POV-Ray : Newsgroups : povray.binaries.images : Operation timed out? Server Time
29 May 2024 02:12:47 EDT (-0400)
  Operation timed out? (Message 21 to 24 of 24)
Subject: Re: Operation timed out?
Date: 14 Aug 2020 15:47:49
Message: <5f36ea65$1@news.povray.org>
Le 12/08/2020 à 19:23, Thorsten a écrit :
> On 12.08.2020 19:08, Alain Martel wrote:
>> Le 2020-08-11 à 13:29, Thorsten a écrit :
>>> On 11.08.2020 18:13, Alain Martel wrote:
>>>> Another case that can cause an «operation timed out» is a race
>>>> condition where two or more processes or threads are asking for the
>>>> same resource at the same time and each is waiting for the other to
>>>> finish using that resource.
>>> No, this is not how POVMS is written. I am its author ;-)
>>> Thorsten
>> One of the process may not be POV-Ray related.
> The error message "Operation timed out" comes from inside POV-Ray.
And the only spot in source for it is when a stream was not provided
answer for long enough time (unclear if it is 100 or 10 seconds).
Which remind me of a windows specific bug for povray: rendering a large
but empty (or easy) scene would overflow the collecting thread with
amount of blocks to process (while the system actually starts swapping
everyone, or at least that process), leading to a problem that the
collecting thread get no cpu to process the queue, and then detecting
that too much time has past since the query.
(well behaved operating systems try to slow the producer thread(s) when
a stream get filled too fast, in order to give a chance to the consumer,
but not MS, IIRC)
A workaround might have been to reduce the number of rendering threads
(+WT1 ?) in such situation.
Date: 26 Dec 2020 06:20:00
Message: <web.5fe71b6d48fcdfd679416a1f0@news.povray.org>
> But when I try to render a sequence of consecutive images, such as
> +ipovearth.pov +ogeorgia_panorama-.png +w1024 +h768 +a0.3 +ki0 +kf719
> +kfi0 +kff719 (a simple camera rotation pull)
> after completing the first frame, I get:
> Operation timed out
> Operation timed out
> Render failed
Did you find a solution to this problem? I get this error all the time when
rendering animation frames. It's maddening. It seems to happen when a new frame
is about to begin and the status area displays the message "Running pre-frame
shellout" for a long time.
Kind regards,
Dave Blandston
Date: 26 Dec 2020 22:45:19
Message: <5fe8034f$1@news.povray.org>
Hi(gh)!
I programmed a workaround via bash shell scripting!
See you in Khyberspace!
Yadgar
Date: 26 Dec 2020 23:45:01
Message: <web.5fe8110148fcdfd679416a1f0@news.povray.org>
> Yadgar
Awesome! I will see if there's a similar solution for Windows.
Kind regards,
Dave Blandston
