Thomas de Groot <tho### [at] degrootorg> wrote:
> Please find here the (last) version of the scene. Search for the
> differences ;-)
Even more beautiful than your original render.
I see that the trees have been fattened-up a bit; and one of the rusty metal
fence-bars has been broken and bent (a nice touch.) It also looks like the
castle or church has been thrown into more shadow (or maybe with less fill
light), which nicely matches the late afternoon Sun. The stones under the fence
seem to have changed too.
I do like the detailed grass, but my personal preference is for the previous
'mossy' appearance; it just seems to go better with the overall 'look' of the
scene-- maybe because, with its 'lack of detail', it offsets the more-detailed
valley and trees. And it more clearly shows the shadow of the out-of-frame tree
that is cast across the lawn.
I like *both* versions of the fence stones; I think I prefer the previous
stones' textures, but the new stones' shapes. A difficult decision!
It's easy to be an amateur art critic, ha :-P
You have used so *many* interesting code tools for this scene, tools that I have
not even started experimenting with yet. Thanks for the detailed descriptions of
your techniques.
> differences ;-)
> One notable change I want to elaborate on a bit. I dumped Gilles Tran's
> MakeGrass and replaced it by Lawnmaker from Uwe Gleiss (2004).
> Unfortunately, his website from where it was downloaded does not exist
> anymore. Interestingly, the grass blades were made of parametric objects
> and I remembered the infinite time it took to render a proper scene, so
> I never used it. William Pokorny's discovery about the optimal settings
> for parametric objects, made me curious of course and, Lo! Lawnmaker
> suddenly became a serious candidate. Not stopping there, and interested
> as I am in using mesh2{} files, I decided to experiment with Meshmaker
> (thanks Ingo!). With the help of an example file by Friedrich
> Lohmueller, I made the conversion within a couple of minutes. Taking
> into account the size of the grasspatches and their grass blade density
> (which can increase parsing time quite rapidly) a typical lawn renders
> very fast, hardly slower than the rest of the scene.
> Thomas
Hi sorry, is it too late to give suggestions? The potential of this image is big
! My first and only remark if too late is that there would me a more immersive
feeling if silhouette of the castle had more bumpy details for slabs. That would
be a lot of work (maybe less for an HG POV displacement). So I hold my tong for
the other possible areas to work on and really appologize if it's too late, I
enjoy the meteorological effect of clouds falling down to rain a lot, and the
slopes of distant hills , and the grain on the rusty metal bar and the position
of wooden ramp to compose image into depth.
You've definitely made some noticeable improvements on the left side.
On the right ... it all seems to have faded into a lack of definition.
The clouds and the land ooze together into a brown cloud - I would have expected
some greater contrast, and a darker, almost black color. Something to add
WEIGHT and authoritatively announce the arrival of a STORM, and make you _feel_
it.
You have sunlight shining on the trees, but no highlights.
An effect of the light group?
The little buildings also seem to have disappeared into the beige cloud.
Are they no longer lit as well?
It's still kicking butt, and I like both versions of the grass.
That all of it is parametric, with a conversion to mesh2{} is pretty exciting as
well. Maybe a tiny example scene showing how all of that is implemented, along
with the needed files in a zip would prod other folks into taking a crack at
some renders of their own ;)
Op 15/10/2020 om 22:38 schreef Bald Eagle:
> it.
Well, It may not be rain... maybe a dust storm. I understand what you
mean but I believe I am leaving things as they are now. Maybe something
for an update in ten years time :-)
No. This is something I am going to look into in my next scene which
will be on ground level, without the castle. It probably results from
the billboard settings and or gamma maybe.
No, they are there at the same place. What has been changed are the
textures.
I prefer this one .
Excellent idea. I need to note it as todo before I forget or before RL
kicks me over.
Op 15/10/2020 om 21:18 schreef Mr:
>> differences ;-)
>> Thomas
Never too late for suggestions; if I am going to do something with them
is another matter. ;-)
For those parts of the castle which show a definite shadow in the Sun
(the tower) I used the displacement feature in Poseray. This is tricky
business because you can easily overdo it and the effect becomes worse.
So, the roof tiles and the stones in the wall were subtly displaced. The
shadowy wall were not displaced though. Overall, I applied a proximity
pattern to make the wall texture more interesting.
There are always more features to work upon in such a scene. I have a
couple of items myself. However, before I get bored I prefer to stop now
and maybe take up the work later (or never). Perfection is not my cup of
tea. :-)
Op 15/10/2020 om 09:26 schreef Kenneth:
>> differences ;-)
Different changes here: besides fattening up of the trees, I threw in a
second one and both are randomly selected. the castle walls have an
added proximity pattern to the texture (the Edouard Poor variant). It
makes them less "clean". New stones under the fence indeed, and I kicked
the metal bars into shape in some places, breaking it at one place (sorry).
Ha! Here the supremely powerful might of the author comes into play. I
shall leave it as-is.
Sure! Which is nonetheless fully appreciated as it often points directly
to sore places which need treatment.
> your techniques.
You are most welcome. I need to do something about all this. I have made
a small start into preparing all the stuff for more general use. I met a
lot of loose ends and inconsistencies already so, that is going to take
some time...
An idea off the top of my head: Instead of a flat billboard, you could make a
simple low-rez height_field for the tree (including the trunk too, possibly).
Perhaps 2 or 3 different ones, for variation. (Pre-#declare each HF so that it
doesn't take up 'extra' memory when used repeatedly.) Then the trees would show
some highlights, using phong or whatever.
Since your current billboard scheme has the trees always facing the camera, the
same scheme would be used for the HF 'shells'-- the 'rear' or underside of the
HFs would never be seen.
Hmmm.
If a heightfield is just a displacement based on the grayscale value of the
image pixels, then you could also make an isosurface of it, and abs() should
mirror the
displacement in both directions.
Then I think there's the isosurface approximation macros that could make a
mesh{} of _that_, and then you could possibly make a whole 3D tree from just the
image.
Alternatively, I guess you could just intersect{} it with a box and texture it
with the image_map and see how that turns out...
Just thinking out loud..
>>> differences ;-)
>>> Thomas
>> image is big
>> immersive
>> That would
>> tong for
>> late, I
>> and the
>> position
Maybe not for this one, but for your next master piece 😉
Op 16/10/2020 om 22:42 schreef Bald Eagle:
> Hmmm.
> mirror the
> image.
Yes, all good suggestions needing to be tested... I have a bit too many
things on my daily plate to be able to chew them properly at this
moment. Starting a /new/ ToDo list (as if that would help).
