POV-Ray : Newsgroups : povray.binaries.images : mesh2 generator: strange error! Server Time
28 Nov 2026 17:49:19 EST (-0500)
  mesh2 generator: strange error! (Message 1 to 16 of 16)
Subject: mesh2 generator: strange error!
Date: 8 Jul 2020 08:45:59
Message: <5f05c007@news.povray.org>
Hi(gh)!
Obviously, I once more have messed up my POVEarth code - when I run my
mesh2 generator (attached here), a strange error shows up:
"File 'mesh2writer.pov' line 287: Parse Error: Expected 'string', End of
File
  found instead
Fatal error in parser: Cannot parse input."
Though the generated mesh2 scripts look correct, whenever I render a
scene containing them, I see no terrain relief, but only ocean...
For better understanding, I also attached a (small) mesh2 script
generated with the mesh2 generator.
See you in Khyberspace!
Yadgar
Download 'mesh2writer.pov.txt' (10 KB) Download 'n41e044.inc.txt' (302 KB)
Subject: Re: mesh2 generator: strange error!
Date: 9 Jul 2020 09:55:01
Message: <web.5f07211a2c1569004d00143e0@news.povray.org>
hi,
tried to have a look, the mesh data appears to parse ok, however, am struggling
with the dimensions and trying to get the camera set up.  it would help if you
could post a small scene file that just includes that tile and displays it.
regards, jr.
Date: 9 Jul 2020 10:38:54
Message: <5f072bfe$1@news.povray.org>
Okay, here it is!
Yadgar
Now playing: Rock Me (Steppenwolf)
Download 'utf-8' (8 KB)
Date: 9 Jul 2020 10:41:00
Message: <5f072c7c$1@news.povray.org>
Hi(gh)!
...and also the texture imagemap!
Yadgar
Download 'n41e044_2004-07.png' (74 KB)
Preview of image 'n41e044_2004-07.png'
Date: 9 Jul 2020 11:20:00
Message: <web.5f07357a2c1569004d00143e0@news.povray.org>
hi,
> Okay, here it is!
cheers.
> > ... I see no terrain relief, but only ocean...
same here.  I inserted, after line 211, a line which simply subtracts from the Y
axis of 'Cam_oceanfloorpos', going from -2.5 to -2.6 the view changes.
no real idea, to be honest.  (had thought about height_fields, their adjustable
water_level  :-))  and absolutely no idea why you see the EOF error message, the
code looks kosher.
regards, jr.
Date: 9 Jul 2020 13:40:01
Message: <web.5f07560b2c156900fb0b41570@news.povray.org>
I added line 253 as:
    translate Cam_Pos/2
then
I changed line 281 to
location Cam_Pos*2
Your tile is not positioned properly.
Date: 9 Jul 2020 17:05:10
Message: <5f078686@news.povray.org>
>      translate Cam_Pos/2
> then
> location Cam_Pos*2
I tried out your suggestions... and the result is quite weird, as you see:
Download 'tbilisi.png' (112 KB)
Preview of image 'tbilisi.png'
Date: 9 Jul 2020 17:55:06
Message: <web.5f07918f2c156900fb0b41570@news.povray.org>
Indeed.
I would suggest either getting rid of your planet entirely for test renders, or
at least give it a transmit value so you can see below the surface.
Create a macro that will give the min_extent and max_extent of your tile, and
calculate the approximate surface normal.   You could then "draw" a cylinder
from the planet center to the center of the tile, and a cone from a [large]
fraction of the camera location to the center of the tile, so you can always get
a bearing on it.
But at least you see the tile and know its approximate location.
Date: 14 Jul 2020 18:35:29
Message: <5f0e3331$1@news.povray.org>
Hi(gh)!
I really have no clue how to do this - and I can't look it up, as is
seems not to be included in the POV-Ray 3.7 doc!
Yadgar
Date: 14 Jul 2020 19:40:01
Message: <web.5f0e41922c156900fb0b41570@news.povray.org>
> Hi(gh)!
> Yadgar
#declare Obj = union {
// Everything
 #local Min = min_extent (Obj);
 #local Max = max_extent (Obj);
 #local Center = (Min+Max)/2;
Date: 14 Jul 2020 19:45:28
Message: <5f0e4398$1@news.povray.org>
> // Everything
Do these two functions return float or vector values?
Date: 14 Jul 2020 20:00:01
Message: <web.5f0e468d2c156900fb0b41570@news.povray.org>
> > // Everything
They're <x, y, z> coordinates.
http://wiki.povray.org/content/Reference:Vector_Expressions#Functions
Date: 14 Jul 2020 22:11:46
Message: <5f0e65e2@news.povray.org>
Hi(gh)!
>>> // Everything
Meanwhile, I found out the reason for the weird position of the terrain
slice: when adding a flattening factor to the calculation of the
vertices, I accidentally deleted the cosine statement for the x
coordinate! I replaced it, and now the terrain is in the correct place -
but I wonder that the texture_list has no effect on its coloring, the
entire relief is black!
I still have a full-resolution (i.e. 3601 by 3601) mesh2 of the Kabul
area rendering correctly, but looking up 3.5 GB of text for the
implementation of the texture is next to impossible...
So here once more the "small" (still some 15,000 lines of code!) mesh2
script generated by my mesh2writer.pov...
Yadgar
Download 'utf-8' (295 KB)
Date: 15 Jul 2020 02:29:22
Message: <5f0ea242@news.povray.org>
Op 15/07/2020 om 00:35 schreef Jörg "Yadgar" Bleimann:
As for the docs, the best you can do is use this:
http://wiki.povray.org/content/Reference:Keywords
the wiki docs are the most up to date. Looking up the Keywords is
fastest. I use this almost on a daily basis.
Date: 15 Jul 2020 06:25:00
Message: <web.5f0ed8b02c156900fb0b41570@news.povray.org>
A mesh of one or two triangles can be placed in exactly the same places as one
of 3601 x 3601 triangles.
Put very simple, fast objects in place when testing.
Get it work and work well (change up some of the numbers to verify your
hard-coded assumptions) and then save a copy of the working code somewhere.
If the texture definition is gigantic, trim it down to a simplistic
representation and see what the pattern modifiers are doing.
Do that, and I'll bet you'll find the problem in no time.
Date: 15 Jul 2020 07:25:01
Message: <web.5f0ee6652c156900fb0b41570@news.povray.org>
#declare F_Earthslice = finish {ambient 0.05 diffuse 1 brilliance 0.25 }
ambient 0.05 seems incredibly low, but diffuse 1 ought to be fine.
This leads me to question: Where is your light source and at what angle does it
impinge upon the surface?
Render a shadowless cylinder from your light source location to the
ApproxLook = <-3347983.0848,4226003.8087,3406932.3387>;
vector to see for sure.
Right now you're flying blind and feeling around in the dark.
