Who can help me to put an image on ONE side of a box.
#declare Tegel_1 =
box { <100, -9, 100>, <-100, 0, -100>
image_map {
gif "vintage-40-vloertegel.gif"
map_type 1
once
scale 1
The image is: vintage-40-vloertegel.gif
The result is: test_01.png
Download 'vintage-40-vloertegel.gif' (7 KB)
Download 'test_01.png' (21 KB)
Preview of image 'vintage-40-vloertegel.gif'
Preview of image 'test_01.png'
Am 2/19/20 11:47 AM, also sprach Wijnand:
> #declare Tegel_1 =
> pigment {
> image_map {
> map_type 1
> once
> scale 1
union {
box { <0, 0, 0.01>, 1 texture {pigment {White}}}
box { 0, <1, 1, 0.011>
image_map {gif "vintage-40-vloertegel.gif"}
dik
Rendered 49,882,521,600 of 49,882,521,600 pixels (100%)
Download 't2.png' (26 KB)
Preview of image 't2.png'
Op 19-2-2020 om 19:15 schreef Dick Balaska:
> union {
> pigment {
Thanks a lot, regards...
Op 19-2-2020 om 23:17 schreef Wijnand:
>> union {
>> pigment {
Hello Dik (?),
Strange... I have made some changes to use your example for a set of
tiles in cm (20x20x0.9 cm). The right one is yours, the left one my
trial. Look the motive is split up in 4 parts and the parts are moved. ???
My source:
location < 0, 50, 0>
look_at < 0, 0, 0>
object {
light_source {<-100,100,-100> color White }
#declare Tile_2 =
union {
box { <-0.5, -0.5, 0.045>,< 0.5, 0.5, 0.01> texture {pigment {White}}}
box { <-0.5, -0.5, 0.0 >,< 0.5, 0.5, 0.00001>
image_map {gif "vintage-41-randtegel.gif"}
rotate<90,0,0>
// scale 20
#declare Tile_5 =
union {
rotate<90,0,0>
object { Tile_2 scale 20 rotate <0,180,0> translate <-20,0,0>}
object { Tile_5 scale 20 translate <10,0,-10>}
Download 'tiles_1.png' (135 KB)
Preview of image 'tiles_1.png'
Op 20-2-2020 om 16:41 schreef Wijnand:
>>> union {
>>> pigment {
> Hello Dik (?),
> My source:
> camera {
> look_at < 0, 0, 0>
> object {
> #declare Tile_2 =
> union {
> pigment {
> rotate<90,0,0>
> // scale 20
> #declare Tile_5 =
> union {
> pigment {
> rotate<90,0,0>
Found it, an image_map starts alway at <0,0,0>.... Grrr.
> #declare Tegel_1 =
> pigment {
> image_map {
> map_type 1
> once
> scale 1
map_type 1 is used to map the image on a sphere.
You want to use map_type 0, the default.
It maps the image in a tiling fashion along the X-Y plane.
So, it becomes :
#declare Tegel_1 =
box { 0, 1 //from <0,0,0> to <1,1,1>
image_map {
gif "vintage-40-vloertegel.gif"//use default mapping
translate <-0.5, -0.5, 0>// centre it
rotate 90*x // flip to the X-Z plane
scale <200, 9, 200> // scale to the desired dimention
Subject: Re: How to put an image on ONE side of a box
Date: 21 Feb 2020 07:10:53
Message: <5e4fc8cd@news.povray.org>
Op 20-2-2020 om 21:49 schreef Alain Martel:
>> #declare Tegel_1 =
>> pigment {
>> image_map {
>> map_type 1
>> once
>> scale 1
> So, it becomes :
> #declare Tegel_1 =
> pigment {
> image_map {
Thanks again, regards...
