POV-Ray : Newsgroups : povray.binaries.images : The Shallows II (2/3) Server Time
25 Jun 2026 03:18:25 EDT (-0400)
  The Shallows II (2/3) (Message 3 to 12 of 19)
<<< Previous 2 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: The Shallows II (2/3)
Date: 21 Nov 2022 05:45:00
Message: <web.637b56079d632bffc0ce110b6cde94f1@news.povray.org>
hi,
> Time to reveal "The Shallows II", the next instalment of the triptych.
> I have been asked about a background story for the triptych, but I
> prefer to leave that to the imagination of the beholder :-)
the suspense is _killing_ me.  :-)
> Total cumulated render time was about 39 hours on a i5 laptop.
love the image, wonderful atmosphere (in both senses).  cheers.
regards, jr.
Date: 21 Nov 2022 10:53:23
Message: <637b9ef3$1@news.povray.org>
Op 20-11-2022 om 18:40 schreef Bald Eagle:
>> Thomas
> Very nice.   I like the concrete aggregate texture, the decomposed frame/riser
> of the rowboat - and little things like the drag marks in the ground and the way
> the plants are aligned.
Thank you indeed!
The rowing boat was inspired by an image from Nuntasi Lake in Romania:
https://www.swyrl.tv/article/wir-sind-der-meteorit-der-auf-die-erde-faellt-beeindruckende-tv-dokus-zu-klimawandel-und-duerre
It was an illustration from a documentary on Arte earlier this year.
The concrete aggregate is not only a texture, but this texture was also
processed and used as basis for displacement mapping in Poseray.
Date: 21 Nov 2022 11:01:30
Message: <637ba0da$1@news.povray.org>
Op 21-11-2022 om 11:42 schreef jr:
> hi,
Of course! ;-0
Thanks jr. I have to think about III now more seriously, and doing some
long overdue homework...
Date: 22 Nov 2022 06:52:29
Message: <637cb7fd$1@news.povray.org>
Hi(gh)!
I. e. not just an normal map? Wow!
See you in Khyberspace!
Yadgar
Date: 22 Nov 2022 07:05:00
Message: <web.637cba7f9d632bff16086ed06830a892@news.povray.org>
=?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
> Hi(gh)!
> Yadgar
Indeed this material really stands out !
Do you think such a result could be achieved using HG POV displacement or
isosurface displacement macros? If yes an include like you did for Granite would
really be worth it, and if not, maybe a tutorial ?
Date: 22 Nov 2022 08:34:28
Message: <637ccfe4$1@news.povray.org>
Op 22-11-2022 om 13:03 schreef Mr:
>> Hi(gh)!
>> Yadgar
Thank you!
Note that displacement mapping is done using .obj or mesh2 files as
input in Poseray. I really have no idea if HG POV can do this. However,
I guess that isosurfaces could do the job but probably would be much
slower (in render time) than the way through Poseray which generates a
"heavy" output .geom file but renders almost as fast as a non-displaced
object.
I gave some sort of tutorial last year:
https://news.povray.org/povray.binaries.images/thread/%3C60e02637%40news.povray.org%3E/
Date: 22 Nov 2022 13:45:00
Message: <web.637d184d9d632bff17bac71e8ffb8ce3@news.povray.org>
It can probably be done with the meshmaker.inc that comes with POV-Ray.
A crude crackle cylinder example:
#version 3.8;
#include "meshmaker.inc"
global_settings {assumed_gamma 1.0}
   location  <0,1,-10>
   look_at   <0,0,0>
   angle 20
light_source { <500,500,-500> rgb <1,0.9,0.8> }
light_source { <-100,100,-500> rgb <0.3,0.3,0.5> }
#declare Crack= function {
    crackle
    colour_map{
      [0, rgb .01]
      [1, rgb .05]
    scale 0.05
#declare R= function(u,v) {
  Crack(u,v,0).gray
#declare F1= function(u,v){(.5+R(u,v))*cos(u)}
#declare F2= function(u,v){(.5+R(u,v))*sin(u)}
#declare F3= function(u,v){v}
object{
   Parametric(
      F1, F2, F3,
      <0, -1>,
      <2*pi, 1>,
      500, 500, ""
   uv_mapping
   pigment{rgb 1}
   finish{specular 0.5}
   rotate <60,0,0>
Date: 23 Nov 2022 07:40:23
Message: <637e14b7$1@news.povray.org>
Op 22-11-2022 om 19:43 schreef ingo:
Ah! That is an excellent suggestion indeed. Something I shall have to
play with... sometime...
Date: 24 Nov 2022 11:13:52
Message: <637f9840@news.povray.org>
For those using POV-Ray 3.7, be aware that there is a bug in
meshmaker.inc v3.7: It will set your scene to #version 3.5, no matter
what you put at the top of your scene file.
This bug is fixed in v3.8 and in unofficial patches based on v3.7.1, and
the file should work if you copy it to your v3.7 include folder.
Date: 25 Nov 2022 04:23:38
Message: <6380899a$1@news.povray.org>
Op 24-11-2022 om 17:13 schreef Cousin Ricky:
Thank you indeed for this reminder! Personally, I almost always version
3.8, but sometimes 3.7 also. I now copied the corrected version of
meshmaker.inc from 3.8 to 3.7.
