POV-Ray : Newsgroups : povray.binaries.images : Our turbulence distribution moves with omega. Server Time
9 Oct 2026 21:57:30 EDT (-0400)
  Our turbulence distribution moves with omega. (Message 1 to 14 of 14)
Subject: Our turbulence distribution moves with omega.
Date: 20 May 2020 14:00:56
Message: <5ec57058$1@news.povray.org>
Working on an in-buit f_turb and think I finally tracked down an issue
which has harassed me for years.
Our turbulence moves with omega. This looks not right to me given what I
understand Brownian Motion to be. The code is effectively unchanged
since it was added in v3.0. I'd expect with increasing omega for the
distribution to get larger and possibly larger than 1.0 (docs mention
this). What seems amiss to me is the more or less linear shift in the
center of the distribution with omega.
If you don't know turbulence is doing this, using it can be very
confusing. "My isosurface foliage doesn't line up with my iso tree
branches - and everything leans one way!"
The irid (comment there about Turbulence returning 0-1 range) and fog
features use Turbulence() I see. Expect the vector version of turbulence
affected too. Agate of course, though probably hard to see any shift
there - or maybe with any traditional pattern. More shift goes with more
noise typically.
In the attached image created a set up which shows the distribution
moving from a center of 0.25 and range of 0.5 to a center of about 2.0
and a range of 4 as you approach an omega of one. Other settings seem
not to matter much to the distribution, except as looks OK to my eye.
I think the distribution should be centered at 0.1 coming out of
Turbulence() and DTurbulence() and it being a smaller or larger
Gaussian, but...
Making a new f_turb centered and using only that sort of turbulence with
isosurfaces doesn't really fly. I want to exploit the pattern warp stuff
extensively including turbulence.
Anyone know the history with turbulence? Thoughts, opinions?
I've not yet tried to understand why the distribution's center is
moving. I also suspect it's not spreading as much as it should, but I
care about that less.
Bill P.
Download 'turbomegadistributiondistortion.jpg' (135 KB)
Preview of image 'turbomegadistributiondistortion.jpg'
Subject: Re: Our turbulence distribution moves with omega.
Date: 21 May 2020 02:28:30
Message: <5ec61f8e$1@news.povray.org>
I really don't know anything about this but you seem to have found
something. Just a question: I suppose this is also true for:
   warp {turbulence MyTurb}
Personally, I prefer to use the warp version which generates more
interesting results.
Date: 21 May 2020 08:32:49
Message: <5ec674f1$1@news.povray.org>
Yes, the underlying turbulence code is the same.
I think the right thing to do is to center the distribution by default.
Provide a new turbplus turbulence which lets folks control more aspects
of turbulence (scale,direction,...) and a distribution offset.
I'm too lazy to do this with the old default turbulence too, so in povr,
turbulence and the octaves, omega, lamda backdoor methods to 'create'
turbulence will become parse errors. The warp {turbulence ...} method
will become the only supported way for users to create a turbulence
warp/item.
I was thinking some about normal patterns last night with respect to
this issue. The exposure is there too where the texture version of the
same pattern can end up shifted relative to normal one should the omega
values be different. I think what we want is turbulence where things
stay centered where positioned without turbulence - unless the user
specifically wants a shift.
Of course, all supposing I can work out the code for something better.
We'll see.
Bill P.
Date: 24 May 2020 10:22:35
Message: <5eca832b@news.povray.org>
> warp/item.
An update as much to help me be sure I have things straight in my head
as to document.
First, we are not as bad off as I first guessed. All of the vector
related turbulence uses DTurbulence which uses DNoise() and these
already do return a 0.0 centered in a -1 to +1 range. See the attached
image.
This vector behavior is what we want I think. However, it doesn't match
our documentation which says the values are in a 0-1 range for
turbulence. As far as I know there is no user direct access to
non-vector turbulence(1) so even if that were the aim of today's code in
turbulence that's never been what is happening best I can see (some pre
v30 thing maybe?).
(1) - f_vturb() in povr will be this.
