After a long hot summer, with the nights getting longer, and the days getting
colder, it is time to start a new project. Maybe I'm overreaching myself, but
the bar has to be higher every time.
I decided to do the Balclutha, a steel-hulled, full-rigged ship, built in
Glasgow in 1886.
She is now a museum ship in San Fransisco.
(https://en.wikipedia.org/wiki/Balclutha_(1886))
The Library Of Congress website has detailed plans and photos of this ship, so I
have all the information to model this ship. Here is the start:
I've modeled one side of the hull, in Blender, exported the .obj-file, and
created a mesh2-file.
Ton.
Download 'forum1.jpg' (80 KB)
Preview of image 'forum1.jpg'
Op 29-3-2022 om 11:02 schreef Ton:
> Glasgow in 1886.
> Cheers
> Ton.
Good start. How did you model the hull: nurbs?
> Thomas
Bedankt Thomas.
I used Blender, and transformed the obj output in mesh2, with normals.
Ton.
Op 30/03/2022 om 01:01 schreef Ton:
>> Thomas
> Bedankt Thomas.
Indeed, but what I mean: /within/ Blender, how was the hull surface
modelled? I do not use Blender so I thought maybe it was generated with
the help of a nurbs tool, which is not available in my Silo package.
From my experience, hulls are not very easy to model without it I
think, or some similar tool.
> >> Thomas
> > Bedankt Thomas.
> Thomas
With the help of the hull profile plans I can determine the X, Y, and Z
coordinates of the hull. X is forward-backwards, Y is up-down, and Z is
left-right (or port-starboard). I start with a plane I subdivide when necessary.
In that way I work down the hull. When exporting to obj-file I (well, blender)
triangulates those rectangles. You see the result, quite convincing.
I have mirrored the hull, added the keel, which are povray objects from
roundedge.inc.
Ton.
Download 'forum4.jpg' (349 KB)
Preview of image 'forum4.jpg'
Download 'forum2.jpg' (92 KB)
Preview of image 'forum2.jpg'
Download 'forum3.jpg' (91 KB)
Preview of image 'forum3.jpg'
Op 30-3-2022 om 12:09 schreef Ton:
>>>> Thomas
>>> Bedankt Thomas.
>> Thomas
> roundedge.inc.
> Cheers
> Ton.
OK, that is pretty much as I modelled my VOC ship (Dutch East Indies
Company) many years ago. I also used the profile plans in a similar way.
http://www.irtc.org/ftp/pub/stills/2005-04-30/direpass.jpg
This one was an earlier version (2005) built in Moray.
Maybe you know DELFTship? I have been using its free version:
https://www.delftship.net/delftship/
It is very comprehensive.
> Glasgow in 1886.
> Cheers
> Ton.
I don't understand why you don't export directly using the pov addon ?
I really need the feedback to improve if something is broken?
> Hi,
I am using version 2.79, never went to 3. Too many changes, and I only use the
mesh editor.
Added color to the hull.
One view from the bow, ...
Download 'forum5.jpg' (123 KB)
Preview of image 'forum5.jpg'
.... and a view from the stern.
Ton.
Download 'forum6.jpg' (124 KB)
Preview of image 'forum6.jpg'
Op 7-4-2022 om 02:05 schreef Ton:
> Cheers
> Ton.
Good. Taking shape rapidly. Are you using object patterns for the colors?
> Thomas
No, that didn't work. Especially with the fake gun ports. From the plans I took
the X- and Y-coordinates for the color bands, and with SDL I create closed
meshes, that I intersect with the hull. So the hull is split in 4 different
sections, each with its own color.
Here is the latest update, the hawsepipes for the mooring ropes are added, plus
the cap rail.
Ton.
Download 'forum7.jpg' (135 KB)
Preview of image 'forum7.jpg'
Managed to get the main deck in place.
Ton.
Download 'forum8.jpg' (141 KB)
Preview of image 'forum8.jpg'
hi,
fascinating to watch the progress, a bit like time-lapse "photography". :-)
regards, jr.
