POV-Ray : Newsgroups : povray.binaries.images : The Shallows II (2/3) Server Time
27 May 2026 21:10:56 EDT (-0400)
  The Shallows II (2/3) (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: The Shallows II (2/3)
Date: 23 Nov 2022 07:40:23
Message: <637e14b7$1@news.povray.org>
Op 22-11-2022 om 19:43 schreef ingo:
> "Mr" <m******r******at_hotmail_dot_fr> wrote:
>> Do you think such a result could be achieved using HG POV displacement or
>> isosurface displacement macros? If yes an include like you did for Granite would
>> really be worth it, and if not, maybe a tutorial ?
> It can probably be done with the meshmaker.inc that comes with POV-Ray.
Ah! That is an excellent suggestion indeed. Something I shall have to
play with... sometime...
Date: 24 Nov 2022 11:13:52
Message: <637f9840@news.povray.org>
For those using POV-Ray 3.7, be aware that there is a bug in
meshmaker.inc v3.7: It will set your scene to #version 3.5, no matter
what you put at the top of your scene file.
This bug is fixed in v3.8 and in unofficial patches based on v3.7.1, and
the file should work if you copy it to your v3.7 include folder.
Date: 25 Nov 2022 04:23:38
Message: <6380899a$1@news.povray.org>
Op 24-11-2022 om 17:13 schreef Cousin Ricky:
Thank you indeed for this reminder! Personally, I almost always version
3.8, but sometimes 3.7 also. I now copied the corrected version of
meshmaker.inc from 3.8 to 3.7.
Date: 3 Dec 2022 16:50:00
Message: <web.638bc4259d632bff7f4378dc6a8f0b95@news.povray.org>
> Time to reveal "The Shallows II", the next instalment of the triptych.
> I have been asked about a background story for the triptych, but I
> prefer to leave that to the imagination of the beholder :-)
> Total cumulated render time was about 39 hours on a i5 laptop.
> Thomas
Hi Thomas,
This is even better than the first image, not really anything to critique. I
especially love the texture/worn paint on the boat, great work.
Looking forwards to the next image.
Sean
Date: 4 Dec 2022 11:35:17
Message: <638ccc45$1@news.povray.org>
Op 3-12-2022 om 22:48 schreef s.day:
> Sean
Thank you indeed Sean!
the (exterior) mesh2 boat texture is constructed as follows:
//source of the image maps:
//https://www.arroway-textures.ch/products/boards-004/?texture-tags=&texture-filter=
//Map definitions
#declare p_map1=pigment {image_map{jpeg
"OldRowingBoat_boards-004_d100.jpg" gamma srgb interpolate 2 transmit
all 0 } }
#declare p_map2=normal {bump_map{jpeg
"OldRowingBoat_boards-004_b030.jpg" gamma 1.0 interpolate 2 }}
#declare p_map3=pigment {image_map{jpeg
"OldRowingBoat_boards-004_s050-g050.jpg" gamma 1.0 interpolate 2 }}
//Poseray macro:
#macro pigment_multiply(p1,p2)
//multiplies two pigments p1xp2
#local PR1 = function {pigment{p1}}
#local PR2 = function {pigment{p2}}
#local PR_FRed=function (x,y,z) {PR1(x,y,z).red*PR2(x,y,z).red}
#local PR_FGrn=function (x,y,z) {PR1(x,y,z).green*PR2(x,y,z).green}
#local PR_FBlu=function (x,y,z) {PR1(x,y,z).blue*PR2(x,y,z).blue}
average pigment_map{
     [function{PR_FRed(x,y,z)} color_map{[0 rgb 0][1 rgb <1,0,0>*3]}]
//add each color and then divide by 3
     [function{PR_FGrn(x,y,z)} color_map{[0 rgb 0][1 rgb <0,1,0>*3]}]
     [function{PR_FBlu(x,y,z)} color_map{[0 rgb 0][1 rgb <0,0,1>*3]}]
//Material definition
#declare PR_DIFFUSE = pigment {p_map1}
#declare PR_DIFFUSE = pigment {pigment_multiply(PR_DIFFUSE, pigment
{color srgb ((<0.67,0.67,0.50>-<1,1,1>)*1.0+<1,1,1>) })}
#declare F1 =
finish {
   specular  0.274
   roughness 0.048
   diffuse  0.8
   reflection {0} conserve_energy
#declare F2 =
finish {
   specular  0.0
   roughness 0.002
   diffuse  0.8
#declare N1 =
normal {p_map2
   bump_size 50
#declare T1 =
   pigment {uv_mapping PR_DIFFUSE}
   finish {F1}
   normal {uv_mapping N1}
#declare T2 =
   finish {F2}
#declare T3 =
   pigment {uv_mapping
     granite
     pigment_map {
       [0.20 srgb <0.3, 1.0, 0.3>]
       [0.35 srgb <1.0, 0.3, 0.3>]
       [0.55 srgb <1.0, 0.3, 0.3>]
       [0.70 srgb <1.0, 1.0, 0.3>]
     scale 1
   finish {F1}
#declare BoatPaint =
material {
     pigment_pattern {uv_mapping p_map3}
     texture_map {
       [0.20 T1]
       [0.30 T3]
       [0.55 T2]
       [0.90 T3]
Date: 5 Dec 2022 02:53:14
Message: <638da36a@news.povray.org>
Op 03/12/2022 om 22:48 schreef s.day:
The boat (and surroundings) were inspired by a photograph of the Nuntasi
Lake in Romania, from a documentary of Arte
(https://www.arte.tv/fr/videos/099776-000-A/secheresse-en-europe/) not
available any more. But I enclose a copy here.
/That/ will take some time unfortunately.... :-/
Download 'nuntasi lake_romenia.jpg' (151 KB)
Preview of image 'nuntasi lake_romenia.jpg'
Date: 5 Dec 2022 06:30:00
Message: <web.638dd5359d632bff1f9dae3025979125@news.povray.org>
I almost had some kind of episode when i clicked on that an thought it was your
image!   :O
and then I thought that "/That/ will take some time unfortunately.... :-/" was
sarcasm.
..oO( _DAMN_ he's gotten GOOD!!! )
I'll go drink my coffee now.
Date: 5 Dec 2022 08:03:39
Message: <638dec2b$1@news.povray.org>
Date: 5 Dec 2022 13:40:00
Message: <web.638e3ab19d632bff1f9dae3025979125@news.povray.org>
Well said.   ;)
Date: 11 Dec 2022 13:19:10
Message: <63961f1e$1@news.povray.org>
Il 21/11/2022 17:01, Thomas de Groot ha scritto:
Waiting for anticipations...
Paolo
