povray.org>
> The dens_object pattern does a series of spherical inside tests [...+a more
elaborate explanation...]
I think I get the gist of it, but not the specifics. Are the parsing & rendering
times ok? (It always seems like solutions for this are weighty one way or
another.)
This povr fork sounds interesting. Does it allow an object's normal to be
completely overridden?
I've been thinking about making a fork of my own. It's probably a lot of work
and frustration just to get it to compile, but I might have to try anyway.
> Bill P.
That result is... really good! Have you tried it with specular highlights or
reflection? It's hard to see the absolute quality here, but I'd say the
experiment was a success for sure!
Sam
Date: 6 Sep 2023 12:24:23
Message: <64f8a7b7$1@news.povray.org>
On 9/5/23 18:59, Samuel B. wrote:
> Parsing and render times.
Of course quite a bit longer with dens_object. No getting around there
being a lot more work getting done. Let's see. A render of just the R -
no normal{} at all on my old 2 core i3:
   1.50user 0.03system 0:01.26elapsed
and with a dens_object normal 'similar' to that posted prior.
   69.96user 0.11system 0:18.82elapsed
using both times the command line:
   povr dens_object_02.pov +w800 +h600 +a0.05 +am2 +r3 +j3.33
to > be completely overridden?
Only a little more so than the usual POV-Ray at this point. As we
increase the normal{} block bump_size beyond 0.5 we already start to,
for example, invert normals. The larger that bump_size the more the
perturbation influence becomes the total perturbed normal. This 'take
over' usually at the cost of some distortion to the intended result.
In povr, I've played some with chained normal perturbations which
replace the raw normal with more perturbations due the chaining.
I have not, though, thought about selectively replacing raw normals
completely with some other entirely. This would be hard to do in general
(with a switch say) but say maybe if using other shapes to paint in
replacements always from the outside / inside we could make the
replacement orderly... I'll think about it.
It's work - and sometimes frustrating for sure - but you can also try
what you want. To some degree you get to use what you want from other
forks too.
> Have you tried it with specular highlights or reflection?
I've not played with finishes yet.
I did spec a little time with the accuracy(a) setting which has some
effect. The 0.02 accuracy default shown in the earlier posting is as
much blunting corners (except for the opposing seams - which stick
around) as rounding them when looked at on closer renders. A smaller
accuracy setting looks more rounded,  but pretty quickly also better
shows additional discontinuities in the normals.
(a) - I have some long standing concerns with this keyword's
implementation with respect to bias and an internal 'magic factor' there
in the code, but not described. I dislike 'magic' code because it almost
always disconnects users from any intuitive feel for what setting would
be best. Anyhow, I might use dens_object based normals to play with that
accuracy code some... We'll see.
Bill P.
Date: 6 Sep 2023 19:35:00
Message: <web.64f90b85b1d4735c16bed5696e741498@news.povray.org>
I don't know what any of that means :( Are you using Linux or something? I'm
guessing those values are in seconds? And that the object with a normal took a
bit over 1 minute? (POV-Ray has always showed me things in terms of seconds,
minutes, hours, PPS etc.)
> > to be completely overridden?
Ah. I think that the only thing the official versions can do to override a
normal atm is to use one of the facets patterns.
It would be nice to completely change normals. We could do things like make
actual normal maps, or in this case, make shaders for rounded edges. At this
point, I can make a function of averaged object patterns and then derive a
normal from it, but I can't take that normal value and use it as an actual
normal :/ I can only adjust the original surface normal with a single density
value. I don't know what future versions of the SDL would look like, but I hope
it supports more direct access to shading without decreasing the easy usability
of today's syntax.
> forks too.
Yeah, I've been wanting to play with clipka's reflection blurring to force it to
allow, for instance, only one sample. That way samples could be multipled via
focal blur and/or aa without reaching ridiculous render times. It would help get
the renderer more in line with something like Blender's Cycles.
> I did spec a little time with the accuracy(a) [...]
> Bill P.
I always interpreted 'accuracy' as a sort of radius. I don't know if the values
match of with actual units, but I keep it low for sharp things, and higher for
when I need a smoother look.
