Continuing to visit ancient code, this time something that attracted my
attention years ago: the media trees used by Gilles Tran in his
MakeCloud application
http://www.oyonale.com/image.php?code=431&mode=info§ion=2003&lang=fr
I took the relevant code out of the application and updated it to POV
version 3.8 into a tree macro. The result is slightly different from the
original but very useful (and fast) to be used as background trees in a
landscape. Maybe I can improve further.
I take the liberty to attach the code here, with the image.
Hope you find it useful.
Download '00-mediatree_test.jpg' (120 KB)
Download '00-mediatree_test.pov.txt' (6 KB)
Preview of image '00-mediatree_test.jpg'
Wow, fluffy trees! They can lend themselves to many experiments.
Nice work!
Paolo
Op 13/12/2021 om 22:09 schreef Paolo Gibellini:
> Nice work!
> Paolo
Thanks Paolo. I am not entirely done, I think. But yes, there is much
room for experiments indeed.
> > Nice work!
> > Paolo
> Thomas
This would obviously be great to make "smoke trees" of the genus Cotinus.
I first discovered these on my commute up Route 287 in NJ when I was working at
(now defunct - thanks, Monsanto) American Cyanamid in the early 90's.
Op 14-12-2021 om 12:46 schreef Bald Eagle:
>>> Nice work!
>>> Paolo
>> Thomas
Indeed. Beautiful plants. Shall put them in the ToDo List, Volume 15,
Page 532... ;-)
> Thomas
Very exciting! the shading is spot on !
That is clever and effective. I have always been interested in the possibilities
of using 'solid' (or semi-solid) media for creating interesting shapes.
Currently, I'm working on using POV-Ray's 'object' pattern and filling that with
media, along with applying an image_map for the media's colors. The code is
complex and uses functions, which is why I haven't posted about it yet; it needs
some detailed comments added, to explain how it works.
Anyway...
Examining your code, it looks like there are two different color schemes for the
trees, in #macro Tree(rd_)...
#local R1 = rd_;
#local R2 = RRand(0.0, 1.0, R1);
#if (R1 < 0.2) // yellowish-green
#local C_Media = <RRand(180, 200, R1), RRand(180, 200, R1), 90>/255;
#else // blue-ish
#local C_Media = <RRand(50, 100, R1), RRand(155, 200, R1), 87>/255;
...... but when the macro is actually called later in the 'woods' #while loop to
create the many trees, it's like this (in two places):
Tree(0) // zero
If I understand the code correctly, that imposes the same 'initial'
yellowish-green color on *all* the trees-- because 0.0 is always less than
#if (R1 < 0.2)
in the macro. To get a good distribution of the TWO colors, I used
Tree(rand(rd))
for both of the macro calls in 'woods'. Or maybe some version of RRand(...)
would work better.
[Somewhat off-topic):
I am also curious about RRand(...) itself, and how it is used here. If rd_ (i.e.
R1) in the 'Tree' macro *is* 0.0, than that is used as the random-number stream
for RRand(...). I didn't know that 0.0 could be successfully used for that-- or
even for seed(0). I have always used at least 1. But zero does work!
I guess I need to take a look at 'math.inc', to see how RRand() is actually
constructed. And to re-read the docs concerning seed() and rand() too ;-)
BTW, I was genuinely surprised that a media/samples count of only 1 would
produce such a visually-appealing result! And a reasonably fast render, too.
Op 15-12-2021 om 11:34 schreef Kenneth:
I didn't even think about that really ;-) I guess it is mainly the
absorption which does the trick...
Op 15-12-2021 om 11:00 schreef Kenneth:
> Anyway...
> #local R1 = rd_;
> #else // blue-ish
> #end
> Tree(0) // zero
yeah... there are still a couple of bugs in the code which I have not
yet squashed under my heels. Left overs from Gilles, wild mindless
changes by me, lack of dried frog pills, you name them.
> #if (R1 < 0.2)
> Tree(rand(rd))
> would work better.
I love RRand! you have a fine control over the range within which you
want your random number to be. For me, who suffers from some mild
dyscalculia, things remain much clearer. :-/
Op 15-12-2021 om 10:12 schreef Mr:
Gilles preceded me there. :-)
I will definitely grab this for later tinkering. For some reason I've never been
able to get media to look opaque like this - and this is so simple too! I wonder
what blindingly obvious thing I've been doing wrong...
