Subject: Apparent circular pattern of scratches
Date: 25 Jan 2019 07:21:57
Message: <5c4aff65@news.povray.org>
See at same subject in povray.advanced-users.
OK. This is the best I can do presently.
Download 'circular scratches_test.png' (457 KB)
Preview of image 'circular scratches_test.png'
Subject: Re: Apparent circular pattern of scratches
Date: 25 Jan 2019 07:34:59
Message: <5c4b0273@news.povray.org>
While increasing the bump_size.
Download 'circular scratches_test.png' (719 KB)
Comming along nicely.
It still has a bit of 'leathery' quality to it, less metallic. Maybe it's
the size/width of the scratches that give that impression,
ingo
Which is indeed very nice. :)
> ingo
Yes, I would say that probably the real test would be something like a
transparent piece of plastic or a dark plastic/glass, where there are in reality
a lot of scratches, but optically, only a few of these are ever really visible
at any given time - depending on the viewing angle.
So, sparser, finer scratches, and perhaps an animation where the object is
rotated a bit to see how a changing incident light angle affects the look.
Still, this has developed to a usable form for a lot of scenes in a very short
time. Great work! :)
Am 25.01.2019 um 19:29 schrieb Bald Eagle:
>> ingo
I think one important feature overlooked so far may be that the
scratches are presumably rough (in all directions, not only in cross
section), while the remainder of the surface is rather smooth; so you'd
either need different finish properties for the scratches (with larger
highlights), or you'd have to somehow add a bit of noise to the scratches.
>>> it's
>>> ingo
>> in reality
>> visible
>> object is
>> look.
Gentlemen, you are perfectly correct regarding these suggestions. We now
enter the domain of subtlety and craftiness indeed. Let's see what we
all come up with.
Date: 26 Jan 2019 03:56:25
Message: <5c4c20b9@news.povray.org>
Proof of concept using different finishes for surface and scratches.
Still in flux...
Download 'circular scratches_test.png' (506 KB)
Date: 26 Jan 2019 07:10:38
Message: <5c4c4e3e@news.povray.org>
... and fulling following "The Teachings of Clipka" (Scroll 24F, Chapter
"On Metals and their Finish").
Download 'circular scratches_test.png' (519 KB)
> Still in flux...
The scratches are based on the random sticks? If so, try uses extremely
stretched boxes as sticks to get a sharper 'impression'.
Maybe use a gradient 'depth map' texture on the sticks, the scratichg edge
rgb 1 and going to rgb 0 to the other edges. Vary the rgb 1 on the sharp
edge for depth variation.
Render it with orthocam and a light at the camera location.
ingo
Hello,
here is my attempt, using a layered texture and an imagefile for the scratches
(similar to what Thomas posted here -
http://news.povray.org/povray.advanced-users/message/%3C5c4970bb%40news.povray.org%3E/#%3C5c4970bb%40news.povray.org%3E
material {
pigment {color srgb <0.9284,0.9016,0.8678>}
normal {
average
normal_map {
[1 bump_map {png "scratches"}
bump_size -1
bump_size -1
rotate x*90
bump_size -1
rotate z*90
accuracy 0.003
finish {
ambient 0
diffuse 0.1
specular 1
roughness 0.0003
phong 0.5
phong_size 10
brilliance 3
reflection {0.6, 1 fresnel on metallic}
conserve_energy
pigment {color srgbf <0.96,0.965,0.975,0.99/0.8>*0.8}
finish {
ambient 0
diffuse 0.05
reflection {0, 1 fresnel on}
conserve_energy
specular albedo 0.5
roughness 0.001
brilliance 7
interior {ior 3.64}
scale 1
Reorient_Trans (z, 1)
Norbert
Download 'scratch finish on metallic surfacea.jpg' (684 KB)
Preview of image 'scratch finish on metallic surfacea.jpg'
Am 26.01.2019 um 09:56 schrieb Thomas de Groot:
> Still in flux...
I think we're getting somewhere.
"Norbert Kern" <nor### [at] t-online de> wrote:
> Hello,
3E
> material {
> texture {
> normal {
> average
> normal_map {
> bump_size -1
> bump_size -1
> rotate x*90
> bump_size -1
> rotate z*90
> accuracy 0.003
> finish {
> ambient 0
> diffuse 0.1
> specular 1
> roughness 0.0003
> phong 0.5
> phong_size 10
> brilliance 3
> conserve_energy
> texture {
> finish {
> ambient 0
> diffuse 0.05
> conserve_energy
> specular albedo 0.5
> roughness 0.001
> brilliance 7
> interior {ior 3.64}
> scale 1
> Norbert
I like that, fine scratches or scuffed. Great how it follows the curvatures and
reflected light.
Any criticism I can think of would be that some lines appear to radiate outward
from the lit areas, showing up as bright as the other, non-radial lines. Which
is what was mentioned before about the original idea, so I wonder how that
directional condition could be achieved? Seems like a polarization effect needed
to do that anyhow.
