POV-Ray : Newsgroups : povray.binaries.images : Improving David Gemelli's Maze Solver Server Time
10 Apr 2026 02:24:42 EDT (-0400)
  Improving David Gemelli's Maze Solver (Message 1 to 4 of 4)
Subject: Improving David Gemelli's Maze Solver
Date: 4 May 2019 12:08:36
Message: <5ccdb904@news.povray.org>
Hi(gh)!
As the original recursive version of the Maze Solver frequently yielded
"Too many nested macros" errors, I started to re-program it in an
iterative fashion. I pretty soon discovered that I had to add a dead end
detection and thus also to keep track of the already travelled path. I
also found out that I had to swap x and y labyrinth coordinates...
But still a strange bug occurs: after running several times into a dead
end (rendition of the last run attached here), the program does not
advance beyond field <22, 1> (marked in the image with a green cross),
although the situation is nowhere different from the short southern dead
end encountered earlier in the path.
To give a better overview about the path taken by algorithm. I added
#warning outputs of the current path counter value as well as of the
current field coordinates; to avoid endless loops, I also limited the
number of macro calls (preliminarily, after debugging, this should not
be necessary anymore).
The main program and the maze data are also attached here.
See you in Khyberspace!
Yadgar
Download 'mazenew_bug.png' (458 KB) Download 'maze.inc.txt' (3 KB) Download 'mazesolver_new.pov.txt' (6 KB)
Preview of image 'mazenew_bug.png'
Subject: Re: Improving David Gemelli's Maze Solver
Date: 4 May 2019 12:41:04
Message: <5ccdc0a0$1@news.povray.org>
Hi(gh)!
I did not save the last changes to the Maze Solver main script... here
it is!
Yadgar
Date: 4 May 2019 13:15:00
Message: <web.5ccdc821c05257c64eec112d0@news.povray.org>
Maybe you should check out this and see if it provides any clues and/or
inspiration.
https://www.youtube.com/watch?v=HyK_Q5rrcr4
Date: 4 May 2019 13:29:46
Message: <5ccdcc0a$1@news.povray.org>
Hi(gh)!
> inspiration.
Probably not, as it is about a maze generator rather than a maze solver
- and when he mentioned the "recursive backtracker" within the first 20
seconds, I stopped the video as I do not want to use recursion - because
this was the very weakness of David Gemelli's original code!
Yadgar
