POV-Ray : Newsgroups : povray.binaries.images : Granites Intermezzo Server Time
6 Apr 2026 22:04:47 EDT (-0400)
  Granites Intermezzo (Message 82 to 86 of 86)
Subject: Re: Granites Intermezzo - last test image!
Date: 14 May 2021 04:24:48
Message: <609e33d0@news.povray.org>
Op 13-5-2021 om 17:27 schreef Mr:
>> All right! This is going to be the *last* test image of the pre-macro
>> Dakota Red Granite, closing also this Intermezzo.
>> Shown here, is the current implementation of the quartz veins through
>> the granite, using the marble pattern. Please note that this feature
>> will remain /experimental/ in the upcoming beta macro which I shall
>> provide tomorrow.
>> Thomas
> Artistically , I love it !  And if the geologist validates it, that's even
> greater !
Thanks. Validating... it depends on how deep you want to go into the
Uncanny Valley, or beyond into a complete and exact copy of reality. The
second, is imo, hardly possible (and certainly not recommended in terms
of workload and ultimate usage); the first would need a lot more
detailed work including close-up comparisons with real samples, but
would not be justified by the average intentions of individual users. I
doubt if even professionals would want it: they probably would opt for a
high-resolution image_map.
So, I do validate this version of the Dakota Red granite, perhaps not as
a true /Dakota Red/, but as a type of red granite. In a later stage we
shall tackle the /Canadian Pink/ and the /North American Pink/. Will
they be different from the present one? We shall see.
Date: 14 May 2021 08:07:15
Message: <609e67f3$1@news.povray.org>
Op 13-5-2021 om 20:40 schreef Bald Eagle:
>> provide tomorrow.
> This is looking very nice!  :)
I had been writing an answer to this post, and then it was lost... drat!
Have to do it again. :-/
> Just going to jot down some observations and thoughts, some which we may
> address, and some we might not.
> I think the pattern we have is better that the previous stock pattern.  The
> grain size is still too uniform, but maybe if several adjacent grains were
> textured identically, using the hexagon/bricks trick, then we could get a less
> homogeneous size distribution.
You have to realise that granites in general /are/ rather uniform in
grain size, only a certain class of rocks show marked size differences
('phenocrysts', 'porphyritic') where the large crystals are represented
by feldspars rather than quartz. So, the size distribution in the
present concept is about right.
> Next I guess would be crafting the textures of the individual minerals composing
> the grains.
No, I would advise against doing that, for the simple reason that it
would be overkill for most of the uses of the material. Additionally it
would burden memory and parser/render time to unacceptable levels. Much
better would be to find a 'fast' way to add a believable sslt
(conundrum, I know).
> Aside:
> I took the boy outside last weekend - the oxygen and sunlight surely burned his
> lungs and skin - and we explored the retaining wall of the local dam
https://www.nae.usace.army.mil/Missions/Civil-Works/Flood-Risk-Management/New-Hampshire/Hop-Ev/
> Lots of granite, big chunks of quartz, and other things yet to be identified "Is
> that andesite?" (smart kid - or maybe it's Minecraft...)
Excellent exercise! To be recommended for everybody in 'rocky' country.
Beautiful landscape btw. I like it.
As said above, the big chunks are probably feldspars rather quartz, and
no, no 'andesite', which would be a fine-grained, dark, extrusive rock
and no granite. However, a smart suggestion indeed. The big chunks may
point to a porphyry or a gabbro instead of a true granite.
> I noticed that the quartz, while appearing translucent white in small samples,
> took on an agate gray/purple cast as the veins or chunks got larger and deeper
> and Beer's law started to really kick in.  There were also striations
> perpendicular to the vein line, and some of the quartz was bordered by a
> different mineral that was more chalky / portland cement solid white, whatever
> that might be.
Yes, those characteristics seem to point to feldspars. the 'chalky'
colour might point to 'weathering' of the minerals.
> There were also "rust spots" in some of the rocks, as well as plates of of mica.
>   And mixed in with the granites were a few very smooth fine-grained/grainless
> stones that had a dark grey transitioning to red color, such that they almost
> looked like they were rusting.
Hmmm... inclusions of stones... maybe we are not dealing with a true
granite here. Granites do not have such inclusions.
> I can return and take samples, photos, closeups if we think such would assist.
Well, a few photos would do no harm indeed. Remember however, that we
are dealing here with /Dakota/ granites! If taking photos, remember to
put in a coin or something recognisable for size. Good practice for such
things!
> I would imagine that the quartz veins will be the most challenging to implement,
> as there will be the issue of presence, thickness, number of veins, orientation,
> amount of turbulence, etc.  Maybe that's best handled by an optional array that
> the macro checks to see if present.
Yes, the veins are a problem. I was wondering if we should not need some
kind of function to do this well. Not sure how to do this correctly.
Date: 14 May 2021 10:48:43
Message: <609e8dcb$1@news.povray.org>
>>> provide tomorrow.
>>> Thomas
>> even
>> greater !
The uncanny Valley is rather shallow when it comes to things like the
pattern of rocks.
Date: 14 May 2021 11:02:03
Message: <609e90eb$1@news.povray.org>
Op 14-5-2021 om 16:48 schreef Alain Martel:
>>>> provide tomorrow.
>>>> Thomas
>>> even
>>> greater !
>> The second, is imo, hardly possible (and certainly not recommended in
>> terms of workload and ultimate usage); the first would need a lot more
>> I doubt if even professionals would want it: they probably would opt
>> for a high-resolution image_map.
>> as a true /Dakota Red/, but as a type of red granite. In a later stage
>> we shall tackle the /Canadian Pink/ and the /North American Pink/.
>> Will they be different from the present one? We shall see.
> pattern of rocks.
Yes, that is certainly true indeed, but you get my meaning.
Date: 17 May 2021 04:10:39
Message: <60a224ff$1@news.povray.org>
Thomas de Groot wrote on 13/05/2021 17:02:
> provide tomorrow.
It looks great!
Paolo
