POV-Ray : Newsgroups : povray.binaries.images : Stone with Veins Server Time
8 Nov 2026 04:40:51 EST (-0500)
  Stone with Veins (Message 1 to 22 of 22)
Subject: Stone with Veins
Date: 25 Dec 2021 03:10:00
Message: <web.61c6d13a245e6b682636f1af607c1b34@news.povray.org>
After the release of Granite_21 by Thomas de Groot and his collaborators, I
hesitate to share my amateurish attempt at a granite texture. The quality of the
results and the levels of sophistication do not compare (Thomas's granite is far
better than anything I can achieve). However, the approach I took did happen to
lend itself somewhat well to making the veins in the rock so with that in mind
I'll go ahead and show some examples.
The basic technique is to make an array of colors, possibly by sampling a
photograph, then create a multi-layered texture consisting of color_maps that
are partly colored with random array entries, and partly transparent. Increasing
the brightness of just one of the color array entries has the effect of
"lighting up" the layers above it. Selecting different colors to brighten can
create dramatically different and sometimes surprising results.
The image attached to this post is the final product for the project I was
working on. The veins are necessarily boring. The next two posts are
developmental experiments and will show the lighting effect more intensely.
I'll post the source code in case anyone is interested but be warned, it's a
little messy.
Have a great day!
Best regards,
Dave Blandston
Download 'granitetest0.jpg' (699 KB)
Preview of image 'granitetest0.jpg'
Subject: Re: Stone with Veins
Date: 25 Dec 2021 03:15:00
Message: <web.61c6d289c205c2d42636f1af607c1b34@news.povray.org>
Another example...
Download 'granitetest1.jpg' (657 KB)
Preview of image 'granitetest1.jpg'
Date: 25 Dec 2021 03:20:00
Message: <web.61c6d3f2c205c2d42636f1af607c1b34@news.povray.org>
I made a brief attempt to add iridescence. With some fine-tuning it might
work...
Download 'granitetest2.jpg' (85 KB)
Preview of image 'granitetest2.jpg'
Date: 25 Dec 2021 03:53:46
Message: <61c6dc1a$1@news.povray.org>
Op 25-12-2021 om 09:07 schreef Dave Blandston:
No need to be shy :-) Different approaches to identical goals are to be
promoted strongly.
This, sir, is brilliant! I declare your end result to be better than
mine, especially in close up. The individual grains are much more
natural looking. Very, very well done indeed.
The veins could use some width variations over their length.
> little messy.
I am certainly interested!
> Have a great day!
You provided one! ;-)
Date: 25 Dec 2021 14:30:00
Message: <web.61c77006c205c2d42636f1af607c1b34@news.povray.org>
Oh you caught me being lazy! The variable width feature will be easy to add and
I agree that it's necessary. Thanks for the kind words and suggestion! You're
under-rating Granite_21 though because the color distribution is excellent and
the surface has exactly the right bumpiness, which I know required amazing
knowledge and skill to produce.
By the way, I must confess that by brightening one of the color entries
(actually color pairs), I was expecting to get brightly-colored flakes without
affecting the other layers - the actual result was quite a surprise. Depending
on which color pair one chooses to brighten, the brightness factor may need to
be quite high if that particular color happens to be buried under several other
layers. There's lots of room for improvement!
Sorry for the messy state of the source code. One thing to note is that render
time can be improved by reducing the number of layers. The reason I set it so
high is that when I used a bright green base layer (<.7, 1, 0>) as a test, it
still showed through a little even with 100 layers.
Warmest regards,
Dave Blandston
Date: 26 Dec 2021 03:05:22
Message: <61c82242$1@news.povray.org>
Op 25/12/2021 om 20:24 schreef Dave Blandston:
Well, well, well, are we going to outcompete each other in praise words
now? ;-)  But seriously, comparing the grain build-up/aspect of the two
approaches in close up, I consider yours definitely as better, more
natural, looking. I need to dive into your code to see how you achieved
that, because it was my ultimate if - imo - partly failed goal.
That is an interesting notion. Investigation is in order.
I am not surprised. Layering does not improve render speed.
> Warmest regards,
And returned. Have a nice and peaceful Christmas (extended to all you
POV-Ray ladies and gentlemen out there in the big world)
Date: 26 Dec 2021 05:15:00
Message: <web.61c84013c205c2d42636f1af607c1b34@news.povray.org>
> that
I cleaned up the code a little and added some comments so it's easier to see
what variables need to be set. The improved code is posted as a reply to the
original post in the "povray.text.scene-files" section.
