POV-Ray : Newsgroups : povray.binaries.images : High Glen - take #3 (final) Server Time
28 Nov 2026 18:45:54 EST (-0500)
  High Glen - take #3 (final) (Message 1 to 25 of 25)
Subject: High Glen - take #3 (final)
Date: 10 May 2019 02:57:21
Message: <5cd520d1@news.povray.org>
Last February, I presented some early renders of this scene. It has now
been "finished" (my scenes are never finished).
Download 'high glen_final.jpg' (652 KB)
Preview of image 'high glen_final.jpg'
Subject: Re: High Glen - take #3 (final)
Date: 10 May 2019 09:07:54
Message: <5cd577aa$1@news.povray.org>
I like the atmosphere/mood.
Supposing the individual is using a variation of an Alphorn?
Bill P.
Date: 10 May 2019 10:20:33
Message: <5cd588b1$1@news.povray.org>
Am 10.05.2019 um 15:07 schrieb William F Pokorny:
Looks like a lur to me.
Date: 10 May 2019 10:27:43
Message: <5cd58a5f@news.povray.org>
Thanks and yes more likely. The Lur is a new instrument to me.
Bill P.
Date: 10 May 2019 11:55:01
Message: <web.5cd59e6a2ad5c3dd3c1c78400@news.povray.org>
> Thomas
The sky is really nice - how did you made it?
Norbert
Date: 10 May 2019 15:12:02
Message: <5cd5cd02$1@news.povray.org>
Is this related to your Mistborn series?
Date: 10 May 2019 20:35:00
Message: <web.5cd618af2ad5c3dd15b36e3c0@news.povray.org>
> Thomas
Good atmosphere, some guard welcoming the new morning.
One day I'll finish a scene!
Ton.
Date: 11 May 2019 02:52:38
Message: <5cd67136$1@news.povray.org>
> Bill P.
It is indeed a lur.
Date: 11 May 2019 03:06:23
Message: <5cd6746f@news.povray.org>
>> Thomas
> Regards,
> Norbert
Three elements compose the sky (and atmosphere) from base to top:
1) a ground fog, slightly tilted to fill the distant valleys more);
2) An atmospheric haze;
3) a cloud layer.
All three are made up of non-interpenetrating media. The code looks like
this (watch out for unwanted line feeds!):
//--start code------------------------------------------
#if (Atmos)
// An atmosphere composed of a ground fog and an haze:
#local Murkiness = 1.5; //best somewhere between 0.5 and 2.9 approximately
#local GroundFog =
difference {
   sphere {<0,0,0>, 6.0}
   plane {<0,1,0>, 0.0}
   scale <1, 0.14/6, 1>
   //scale 5000
   rotate -1.5*x
#if (Debug)
#declare Min = min_extent(GroundFog);
#declare Max = max_extent(GroundFog);
#debug concat("\n  min_extent GroundFog: <",vstr(3, Min, ", ", 0,3),">\n")
#debug concat("  max_extent GroundFog: <",vstr(3, Max, ", ", 0,3),">\n\n")
#local Haze =
difference {
   scale <1, 0.15/6, 1>
   //scale 5000
   rotate -1.5*x
   translate 0.14002*y
#if (Debug)
#declare Min = min_extent(Haze);
#declare Max = max_extent(Haze);
#debug concat("\n  min_extent Haze: <",vstr(3, Min, ", ", 0,3),">\n")
#debug concat("  max_extent Haze: <",vstr(3, Max, ", ", 0,3),">\n\n")
#declare Atmosphere =
union {
   object {
     GroundFog
     hollow
     pigment {rgb <1,1,1> transmit 1.0}
     interior {
       media {
         scattering {5 rgb <0.6, 0.6, 0.8>*Murkiness/5000 extinction 1.0
           eccentricity 0.01
         samples 20
         density {
           spherical
           density_map {
             [0.00 rgb 0.1]
             [0.45 rgb 1.0]
             [0.50 rgb 0.1]
             [0.60 rgb 0.1]
             [0.65 rgb 0.9]
             [1.00 rgb 1.0]
           scale 11
           warp {turbulence <2.0, 3.0, 2.0>}
           scale <1.0, 1.0, 2.0>
           scale 1/11
     scale 5000
     translate <CamLoc.x, 0.0, CamLoc.z>
   object {
     Haze
     hollow
     interior {
       media {
         scattering {5, rgb <1,1,1>*0.10/5000
           eccentricity 0.4
         samples 20
         density {
           spherical
           density_map {
             [0.00 rgb 1.0]
             [0.90 rgb 0.0]
     scale 5000
} //end of Atmosphere union
#if (Debug)
#declare Min = min_extent(Atmosphere);
#declare Max = max_extent(Atmosphere);
#debug concat("\n  min_extent Atmosphere: <",vstr(3, Min, ", ", 0,3),">\n")
#debug concat("  max_extent Atmosphere: <",vstr(3, Max, ", ", 0,3),">\n\n")
Atmosphere
#end  //of Atmos
#if (Clouds)
#local CloudScale = 1000*10;
#declare Density_in =
density {
	wrinkles
	frequency 4
   color_map {
     [0.30 rgb <0.00, 0.00, 0.00>]
     [0.48 rgb 0.9]
     [0.52 rgb 0.9]
     [0.70 rgb <0.00, 0.00, 0.00>]
   scale 0.5
	//rotate 90*x	//when using spirals; either here or:
   scale 30
   warp {turbulence <3, 4, 2>*0.9}
   scale 1/30
	//rotate 90*x	//when using spirals; here
#declare Density_out =
density {
#declare CloudScape =
   difference {
     sphere {0, 1.0}
     sphere {0, 0.75}
     hollow
     material {
       texture {pigment {rgb 1 transmit 1.0} finish {ambient 0 diffuse 0}}
       interior {
         media {
           // (---general values---)
           intervals 1
           samples 50
           //absorption rgb <0.5, 0.5, 0.5>*0.00001/CloudScale
           scattering {1, rgb <1, 1, 1>*8.00/CloudScale}
           // (---density---)
           density {
             spherical
			  	  density_map {
			  	    [0.1 Density_out]
				      [0.9 Density_in]
				    warp {turbulence 0.3}
			  	  scale 1
   scale CloudScale
   scale <5, 1.0, 5>
	rotate -20*z
   rotate 15*y
   translate <CamLookAt.x, CamLoc.y, 0>
CloudScape
#end  //of Clouds
//--end code------------------------------------------
Date: 11 May 2019 03:09:22
Message: <5cd67522@news.povray.org>
>> now been "finished" (my scenes are never finished).