I was - more - confused when I posted the initial image. I'd forgotten
that I'd changed my usual axises from +-1 to +-2 - AND scaled the
returned values from Turbulence() by 0.5 trying to see all the
distribution centers. So, the typical distributions from Turbulence
today are all the way out at +4.0 not +2.0 as I said...
In a survey of affected code:
The patterns agate, marble, spiral1, spiral2 where turbulence is used
will be getting violent shifts both on use of turbulence where not a
default and on omega changes. Aside: wood uses turbulence too by in x
and y so DTurbulence() and is OK. The plan is to do nothing with the
affected patterns post Turbulence() change unless something pops.
The finish irid feature assumes a 0-1 distribution and does some math to
get a zero centered, -1 to 1 one for further calculation. It hard codes
the turbulence parameters and has omega at 0.5. This feature has some
other issues like lack of ability to scale relative to the incoming
coordinates which will make it tricky to get something which always
works with respect to scene dimensions. The documentation also mentions
irid_amount and I don't see it anywhere in the calculations... I think
given numerical accuracy there should be some >=0 clamping to not
sometimes get negative thicknesses... Anyway work to do here.
Not tested to confirm, but the fog features using turbulence I suspect
are in bad shape. There is a min(1.0,Turbulence(..)... bit used a ouple
places which I believe will make it very hard to get much turbulence
given the distribution center is way the heck out at 4.0 with defaults!
Up front plan is to make no code changes here. I think the Turbulence()
fix will make fog turbulence better.
Bill P.
Download 'storyvectorturbulence.png' (306 KB)
Preview of image 'storyvectorturbulence.png'
Date: 24 May 2020 12:18:48
Message: <5eca9e68$1@news.povray.org>
Attached an image up the updated irid code running with the fixed
Turbulence(). I also added the clamp to prevent the film thickness from
going below 0.0 and one of our demo scenes hits this clamp. See the
lower right sphere in the middle set. Less colorful result but I think
correct. There is no film there.
I also tried for a matching fudge factor to match the breadth of the old
Turbulence() distribution. Cannot match previous precisely, but not bad
in my view.
Bill P.
Download 'iridturbulencedistfixandclamp.jpg' (72 KB)
Preview of image 'iridturbulencedistfixandclamp.jpg'
Date: 24 May 2020 12:20:01
Message: <web.5eca9df89f5cc729fb0b41570@news.povray.org>
I (and likely others) would like some way to better understand the distribution
of values in the pigment patterns.   That's from the perspective of "I would
like a bit more of THAT tone in my wood pattern ....   so what portion of my
texture map do I need to adjust...?"
I bring that up because I'm trying to envision omega, octaves, lamda, etc, and
I'd need a graph of that to better understand what knobs to fiddle with when I'm
crafting a turbulated pattern.
Specifically with respect to noise and turbulence, and the range of values that
functions return, it would be nice to have a way to know or be reminded that an
inbuilt function, where the calculations are invisible to the user, deviate from
a 0-1 range.
I'd say that from an isosurface perspective, it would be MOST helpful in
determining where to set the threshold, or what to subtract from the equation in
order to get a zero-value surface.
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.2#Noise_and_pigment_functions
"Using this simple noise3d function results in the image on the right. The value
-0.5 matches the default threshold value of zero. The f_noise3d function returns
values between 0 and 1:
function { f_noise3d(x,y,z)-0.5 }"
(Most folks would be tempted to just use noise and a 0 threshold, and then waste
a lot of time trying to "debug" the isosurface object.
> The finish irid feature ....
> ... This feature has some
I would very much like a function that "scales space" prior to passing world
space cooordinates into functions.
Having had to grapple with that issue, I'm wondering what the best
implementation of that would be.  I'm also curious what your approach is when
you use functions.
I haven't figured out how to graph a function with the native (x,y,z) - so I
define all my functions with capitals, which just act as containers for the
lowercase I pass to it on invocation.
Then I can graph them using a #for (X, 0, tau) loop ....
Yeah - iridescence seems ... "special".
Using Iridescence
"Iridescence is what we see on the surface of an oil slick when the sun shines
on it. The rainbow effect is created by something called thin-film interference
(read section Iridescence for details). For now let's just try using it.