"jr" <cre### [at] gmail com> wrote:
> hi,
> regards, jr.
It reminds me a bit of a plastic kit, where you glue the two halves of the hull
together, and then add the decks and the rest of the ship.
Ton.
The fore-deck is in place. Onto the aft-deck.
Ton.
Download 'forum9.jpg' (143 KB)
Preview of image 'forum9.jpg'
Op 22-4-2022 om 01:36 schreef Ton:
> Cheers
> Ton.
Aye aye, sir!
Here is the aft deck, or stern deck, or, as in the drawings of the Balclutha,
poop deck.
Ton.
Download 'forum10.jpg' (150 KB)
Preview of image 'forum10.jpg'
Am 31.03.2022 um 10:07 schrieb Mr:
>> Glasgow in 1886.
>> Cheers
>> Ton.
> Hi,
Hi Mr,
I try to switch from Poser to Makehuman and Blender for modeling humans
in MakeHuman und posing them in Blender. That works fine and I would
like to test your POV-exporter but I cannot find this tool within
Blender (Edit-Menu/Preferences/Add ons). So there seems to be a problem
with the accessibility of your tool in Blender (Version 3.0).
Regards
Michael
Here is another bit of progress, the fronts of the fore- and aft-decks are
there, making the ship weather tight, plus the portholes are in place, so it's
not so dark inside.
Ton.
Download 'forum11.jpg' (143 KB)
Preview of image 'forum11.jpg'
Download 'forum12.jpg' (157 KB)
Preview of image 'forum12.jpg'
Each time, I am awed by the seemingly out-of-hand way you build your
models. In your place, I would endlessly tinker with the object,
constantly changing, amending, restarting from scratch, before being
satisfied and after being often frustrated. Good, clean, job, sir.
Waiting for the next stages, masts and rigging I assume. Some more decks
and pilot house, yes?
Thanks for the compliment, Thomas. I do tinker, change, before satisfied. The
main thing is to make up your mind and say, okay, this is it! Some sample,
close-up renders, yes, it looks good, done, Otherwise you're never finished. I'm
not a perfectionist in the sense that everything has to be the correct size up
to the millimeter, or 1/16 of an inch (this is an imperial ship, after all). I
don't think I would have the patience, or stamina, to do your work on the
granites,
The decks are finished, there are not many structures on deck. The maindeck has
some quarters and the carpenters shop. The aftdeck has a chart house, the
steering wheel is outside. There are a couple of things on the deck, like
britts, fife rails, railing, and then the masts with all the rigging. So still
plenty to do.
Attached are close-ups of the foredeck and aftdeck from the maindeck.
Ton.
Download 'forum13.jpg' (251 KB)
Preview of image 'forum13.jpg'
Download 'forum14.jpg' (231 KB)
Preview of image 'forum14.jpg'
Op 4-5-2022 om 01:37 schreef Ton:
> granites,
It is not so much that I am a perfectionist (I am a bit but not
excessively) but I have regularly problems with finding the
right/correct way to do things or to apply the correct solution to a
problem.
I am slowly working towards the moment when I shall reveal some of my
recent work: an architectural project I started in 2009 with Moray,
shelved till the beginning of 2021, interrupted by the granites project,
and restarted in January 2022...
> plenty to do.
> Cheers
> Ton.
Very nice indeed. Pristine clean paint job too. :-)
> plenty to do.
I like that decorative curved-wood railing(?) around the fore-deck. A
sphere-sweep?
I am watching the construction of this ship with interest; nice work so far.
Hi Kenneth, that edge around the foredeck are just a couple of cylinders. I know
where the vertices of the mesh are, and just draw the cylinders.
Thomas, looking forward to your never-ending project.
The Balclutha now has its bulwark-rail and stanchions. I also added the bitts.
Ton.
Download 'forum15.jpg' (148 KB)
Preview of image 'forum15.jpg'
Here is a close-up of the stanchions. The photo also shows a bitt.
Ton.
