POV-Ray : Newsgroups : povray.binaries.images : Creating internal image_map from function. Server Time
19 Oct 2025 09:35:24 EDT (-0400)
  Creating internal image_map from function. (Message 1 to 4 of 4)
Subject: Creating internal image_map from function.
Date: 16 Feb 2023 08:48:10
Message: <63ee341a$1@news.povray.org>
Given the recent discussions on creating height_fields from functions, I
thought I'd mention a documented feature of POV-Ray I've not seen
discussed on these newsgroup fora - that I recall.
It's possible to create an internal image_map from a function on the fly
in SDL. The syntax is similar to defining a height_field (HF) with a
function on the fly. The function (or pattern via a function) runs only
during parsing. The rendering phase then references the internal
image_map.
For example:
#declare Fn02 = function {
     pattern {
         radial sine_wave frequency 16
         translate (x+z)*0.5
         rotate x*-90
#macro ImageMap01(_HF)
   #if (_HF=0)
     image_map { function 40, 40 { Fn02(x,y,z) }
   #else
   #if (_HF=0)
       map_type 0
       once
     //interpolate 2
     warp { repeat x flip x }
     warp { repeat y flip y }
#declare Pigment01 = pigment { ImageMap01(0) }
#declare Texture01 = texture { pigment { Pigment01 } }
#declare Box01 = box { 0,<2,2,0.1> }
#declare Obj01 = object {
     Box01
     texture { Texture01 }
     translate <-1.0,-1.0,0>
Bill P.
Download 'fntointernalimage.jpg' (71 KB)
Preview of image 'fntointernalimage.jpg'
Subject: Re: Creating internal image_map from function.
Date: 16 Feb 2023 09:03:20
Message: <63ee37a8$1@news.povray.org>
Op 16-2-2023 om 14:48 schreef William F Pokorny:
> during parsing. The rendering phase then references the internal image_map.
Ah! That is nice indeed. I am currently playing with all this stuff
since my revisiting in December 2022 of the JtaUR (Journey to an Unknown
Region) and I can most probably integrate it. Thanks! Shall be back later.
Date: 16 Feb 2023 09:10:00
Message: <web.63ee3845f57ad3c2ca9e57c410800fb2@news.povray.org>
> in SDL.
It works, thanks, so many possibility in POV !
It seams to me that this feature will be good for function's graph
representation, as it's possible to use original function as path of function
for colormap.
I will play with it this evening.
YB
Date: 16 Feb 2023 13:20:00
Message: <web.63ee7386f57ad3c21f9dae3025979125@news.povray.org>
I think I asked clipka about it once, but I never got around to doing much with
it, and I can't recall seeing anything that jumped out in the documentation.
Thanks for the code/syntax example.    Those are always most helpful.
- BW