Wow! you have an excellent memory! ;-)
In reality, the Mistborn series has been a bit still-born I am afraid,
in so far that I have not been able to do something really serious about
it. But, yes, now that you mention it, I think this scene could very
well be included into the series. Thanks for reminding me!
Date: 11 May 2019 03:12:16
Message: <5cd675d0$1@news.povray.org>
>> Thomas
> Cheers
> Ton.
Thanks indeed. That is exactly the mood I wanted to convey. While
working on the scene, I could feel (again) the chill and dampness of an
early spring/summer day up in the mountains.
Date: 11 May 2019 08:35:01
Message: <web.5cd6c16d2ad5c3dd3c1c78400@news.povray.org>
> > Regards,
> > Norbert
> 3) a cloud layer.
> Thomas
This sky is slow, but gives fantastic results - surely it was hard work to get
it right.
Many thanks for it. In fact, its beauty reminds me a bit of an old Mick
Hazelgrove source (cannot find it on the server) - Kingz. Here is my last
interpretation of his sky code (of course it would need work on the bottom of
the cloud container...).
Norbert
Download 'king37c.jpg' (569 KB)
Preview of image 'king37c.jpg'
Date: 11 May 2019 12:33:10
Message: <5cd6f946$1@news.povray.org>
Not so much excellent as unevenly distributed.  People tell me I'd make
an excellent Jeopardy! contestant.  (Jeopardy! is an American game show
dealing with knowledge trivia.)  But when it comes to things that matter
in real life, I have lifelong CRS (and now I'm at that age when I don't
know if it's CRS or "senior moments").
Date: 11 May 2019 18:36:19
Message: <5cd74e63$1@news.povray.org>
Hi(gh)!
On 11.05.19 08:52, Thomas de Groot wrote:
> It is indeed a lur.
...oh, and he's got long red hair! Lovely, a true Celt! What's his name?
See you in Khyberspace!
Yadgar
Now playing: Since The Last Goodbye (The Alan Parsons Project)
Date: 12 May 2019 02:44:00
Message: <5cd7c0b0$1@news.povray.org>
>>> Regards,
>>> Norbert
>> 3) a cloud layer.
>> Thomas
> it right.
The speed is acceptable I guess. I have used other media skies which
were much slower, Abe's for instance. Mick's clouds code is truly great
indeed. I have used it a couple of times for dramatic effects. I should
revisit it...
Date: 12 May 2019 02:49:27
Message: <5cd7c1f7$1@news.povray.org>
On 12-5-2019 0:37, Jörg "Yadgar" Bleimann wrote:
> Hi(gh)!
>> It is indeed a lur.
I have not been introduced to him, so I do not know his name
unfortunately. Many Celts were black haired by the way ;-)
Date: 12 May 2019 02:50:51
Message: <5cd7c24b$1@news.povray.org>
Well, "senior moments" is something I am quite familiar with... :-)
Date: 12 May 2019 16:41:14
Message: <5cd884ea$1@news.povray.org>
Is there ANY on-trivial scene that is ever truly finished ?
Date: 12 May 2019 16:44:07
Message: <5cd88597$1@news.povray.org>
>> Hi(gh)!
>>> It is indeed a lur.
Yes, but the soap they used to wash them tended to make them turn some
other colour, like blond or some red/redish shades.
Date: 13 May 2019 02:55:40
Message: <5cd914ec$1@news.povray.org>
> Alain
I guess not.
Date: 13 May 2019 07:05:01
Message: <web.5cd94e902ad5c3ddb81657640@news.povray.org>
> > > Regards,
> > > Norbert
> > 3) a cloud layer.
> > Thomas
> it right.
> Norbert
Could I have the source?
Date: 14 May 2019 07:34:44
Message: <5cdaa7d4@news.povray.org>
>>>> Regards,
>>>> Norbert
>>> 3) a cloud layer.
>>> Thomas
>> it right.
>> Norbert
This is the original file from Mick Hazelgrove. I cannot find the ng post.
Download 'mh_clouds_original.zip' (2 KB)
Date: 16 May 2019 10:45:01
Message: <web.5cdd76952ad5c3dd42f09b400@news.povray.org>
> >>>> Regards,
> >>>> Norbert
> >>> 3) a cloud layer.
> >>> Thomas
> >> it right.
> >> Norbert
> Thomas
Thanks!
Date: 18 May 2019 03:18:52
Message: <5cdfb1dc$1@news.povray.org>
If it hasn't been mentioned already, leaning the spears against the wall
at an angle like that is probably bad because of the risk of tripping
over them in an emergency. Better to lay them on the ground (wrapped in
canvas) or lean them upright against a stand or something. IMO.
Michael
Date: 18 May 2019 07:00:36
Message: <5cdfe5d4$1@news.povray.org>
I shall transmit to the High Command. :-)