Download 'forum16.jpg' (198 KB)
Preview of image 'forum16.jpg'
I like the black texture of the bolard.
tTh
| sphinx of black quartz, judge my vow. |
> tTh
Thanks. It's just a black metallic texture with a bit of bozo pattern normal,
nothing fancy, but it looks good.
The fife rails are done, here is a photo of the mainmast one, with the bilge
pump attached.
Ton.
Download 'forum17.jpg' (272 KB)
Preview of image 'forum17.jpg'
Deckhouse is done. This is the largest object on Balclutha, besides the hull,
also one of the easiest.Just a RE_Box_y from roundedge.inc, cylinders and
toruses for the roof, and add the portholes and doors.
Ton.
Download 'forum18.jpg' (259 KB)
Preview of image 'forum18.jpg'
The ladders are done. Because the ladders are connected to the balustrade, and
the balustrade is connected to the railing, I had to do those as well. That took
a while. But without further delay, here are the latest images. The foredeck:
Ton.
Download 'forum19.jpg' (347 KB)
Preview of image 'forum19.jpg'
And the aftdeck.
Ton.
Download 'forum20.jpg' (410 KB)
Preview of image 'forum20.jpg'
The catheads sure took some time, they are complicated.
Here they are.
Ton.
Download 'forum21.jpg' (324 KB)
Preview of image 'forum21.jpg'
A view of the whole ship, as it is now.
Now onto the anchors, and tie them securely to the catheads and the foredeck.
Ton.
Download 'forum22.jpg' (185 KB)
Preview of image 'forum22.jpg'
hi,
I wish there'd been an image of that same aspect, for every step along the way,
it would allow one to assemble a time lapse sequence. (looking forward to masts
+ rigging :-))
regards, jr.
> hi,
> + rigging :-))
> regards, jr.
A good idea for many projects.
I've done a sort of "buildup" approach for scenes or complicated objects that
would lend itself to this even at this stage.
Basically every step is a numeric level, and if a value (the clock) is equal to
or greater than that level, the object {} gets rendered.
There might be a way to "delete" selected steps to show how modifications and
corrections were made.
Anyway, I'm sure he can easily do some editing to accomplish this.
Seeing the code or a description of how some of the more interesting objects
were created is always educational. :)
-BW
I've done the anchors, maneuvered them in place, slowly (they're heavy!), and
I've added the pin rail for the bowsprit.
This concludes the foredeck, now onto the aft.
Ton.
Download 'forum23.jpg' (187 KB)
Preview of image 'forum23.jpg'
Op 05/07/2022 om 04:02 schreef Ton:
> Cheers
> Ton.
Perfect! ...although... how do you drop the anchors /through/ the
railing? ;-)
> railing? ;-)
> Thomas
Well spotted, so early in the morning for you! That part of the railing can be
removed, but I didn't model the hinges. They are very small, and not noticeable
on this scale. At least that's what I thought.... I might put a little thicker
cylinder there, and say that that's the hinge.
Ton.
Op 05/07/2022 om 08:23 schreef Ton:
>> railing? ;-)
>> Thomas
> Cheers
> Ton.
Not /that/ early (8:38 am local time).
Hinges, yes I guessed so indeed. Maybe show them, just to avoid
repetitive stupid questions from visiting landlubbers. :-)
> Cheers
> Ton.
There is an issue here : You need to remove the guard rails to lower the
anchors.
For all the eagle-eyed povrayers here, I am glad you pointed out the lack of the
anchor chain. Here it is:
Ton.
Download 'forum24.jpg' (179 KB)
Preview of image 'forum24.jpg'
Op 11-7-2022 om 13:13 schreef Ton:
> Cheers
> Ton.
Nah...! What's the use of an anchor chain if you cannot drop the anchor
through the railing? Our eagle-eyes stalled at that point. ;-)
> Thomas
Makes sense.
Well, I'm on to the aft-deck now, now anchors there.
Ton.
The poop deck is getting crowded:
The rudder is attached, and the steering wheel.
Ton.
Download 'forum25.jpg' (124 KB)
Preview of image 'forum25.jpg'
