POV-Ray : Newsgroups : povray.binaries.images : Granites Intermezzo Server Time
14 Mar 2026 17:46:24 EDT (-0400)
  Granites Intermezzo (Message 51 to 60 of 86)
Subject: Re: Granites Intermezzo
Date: 4 May 2021 03:01:00
Message: <6090f12c$1@news.povray.org>
Op 03/05/2021 om 19:21 schreef Bald Eagle:
>> For your judgment again.
> This is pretty spectacular, as was the prior ovus example.
> I think what Maurice is trying to point out is the "frosted" look of the blurred
> pattern.
> I think the earlier prototype StepNoise example was more impressive than the
> current iteration.
Both are necessary. The blended version is the weathered granite look,
the crisp version is the fresh granite look.
> And I'm not sure why you chose to do several experiments with start and end both
> equal to 0.5 - as that is just the cells pattern.
No secret there: just for convenience while testing the omega, lambda
and octaves. The top row of the experiment shows start and end
variations both. I guess that more differences would be shown with a
"simpler" colour_map? Not sure about this. I want to investigate a bit
further.
> But I must say that I really like this frosted look for an outdoor, weathered
> piece of natural stone, as this is really what it looks like, with dust, and
> evaporated rain, and pollen, etc.  Adding that displacement or normal really
> gives it that natural look as well.
I guess this is almost as close as you can get to a believable granite.
> I think Maurice is looking for that lack of micro-surface texture that leads to
> a lot of air - which has a different ior than the minerals and leads to that dry
> paper / freshly applied transparent tape look.  Polishing, wetting, and waxing
> gives it that sharp, crisp, high-contrast look with more saturated colors and
> clearer delineations between the grains.
> At least that's what I'm speculating.
Maybe. I am not sure yet about what he means.
> However, all in all, this is very pleasing, and extremely encouraging progress!
Absolutely.
Subject: Re: Granites Intermezzo - big render
Date: 4 May 2021 07:06:10
Message: <60912aa2@news.povray.org>
A 2048x2048px render.
StepNoise settings: Start=0.2; End=0.8; Turbulence=0.325; and octaves=2;
lambda=1; omega=2;
Download 'dakotagrains_testbig.jpg' (685 KB)
Preview of image 'dakotagrains_testbig.jpg'
Date: 4 May 2021 11:36:17
Message: <609169f1$1@news.povray.org>
Op 3-5-2021 om 19:21 schreef Bald Eagle:
As an alternative, I am examining the use of another pattern: crackle solid.
It might be an interesting option...
Subject: Re: Granites Intermezzo - using crackle solid pattern
Date: 5 May 2021 10:57:48
Message: <6092b26c@news.povray.org>
I think this is a perfect alternative to all the preceding!
The basic pigment_pattern used for the mineral grains as well as for the
mask controlling the size distribution through the rock, is crackle
solid. It has the advantage to well-discriminate between the different
minerals, better than all the previous experiments. I found this out by
examining a couple of traditional POV-Ray stone textures, more
especially T_Stone_28.inc, and tweak from there before substituting the
results here.
I think that the "blurry" aspect that Mr was complaining about, came in
fact from the size distribution within the mask pattern. It may still
exist a bit, but I developed a mask with less diffuse transitions.
Download 'dakotagrains_testbig3.jpg' (237 KB)
Preview of image 'dakotagrains_testbig3.jpg'
Date: 5 May 2021 12:15:00
Message: <web.6092c3fd9461b36b6adeaecb3f378f2@news.povray.org>
> results here.
> Thomas
This sure looks good. I guess my trouble with this scale and contrast/definition
is that I must be loosing track of what context the current image you show is
made for, and thus probably do not have in mind the proper type of real photo
referenced granite occurence. Once we can play with parameters and get these
various photo references side by side with the renders thing will certainly look
fine and more versatile than if made with just one average reference.
If will it or does it already have configuration presets? something along : 1
Raw outside (worn out with slightly blurry patches) 2 raw inside (same pigment,
neater, and with normal bump) 3 polished: same as before without bump and with
slight mirror reflection?
What troubles me, with the scale is that initial picture I saw ad red flakes
around 1cm size while this frosted has rather 1mm... can the first one still be
made easily?
Date: 5 May 2021 13:55:00
Message: <web.6092daeb9461b36b1f9dae3025979125@news.povray.org>
> solid.
That's working out just as nicely.
IIRC, crackle solid has different "metrics" and you can get the adjacent cell
effect like you're showing, but also a sort of pavers-and-mortar effect.
These are all looking good, and it will be really nice if there's a way to mix /
blend some of the different patterns and texture_maps, or even the same pattern
at different scales.
Date: 6 May 2021 04:37:03
Message: <6093aaaf$1@news.povray.org>
Op 5-5-2021 om 18:12 schreef Mr:
The whole thing is a mess at the moment of course ;-) I need to assess
now /how/ and /what/ I want to make controls for. A macro architecture
of course and enough parameters to play with.
No yet totally present as such but to be part of that macro I mentioned.
I hope to start with the cleaning-up now as I guess I have ironed out
all the problems at this moment.
> made easily?
No idea to be frank. But I keep it in my mind as one of the options.
Date: 6 May 2021 04:39:41
Message: <6093ab4d$1@news.povray.org>
Op 5-5-2021 om 19:50 schreef Bald Eagle:
>> solid.
I believe so, but I prefer not to use the pavers-and-mortar effect. Less
natural feeling.
Indeed. Part of the work in progress. ;-)
Date: 6 May 2021 05:10:00
Message: <web.6093b2009461b36b79819d986cde94f1@news.povray.org>
hi,
with the many posts I read, (sorry) I seem to have lost track of 'why'.  whether
it is "simply" a general modernisation, or bringing the code[*] up-to-date for
3.8 and the shiny, new (SDL) toys.  if the latter, then you're spoilt for
choice.  :-)
[*] much of new, I assume.
regards, jr.
Date: 6 May 2021 06:25:00
Message: <web.6093c3409461b36b1f9dae3025979125@news.povray.org>
> natural feeling.
I only mention it because the opening image of this thread has the natural
examples which have quartz veining that is suggestive of this type of
patterning.