Iridescence is specified by the irid statement and three values: amount,
thickness and turbulence. The amount is the contribution to the overall surface
color. Usually 0.1 to 0.5 is sufficient here. The thickness affects the busyness
of the effect. Keep this between 0.25 and 1 for best results. The turbulence is
a little different from pigment or normal turbulence. We cannot set octaves,
lambda or omega but we can specify an amount which will affect the thickness in
a slightly different way from the thickness value. Values between 0.25 and 1
work best here too."
> I think
maybe abs() ?
yeah wow - that's WAY out there...
Date: 24 May 2020 12:24:46
Message: <5eca9fce$1@news.povray.org>
>> always works with respect to scene dimensions. The documentation also
>> mentions irid_amount and I don't see it anywhere in the
>> calculations...
Forgot to mention documentation's irid_amount gets mapped to just 'irid'
in the code. It's there.
Bill P.
Date: 24 May 2020 12:58:38
Message: <5ecaa7be$1@news.povray.org>
> a 0-1 range.
I agree, more inbuilt ability to see the value distributions is needed.
It would, over the years, have saved me huge chunks of time - especially
where POV-Ray has been wrong! Not yet quite sure how to approach it in a
practical sense. By adding functions like f_turb() I am making
accessible what's not been, but that's just a piece of what is needed.
I think pretty much always have the threshold at 0.0 for best
interoperability of functions. Subtract or add to the function to get to
a zero values surface as you say. Aside: I think putting out a bunch of
canned functions with thresholds all over the place mostly makes things
more difficult for typical users. I get why mathematicians would think a
non-zero threshold capability a good idea, but in a tool like POV-Ray
it's mostly a bad one.
Yep, agree.
This was an aim of the new to povr pattern_modifiers {} keyword.
> you use functions.
I used to do loops more often; creating spheres and such to represent
value regions. More though, I'm using functions as pigments - partly
reasons for raw_wave and function_interval wave modifier keywords in
povr. The blend functions support ranges other than 0-1, but the wave
form modification code in POV-Ray proper clamps and modifies values to
always be in a 0-1 range... Even with the new functionality in povr, it
still means remapping or collapsing the values into a more workable ranges.
Yep...
So, you taken any more runs at the elliptical_torus? I hate the thing
now! It seems like it should be doable (even not that hard), so I keep
taking runs at it - and I just cannot get it... :-)
Bill P.
Date: 24 May 2020 13:50:00
Message: <web.5ecab3009f5cc729fb0b41570@news.povray.org>
Agreed.   Certainly the mapping of the pigments with the function values helped
me understand that more, as did writing out / copying all of the source code
pigments into SDL (the easy ones  ;) ).
Yes, and I need to work on my idea of casting out a bit and searching for a more
suitable level set value, if the user-defined one is chosen badly.
Ah, excellent.  :)
> povr.
I have started to do that more myself, having recognized the value and ease of
it.  :)
I was starting to do more of that here, but I needed some education and
direction:
http://news.povray.org/povray.advanced-users/thread/%3Cweb.5ec33c80cab151a1fb0b41570%40news.povray.org%3E/
The above thread was part of my effort to get a more solid footing, and I sent
out an email to a math/comp sci professor - which has yet to be acknowledged or
replied to.  I will try spamming a few more ivory tower academics...  ;)
The radius gets elliptified as one increases the eccentricity.   So maybe one
way to approach it is to figure out what terms to add in to negate that
effect...
define the minor radius as an ellipse, and do the adjustments there...
I had an entrepreneurial business project I got roped into, so I've been coding
a bunch of stuff and had an all-nighter or two, so that's eaten up a bunch of
time and energy lately.   As you say - it _looks_ like it should be SO easy....
 so I won't be able to let it go, will I?   ;)  :D
Date: 24 May 2020 14:05:01
Message: <web.5ecab7179f5cc729fb0b41570@news.povray.org>
I'm this doesn't make things any easier to follow:
http://wiki.povray.org/content/Reference:Warp#Turbulence
Turbulence
The turbulence pattern modifier is still supported for compatibility issues, but
it is better nowadays to use the warp turbulence feature, which does not have
turbulence's limitation in transformation order (turbulence is always applied
first, before any scale, translate or rotate, whatever the order you specify).