Kind regards,
Dave Blandston
Date: 27 Dec 2021 03:05:00
Message: <web.61c9737cc205c2d416086ed03f378f2@news.povray.org>
> > that
> Kind regards,
> Dave Blandston
both approaches look pretty complementary, and I hope they could somewhat merge?
I really like the white veins with iridescence. To make it really fully
functional, it would be great if it could also add some such quartzy  "freckles"
smaller and scattered away from the veins(sorry for my unscientific vocabulary)
but maybe just some warp / turbulence would end up providing that ?
This is great !
Date: 27 Dec 2021 05:50:00
Message: <web.61c999eac205c2d42636f1af607c1b34@news.povray.org>
Good ideas! Yes, adding flecks is possible. That could be accomplished with a
texture_map or with CSG objects.
I've been working on other stuff and haven't experimented further with
iridescence but I think it might be possible to do much better than the example
image.
Have a wonderful day!
-Dave Blandston
Date: 28 Dec 2021 02:36:55
Message: <61cabe97$1@news.povray.org>
Op 27/12/2021 om 11:48 schreef Dave Blandston:
Indeed. Especially the trick of using colour pairs is a smart one. If
Dave agrees I would like somehow to integrate that in Granite 21, when I
can get to it.
> image.
Dave, I have started to play with your code. Is there a reason why you
chose to use hex colours? I find them rather counter-intuitive.
Date: 28 Dec 2021 05:00:00
Message: <web.61cadfacc205c2d42636f1af607c1b34@news.povray.org>
> If
> can get to it.
> Is there a reason why you chose to use hex colours?
Please feel free to use the code in whatever way you wish!
There's no reason to keep the hex colors. The reason I used them is because I
use the color picker tool in Paint.net to sample colors from pictures and it's
much easier and quicker to copy and paste a single hexadecimal color code from
Paint.net to POV-Ray instead of three separate RGB values. If one set of colors
is used for the stone and a second set of colors is used for the veins then
there could be quite a number of copy-and-pastes.
Have an awesome day!
Kind regards,
Dave Blandston
Date: 28 Dec 2021 11:45:00
Message: <web.61cb3ddfc205c2d44cef624e6e066e29@news.povray.org>
> ...The reason I used them is because I
> use the color picker tool in Paint.net to sample colors from pictures,,,
Ah, a fellow Paint.net user ;-) I'm currently running Windows 10; my previous
go-to app for graphics work was an *old* version of Photoshop (which ran under
Windows XP and even 7 with some fiddling), so it is taking me awhile to learn
workarounds for some of PS's more advanced features.
> work...
Your result is really beautiful, and those veins look...real! That's a great
technique you've come up with; I plan to look at your code, thanks for posting
it.
Date: 28 Dec 2021 15:35:00
Message: <web.61cb73edc205c2d42636f1af607c1b34@news.povray.org>
I bought the last version of Photo Shop before it became subscription-only and
it's invaluable of course but I prefer the speed and simplicity of Paint.net
whenever possible, which I find is most of the time.
> it.
Thanks for the generous compliment, just be warned: trial-and-error is
necessary. The final result depends on how the texture layers randomly stack up.
The current code is not at all sophisticated in it's ability to be controlled in
a predictable manner. However, POV-Ray is a wonderful thing and that can
certainly be accomplished!
One more thing that might be worth exploring is the selection of color(s) that
make up the transparent portion of each layer. Currently, the transparent
portions are set to Black or White (via the variable "WhiteLevel"). Using a
value greater than one or less than zero is also interesting.
There are lots of possibilities to explore. I discovered that layered textures
don't work quite the way I thought they did, they work better than I thought.
Thank you once again POV-Ray programmers!
Kind regards,
Dave Blandston
Date: 30 Dec 2021 08:40:32
Message: <61cdb6d0@news.povray.org>
So here we go.
I took my Granite_21 array for Dakota Red and extracted colour pairs. I
also changed the reflection block because I guess the original
reflection is way too strong. I used the reflection as given in
Granite_21. A couple of further, inconsequential, changes et voilà.