Sam
Date: 7 Sep 2023 06:15:43
Message: <64f9a2cf$1@news.povray.org>
> I don't know what any of that means 🙁 Are you using Linux or something? I'm
Yes, Ubuntu and I trust the unix/linux timers over POV-Ray's internal
measures because they wrap POV-Ray's processes / sub-processes.
The elapsed time is likely the practical user measure. It's how long
someone waits for the render to finish. So, 1.5 seconds became 19
seconds on my i3.
Multi-cores, multi-threads, variable clock rates - now high power and
low power cores. There are too configure and compile options, differing
compilers etc too. Other load on the machine...
What the reported times mean these days is a good deal harder to really
understand than it used to be.
... and facets ... I've never spent time with that normal{} block
modifier or the code. In a quick look at the code it does look like
there is a mode for complete replacement in addition to one which
perturbs. Thanks.
Aside: The povr fork has a normal{micro} perturbation method which
really only works as a final results with AA. This sounds a little like
what the clipka code experiment you'd like to do.
Shading... This something about which I don't know very much. I know
there are shaders available in GPU hardware which can fake effects and
do certain limited programming like stuff, but that's about it.
As for mapping to arbitrary shapes - a tough problem. Probably easier to
create a mesh and work with that. Aside: I've played a little with df3
environments into which arbitrary shapes can be placed for pigment /
normal mapping of a sort. However, that approach has the non-trivial,
practical issue of very large df3 sizes accompanying those now mapped /
painted shapes.
Bill P.
Date: 7 Sep 2023 18:35:00
Message: <web.64fa4fc2b1d4735c16bed5696e741498@news.povray.org>
Ah, ok. I was starting to wonder if there was a setting I missed.
I'll have to switch over to some flavor of Linux one of these days, since
Microsoft is progressively making Windows worse in every way. (Bloat is probably
the biggest issue. I suspect Windows uses too many resources... Currently, 44%
of my 8GB of memory is being used, and I only have Firefox open! For some
reason, several Edge instances are running, plus a bunch of other things. It's
crazy.)
Ah, so is it like crand, but for normals? That would probably be perfect,
especially if samples multiply with focal blur.
I was referring to shading in the general sense, as in what POV-Ray does under
the hood. Being an end user, I only get to change options exposed/implemented by
the SDL.
Ideally, I think a future version could benefit from being more like Blender's
Cycles, where you get near absolute control over diffuse, glossy reflections,
emission, subsurface scatting, etc. (Blender uses nodes for this, so it would be
different in POV-Ray.) Each such feature could receive value and pattern inputs,
while still being simple to use when you don't want to go overboard. In POV, we
can already do a lot with texture_maps but they tend to be slower to render,
even for simple things like having the specular roughness change using a
pattern.
Yeah, real shapes are always better overall.
> Aside: I've played a little with df3 environments into which arbitrary
> shapes can be placed for pigment / normal mapping of a sort. However,
> that approach has the non-trivial, practical issue of very large df3
> sizes accompanying those now mapped / painted shapes.
> Bill P.
There is a way to 'grow' signed distance functions (SDFs), and then render them
at resolutions higher than the initial array size. In cases where you're making
arbitrary shapes (like if you had a 3D voxel painter or such), the result might
look bumpy (like packed spheres) near the resolution size. But in cases where
you know the shapes you want, it can be very precise.
I can't really explain it better at this time, but if your system supports
hardware shaders, check out these 2D examples:
https://www.shadertoy.com/view/4sK3WK
https://www.shadertoy.com/view/MdGGWt
It's probably not ideal for most things.
Sam
Date: 8 Sep 2023 10:48:28
Message: <64fb343c$1@news.povray.org>
> crazy.)
I don't know that switching would help.  While Microsoft does eat disk
space like candy, and I'm never one to discourage people from ditching
Windows, my GNU/Linux system shows 393 processes open.  Only a few dozen
at most are windows that I have open.  And Firefox is easily the
greediest app on my system.
Starting a fresh session shows 365 processes and 1.3 GiB memory used,
before I even open any apps.  Bloat just seems to be an inherent
property of most 21st century software.
But yeah, Edge does have a habit of popping up out of nowhere on Windows
systems.