For a detailed discussion see Turbulence versus Turbulence Warp
The old-style turbulence is handled slightly differently when used with the
agate, marble, spiral1, spiral2, and wood textures."
I'm thinking that maybe with tools like Wolfram or ShaderToy that are capable of
doing very fast calculation and visualization, some POV-Ray functions can be
represented, and values can be adjusted with sliders.   Just to get the general
idea, and fast, interactive RT feedback
Date: 25 May 2020 02:33:52
Message: <5ecb66d0@news.povray.org>
Op 24/05/2020 om 18:16 schreef Bald Eagle:
[snip]
[snip]
> Using Iridescence
I am probably wrong, but I seem to recall that Christoph did some
massive work in overhauling iridescence a number of years ago...? Indeed
in 2011:
http://news.povray.org/povray.binaries.images/thread/%3C4ed6f24c@news.povray.org%3E/
...there should be more about this.
Or is this unrelated to the present problem?
Date: 25 May 2020 08:38:09
Message: <5ecbbc31$1@news.povray.org>
> [snip]
> [snip]
>> Using Iridescence
>> sun shines
>> interference
>> overall surface
>> the busyness
>> turbulence is
>> octaves,
>> thickness in
>> and 1
> in 2011:
Thank you for the newsgroup pointer.
His updates - assuming they are the code I see - are tangle with this
problem because Turbulence() wasn't - or isn't now in any case -
returning the distribution and range assumed in the code.
Christoph's changes were - I believe made for the v37 release. The
documentation notes changes to actual physical dimensions for v37(1).
Which, on more thought, means I need to yank my fudge matching, magic
factor back out of the code and update the scenes for the proper end
thicknesses given the turbulence instead!
He mentions being unable to scale for the same effect - which I believe
is correct with respect to the viewer frame. I'm suggesting when using
turbulence adding some method to scale and/or shift the turbulence of
the thickness a good idea given the difficulty matching up with changing
scene scaling of some object. Like media and density, if you want the
turbulence to be constant (maybe yes, maybe some, maybe no) you'd need
to 'counter' adjust it in some way on scene scaling - we cannot do this.
(1) The documentation in r3_6.html#r3_6_1_3_7 has this 3.7 note:
"Note: The version 3.7 iridescence feature has had a major overhaul. The
syntax remains the same, however, both the thickness and amount values
are now specified in microns. Consequently, iridescence effects will
vary from previous versions."
which emphasizes 'both' thickness and amount being in microns. The
'thickness amount' is, and the 'turbulence amount' is, but the
irid_amount is just a color intensity multiplier for the irid_wavelength
color specified in global_settings. We could likely help new to irid
users by making this clearer.
The "See also the global setting Irid_Wavelength for additional
information." sentence I think should probably be up in the paragraph
with irid_amount because - indirectly - this is the 'amount' of color,
color to which it's related.
Anyway, this rushed so apologies for the mistakes. Off to real life for
a few days. Thanks again for the prompt. I need to yank that fudge
factor in my povr code.
Bill P.
Date: 3 Jun 2020 14:52:55
Message: <5ed7f187$1@news.povray.org>
> in my view.
In povr, irid updated to yank fudge factor and scenes updated with
accurate base thicknesses. Thanks Thomas.
When I looked at the fixed internal turbulence() with fog picked up
additional bugs I expect kept folks from doing a lot especially with
turbulence (copy constructor was creating new, but not copying old
turbulence values, for example).
Anyway. In povr I've got the turbulence() fix in - with fixes to irid
and a significant re-work of fog updating and adding features/keywords.
Image attached showing some of the fixed and extended features.
The agate pattern looks different, but OK, with the turbulence() fix.
Not looked in detail at marble or the two spiral patterns as yet. Still
some f_turbulence() work to finish off.
Bill P.
Download 'fogstory.jpg' (148 KB)
Preview of image 'fogstory.jpg'
Date: 4 Jun 2020 02:27:56
Message: <5ed8946c$1@news.povray.org>
Well done, sir. Keep up the good work!