Thanks for posting!
Bill
Op 15-12-2021 om 15:34 schreef Bill Pragnell:
> Thanks for posting!
> Bill
Thanks Bill! Just wait one or two days until I have tracked down the
last bugs.
Subject: Re: Gilles Tran's media trees as a macro
Date: 16 Dec 2021 08:36:45
Message: <61bb40ed@news.povray.org>
I believe that I tracked down all the inconsistencies and errors
remaining. The scene file is also easier to use, either as a single tree
tester (change the random seed!) or as a parkland development scheme, by
changing the camera location switch (CamLoc).
The scene file with macro, this time, has been provided in
p.b.scene-files folder under the identical subject line as the present
message.
Enjoy!
Download '00-mediatree_test2.jpg' (105 KB)
Preview of image '00-mediatree_test2.jpg'
That looks *really* nice. Good job! I haven't yet peeked at the revised code,
but will.
I like the grainy 'grass' texture too. I reminds me very much of a kind of
coated-paper material I bought when I was a kid, for making model-train
landscapes. It had a rough surface texture-- not just printed on-- that was made
of various green shades of some kind of ground-up material glued to it, maybe
cork(?) As I remember it, the visual effect looked almost exactly like your
render. I loved playing with that stuff; it added a very realistic look to my
train layouts and other models.
Op 16-12-2021 om 15:55 schreef Kenneth:
> but will.
You will like it, I am sure. :-)
Yes, I know what you refer to indeed. I remember that paper too: iirc,
it was some tough paper which you could wrinkle with your hands and it
could simulate mountains and meadows. Aaah...! modelling landscapes
before POV-Ray! ;-)
> but will.
https://blog.modeltrainstuff.com/adding-grass-and-greenery-to-your-layout/
This would make a great combination with (and tribute to) Friedrich Lohmueller's
trains and tracks, along with many other objects that people have modeled over
the years.
http://www.f-lohmueller.de/pov_tut/modelling/model_000e.htm
Op 17/12/2021 om 00:38 schreef Bald Eagle:
> the years.
What an excellent idea! Going to seriously think about this. Let you
know. Got a few ideas maybe, that would rekindle a couple of scenes that
got on hold somehow.
Subject: Re: Gilles Tran's media trees as a macro [2]
Date: 17 Dec 2021 11:03:40
Message: <61bcb4dc$1@news.povray.org>
The project could not be complete without the original macro of Gilles
Tran. So, with a few minor changes, I added the original macro, with the
possibility to switch between the two and, why not? mix both into the
same scene.
Latest version to be found in p.b.scene-files.
Download '00-mediatree_test3.jpg' (121 KB)
Preview of image '00-mediatree_test3.jpg'
> same scene.
> Thomas
Hi Thomas,
I haven't looked at the code but the result is very interesting. From a distance
it produces a very nice forest.
Pascal
Date: 19 Dec 2021 02:15:28
Message: <61bedc10$1@news.povray.org>
Op 19/12/2021 om 03:41 schreef BayashiPascal:
> Hi Thomas,
> Pascal
Yes, it does, doesn't it? I am somewhat surprised why this trick has not
been used more often. As far as I can tell presently, Gilles Tran has
been the only one and not that often either.
> same scene.
> Thomas
It seems you're getting very good control over this !
Date: 20 Dec 2021 07:14:41
Message: <61c073b1$1@news.povray.org>
Op 20-12-2021 om 10:20 schreef Mr:
>> same scene.
>> Thomas
My many years of total isolation in a cave, deep in the desert, seem to
finally bear their fruits... :-)
Subject: Re: Gilles Tran's media trees as a macro - correcting two train track include files (Lohmueller)
Date: 3 Jan 2022 07:48:29
Message: <61d2f09d$1@news.povray.org>
Op 17-12-2021 om 00:38 schreef Bald Eagle:
> the years.
Finally getting round to the train tracks, and I found a couple of bugs
(missing lines) in two of the include files. In both
RT_Track_Switch_B_00.inc and RT_Track_Switch_Y_00.inc, /before/ line
221, the following line is missing:
#local Height_Top_Edge_Rail = Height_Rail_Top;
It should then be followed by:
#local Rail_H = Height_Top_Edge_Rail-SH;
So you can check.