This is the finish block I used:
   finish {
     diffuse albedo 0.5 brilliance 1.5
     specular albedo 0.9 roughness 0.0025
     fresnel on
     reflection {0.1  fresnel on}
     conserve_energy
I used 10 layers and scaled the final texture on the object. I could
also have used much more layers (e.g. 100) and scale the texture
somewhat less, with a similar result but a bit more confused imo.
Again, this is a great piece of work, Dave! I need to dig deeper now. ;-)
Download 'db_granite_test2_1.jpg' (85 KB)
Preview of image 'db_granite_test2_1.jpg'
Date: 31 Dec 2021 00:50:00
Message: <web.61ce98d1c205c2d42636f1af607c1b34@news.povray.org>
> Granite_21. A couple of further, inconsequential, changes et voilą.
You would be shocked at what a mess I've made of the lighting and texturing in
the scene that this came from so yes the finish would need a lot of fixing. I've
always had trouble with that part of POV-Ray...
Ten layers is much more reasonable than a hundred and your excellent results
prove it. I admit that a hundred layers is a bit of overkill. (Sometimes I tend
to be a bit of a perfectionist. I don't quite have OCD, but I do have CDO which
is similar, but with the letters in alphabetical order like they're supposed to
be.)
I've been using this sample image as a Granite_21 reference point:
https://news.povray.org/povray.binaries.images/attachment/%3C6089814e%40news.povray.org%3E/dakotagrains_sn_test.jpg
This one represents near perfection in my opinion (the color samples I used came
from that picture, by the way). But I agree, both methods produce great results
and I'm more excited than ever regarding Granite_21. Thanks for sharing your
preliminary results!
Kind regards,
Dave Blandston
Date: 31 Dec 2021 10:41:14
Message: <61cf249a@news.povray.org>
Op 31-12-2021 om 06:44 schreef Dave Blandston:
I agree. Sometimes finish can be straightforward, but especially with
reflections, there are tricky things to take care of.
> be.)
In fact, I can imagine cases where a hundred layers would be be alright.
The attached image shows, side by side, the granite as rendered with
your code (and 100 layers) at left, and as rendered with Granite_21, at
right. Both methods imo are valid, depending on what you want to
achieve. I focussed much more on the creation of individual grains
(which clearly has its drawback and limitations) while I think your
method is almost more intuitive/natural looking. In any case, I like it
quite a lot.
Best wishes for the New Year, take care! Extended to all Povers!
Download 'db_granite_test2_4-5.jpg' (239 KB)
Preview of image 'db_granite_test2_4-5.jpg'
Date: 31 Dec 2021 11:25:42
Message: <61cf2f06@news.povray.org>
My finish suggestion was not entirely correct. Better to use the
following (as a material, btw):
#local S = .2;
#declare StoneColor =
material {
   interior {ior 1.6}
     StoneColor
     finish {
       specular albedo 0.9*0.5 roughness 0.0025  //roughness 0.005 =
less proeminent
       fresnel on
       reflection {0.01 0.1  fresnel on}
       conserve_energy
     normal {granite .025 scale <S, S, S>}
Date: 31 Dec 2021 14:20:00
Message: <web.61cf5796c205c2d42636f1af607c1b34@news.povray.org>
> quite a lot.
Applying your material made a big improvement in the area of realism. Thanks for
sharing it!
And Happy New Year to everyone!
Best regards,
Dave Blandston
Date: 31 Dec 2021 14:40:50
Message: <61cf5cc2@news.povray.org>
>> texturing in
>> fixing. I've
>> results
>> (Sometimes I tend
>> CDO which
>> supposed to
>> be.)
>> used came
>> great results
>> sharing your
> quite a lot.
The left one hints of a big piece while the one on the right fits better
foe a small one.
Date: 31 Dec 2021 16:05:00
Message: <web.61cf6fb4c205c2d42636f1af607c1b34@news.povray.org>
> foe a small one.
Interesting point.
Date: 31 Dec 2021 16:10:00
Message: <web.61cf7088c205c2d41f9dae3025979125@news.povray.org>
What an amazing journey these stone textures have been!  I'm pretty happy to see
that a completely unrelated project has been woven into this, and with the bonus
that there are iridescent mineral veins to add in as well!
Good work, both of you for taking this another step further forward.
Date: 31 Dec 2021 19:40:00
Message: <web.61cfa210c205c2d42636f1af607c1b34@news.povray.org>
Kind of like the Fractint "Stone Soup Group..."
