POV-Ray : Newsgroups : povray.binaries.images : An experiment in monochrome Server Time
6 Jul 2025 00:54:42 EDT (-0400)
  An experiment in monochrome (Message 16 to 25 of 25)
Subject: Re: An experiment in monochrome
Date: 10 Jun 2021 18:00:00
Message: <web.60c28a6b23b82ed51f9dae3025979125@news.povray.org>
=?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
> Yadgar
I really just have to say that if you got some dark sunglasses and a leather
biker vest, you could totally pull off that "bouncer at a biker bar" look.
:D
Date: 10 Jun 2021 20:40:00
Message: <web.60c2afe723b82ed58e52cc8789db30a9@news.povray.org>
> "Bald Eagle" <cre### [at] netscapenet> wrote:
> > I'm also thinking that using cones would give a Voronoi effect.
> I just did this one because it was quick.
They make a nice texture that reminds me of mashed paper.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Message: <web.60c2b06d23b82ed51f9dae3025979125@news.povray.org>
This is a multi-part message in MIME format.
Download 'monochrome_be.png' (615 KB)
Preview of image 'monochrome_be.png'
Date: 11 Jun 2021 06:16:35
Message: <60c33803$1@news.povray.org>
On 11/06/2021 2:27 am, Bald Eagle wrote:
> I am curious about
> #declare GreyTest = 0.001 + abs(TestK(X,Y,0) -
> abs((TestR(X,Y,0) + TestG(X,Y,0) - TestB(X,Y,0))));
> What is the underlying logic/reasoning behind this "greyness test"?
I wish to represent 4 colours - R, G, B and Grey.
The 0.001 is now redundant, I put it in to prevent a divide by zero
error in a previous version.
TestK(X,Y,0) returns the mean value of R, G, B. (1)
R+G-B will also return the mean if R, G and B are all the same, i.e.
colour is Grey. (Black and White are just shades of Grey :-))  (2)
So the GreyTest (1)-(2) returns zero if R, G and B are equal and a small
value if they are close.
BUT --------------------------------------------------------
You got me thinking, are there any cases where the test returns zero but
R, G, B are not equal?
Answer - yes, the test sometimes falls down when the 3 numbers are
equally spaced. e.g  0.1, 0.2, 0.3    or 0.3, 0.6, 0.9
I was over thinking, maybe this will work:
#declare GreyTest = abs(TestR(X,Y,0)-TestG(X,Y,0)) +
abs(TestR(X,Y,0)-TestB(X,Y,0)) + abs(TestB(X,Y,0)-TestG(X,Y,0));
m@
Date: 11 Jun 2021 12:12:32
Message: <60c38b70$1@news.povray.org>
Hi(gh)!
>> Yadgar
Yes, and I'm about as heavyweight as the typical biker bar bouncer - but
unfortunately, it's more fat than muscle... but nevertheless, I prefer
muscle-powered cycling over motorbiking!
Now playing: Nobody Home (Pink Floyd)
Date: 11 Jun 2021 18:45:00
Message: <web.60c3e71d23b82ed51f9dae3025979125@news.povray.org>
I thought a bit about this, underthought it while playing with the idea, and
then realized that what I wanted to suggest was making use of the HSV color
space.
That way when all of the color channels are equal, the Hues cancel each other
out, or if they are close, then they give a small Saturation vector.  You can
then set the threshold and test the length of that Saturation vector.
Brightness would correspond to the Value.
Then you just use the CRGB2HSV color conversion macro in colors.inc (requires
CRGB2H).
// Converts a color in RGB color space to a color in HSV color space.
// Input:  < Red, Green, Blue, Filter, Transmit >
// Output: < Hue, Saturation, Value, Filter, Transmit >
#macro CRGB2HSV(Color)
   #local RGBFT = color Color;
   #local R = (RGBFT.red);
   #local G = (RGBFT.green);
   #local B = (RGBFT.blue);
   #local Min = min(R,min(G,B));
   #local Max = max(R,max(G,B));
   #local Span = Max-Min;
   #local H = CRGB2H (<R,G,B>, Max, Span);
   #local S = 0; #if (Max!=0) #local S = Span/Max; #end
   <H,S,Max,(RGBFT.filter),(RGBFT.transmit)>
// Takes RGB vector, Max component, and Span as input,
// returns Hue value.
#macro CRGB2H (RGB, Max, Span)
   #local H = 0;
   #local R = RGB.red;
   #local G = RGB.green;
   #local B = RGB.blue;
   #if (Span>0)
      #local H = (
         + (R = Max & G != Max ? 0 + (G - B)/Span : 0)
         + (G = Max & B != Max ? 2 + (B - R)/Span : 0)
         + (B = Max & R != Max ? 4 + (R - G)/Span : 0)
      )*60;
   H
Date: 14 Jun 2021 04:40:58
Message: <60c7161a@news.povray.org>
On 08/06/2021 11:21 am, m@b wrote:
> Trying to emulate mechanical shading.
> m@
Here is an animated version with colour. Including the traditional
checkered floor and blue sky:
<https://youtu.be/N2Z-DXoJBUY>
m@
Date: 18 Jun 2021 05:25:35
Message: <60cc668f@news.povray.org>
> m@
Latest:
Download 'image cross hatch 04.png' (279 KB)
Preview of image 'image cross hatch 04.png'
Date: 18 Jun 2021 07:15:46
Message: <60cc8062$1@news.povray.org>
Op 18-6-2021 om 11:25 schreef m@b:
>> m@
> Latest:
Oh yes! I prefer this one to those with different cross-hatches.
Date: 18 Jun 2021 07:20:00
Message: <web.60cc80e523b82ed56adeaecb3f378f2@news.povray.org>
> > m@
> Latest:
The technique refines ! result looks excellent !
