POV-Ray : Newsgroups : povray.binaries.images : Granites Intermezzo Server Time
7 Apr 2026 05:29:47 EDT (-0400)
  Granites Intermezzo (Message 22 to 31 of 86)
Subject: Re: Granites Intermezzo
Date: 28 Apr 2021 11:50:00
Message: <web.60898377cfb077e479819d986cde94f1@news.povray.org>
hi,
> ... perfection.
"Flanders (medium) Gray".  :-)
regards, jr.
Date: 28 Apr 2021 13:30:00
Message: <web.60899ad1cfb077e41f9dae3025979125@news.povray.org>
> I do not want to have you wait: This is the first render with StepNoise.
> My judgment is: perfection.
.... holy crap!  :O
I would have never guessed it would THAT good!  Thanks for not making me wait.
That is indeed MUCH better than the turbulated cells experiment.  I'm glad that
it's panning out and we have something to work with as a good base pattern.
I'd say the next thing to do would be to have that texture be an entry in a
marble pattern texture_map, with a quartz texture as the vein.
After that, you're going to be the geological expert on whatever else might make
worthwhile additions.
Date: 28 Apr 2021 16:40:00
Message: <web.6089c781cfb077e41f9dae3025979125@news.povray.org>
Quick stab at adding the vein.
Didn't like marble or planar, so I coded a Boolean math function for the stripe,
and let it blend on the sides.
Adding a mod to the function will repeat it, but it's too regular.
I tried warp {repeat x*4} but that repeats the whole pattern, and you get hard
lines.
I thought maybe I could layer it, but it's a pattern texture, and POV-Ray says
"No way!"
I also tried to add a specular highlight, and I'm too inept to get that to work
either.
Nor could I get the void created by using a difference to be anything but black.
It's unclear to me at the present time how to have separate turbulence values
for the stripe and the base StepNoise pattern, but I guess we'll figure that out
as we proceed.
Currently using the sum of two turbulated stripe patterns, so maybe the
placement of the stripes will have to be generated by a macro and an array of
plane offsets.
Anyway, this gives the general idea.
Download 'granite_veins_1.png' (192 KB)
Preview of image 'granite_veins_1.png'
Date: 28 Apr 2021 21:20:00
Message: <web.608a0944cfb077e41f9dae3025979125@news.povray.org>
And the code:
Download 'granite_veins_1.pov.txt' (4 KB)
Date: 29 Apr 2021 02:13:17
Message: <608a4e7d$1@news.povray.org>
Op 28/04/2021 om 17:47 schreef jr:
> hi,
>> ... perfection.
> regards, jr.
For the time being, yes ;-)
Date: 29 Apr 2021 02:18:19
Message: <608a4fab$1@news.povray.org>
Op 28/04/2021 om 19:26 schreef Bald Eagle:
> .... holy crap!  :O
Indeed. Was what I thought too.
I still have to test the grain size control and such but we can indeed
ditch the turbulated cells. I was happy and not happy at the same time
with those; especially the larger grains were problematic.
Sure, and don't forget the quartz veins in the granite :-)
Good. Work enough on the horizon.
Date: 29 Apr 2021 02:24:54
Message: <608a5136$1@news.povray.org>
Op 28/04/2021 om 22:37 schreef Bald Eagle:
My latest experiments with veins was by using agate and agate_turb as
second texture layer. Needed to add a warp{turbulence *z} to hide the
layering of agate. The results were promising if not perfect. I do not
have an example render at hand at this moment.
> lines.
> "No way!"
> either.
> as we proceed.
It's a first step.
> plane offsets.
Date: 29 Apr 2021 02:25:24
Message: <608a5154$1@news.povray.org>
Op 29/04/2021 om 03:17 schreef Bald Eagle:
> And the code:
Thanks. Shall play with that too.
Date: 29 Apr 2021 11:25:15
Message: <608acfdb$1@news.povray.org>
alright. Getting tired after a day of tweaking.
Second, overhauled, StepNoise version. Several things learned:
- to be careful with the /scale/ of the grains. This is as good as I
dare to go. Larger minerals become increasingly unbelievable, so one
needs to find the balance (as with the turbulated cells obviously, but
StepNoise does a much better, although not perfect, job).
- the mask for the pigment_pattern needs a /very/ careful adjustment.
The present one is good but could probably be improved further. Good
enough for now.
- white grains are present but hardly visible. In the first version they
were placed at the wrong place within the colour_map, rendering rings
instead of mineral grains. Corrected that but need now to be enhanced a bit.
- sslt would probably increase realism, even in the frosted version. I
am going to look into that.
Download 'dakotagrains_sn_test2.jpg' (95 KB)
Preview of image 'dakotagrains_sn_test2.jpg'
Date: 29 Apr 2021 12:00:00
Message: <web.608ad74acfb077e479819d986cde94f1@news.povray.org>
hi,
glad you did though, "Flanders Gray (tm)" looks ready for turning into kitchen
worktops.  :-)  (am interested to see it being used other than in a
demo/reference image)
regards, jr.