> > Hello,
> > Norbert
Holy crap. :O
> reflected light.
I think that's an important part of the effect - the halo of concentric
scratches.
> to do that anyhow.
Yeah - I'm also still very curious as to what gives rise to that selective
effect IRL. I'd be tempted to predict that only a series of oriented lines
would reflect strongly - not a circular pattern. I mean, it's not like
completely random scratches adopt a circular pattern - so it must necessarily be
a purely optical effect.
>> Still in flux...
No, on a bump_map. Not a very subtle one I must say but sufficient for
the purpose.
That is a good alternative for making scratch maps, apart from simply
downloading them from the web :-)
> ingo
Date: 27 Jan 2019 02:52:48
Message: <5c4d6350@news.povray.org>
>>> Hello,
>>> Norbert
> Holy crap. :O
I agree. The important thing is to use a bump_map of some quality.
>> reflected light.
> scratches.
See image attached. Playing with different bump_maps and strength of the
bump_size.
>> to do that anyhow.
Maybe, that comes from the fact that the scratches are not very linear,
more "curvy" as it were. I noticed that also with different bump_maps.
The more linear the scratches are, the more the effect is visible.
It /is/ an optical effect of course, based imho on the strength of
incident light reflecting from the scratch surfaces. The closer the
incident light angle is to 90 degrees with regard to (part of) the
scratch surface, the stronger the scratch reflects. Inversely, the
scratch will hardly or not light up when the incident light angle is
very low. The cumulation of strongly reflecting scratches will dominate
the view in the end, giving rise to the optical illusion.
Download 'circular scratches_test.png' (427 KB)
I found a povray file to get the bump_map. Perhaps somebody knows the origin. My
only contribution is an aoi texture as default.
/* scratches2 */
// +fn16 Output_File_Name=d:\images\ +w4096 +h4096
#version 3.7;
global_settings {
#declare a_g = 2.2;
assumed_gamma a_g
max_trace_level 16
noise_generator 3
orthographic
location -5*z
look_at 0
right 40*x
up 40*y
/*#default {
bozo
scale 0.2
color_map {
[0 rgb 0.5]
[1 rgb 1]
finish {ambient 1}
#default {
aoi
color_map {
[0 srgb 1]
[0.5 srgb 0]
[1 srgb 1]
finish {ambient 1}
#include "transforms.inc"
#declare I = seed (1);
#declare ang = 0;
#while (ang < 360)
#declare num = 20+20*rand (I);
#declare i = 0;
#while (i < num)
#declare px = no;
#declare nx = no;
#declare r = 0.01+0.035*rand (I);
#declare s = 2+10*rand (I);
#declare _x = -20+40*rand (I);
#declare _y = -20+40*rand (I);
sphere {
0, 1
scale <r,0.5,r>
scale <1,s,1>
rotate ang*z
translate <_x,_y,0>
#if (vtransform (0.5*y, transform {scale <1,s,1> rotate ang*z
translate _x*x}).x > 40 | vtransform (-0.5*y, transform {scale <1,s,1> rotate
ang*z translate _x*x}).x > 40)
#declare px = yes;
sphere {
0, 1
scale <r,0.5,r>
scale <1,s,1>
rotate ang*z
translate <_x-40,_y,0>
#else
ang*z translate _x*x}).x < 40 | vtransform (-0.5*y, transform {scale <1,s,1>
rotate ang*z translate _x*x}).x < 40)
#declare nx = yes;
sphere {
0, 1
scale <r,0.5,r>
scale <1,s,1>
rotate ang*z
translate <_x+40,_y,0>
translate _y*y}).y > 40 | vtransform (-0.5*y, transform {scale <1,s,1> rotate
ang*z translate _y*y}).y > 40)
sphere {
0, 1
scale <r,0.5,r>
scale <1,s,1>
rotate ang*z
translate <_x,_y-40,0>
#if (px)
sphere {
0, 1
scale <r,0.5,r>
scale <1,s,1>
rotate ang*z
translate <_x-40,_y-40,0>
#else
#if (nx)
sphere {
0, 1
scale <r,0.5,r>
scale <1,s,1>
rotate ang*z
translate <_x+40,_y-40,0>
#else
ang*z translate _y*y}).y < 40 | vtransform (-0.5*y, transform {scale <1,s,1>
rotate ang*z translate _y*y}).y < 40)
sphere {
0, 1
scale <r,0.5,r>
scale <1,s,1>
rotate ang*z
translate <_x,_y+40,0>
#if (px)
sphere {
0, 1
scale <r,0.5,r>
scale <1,s,1>
rotate ang*z
translate <_x-40,_y+40,0>
#else
#if (nx)
sphere {
0, 1
scale <r,0.5,r>
scale <1,s,1>
rotate ang*z
translate
<_x+40,_y+40,0>
#declare i = i+1;
#declare ang = ang+20;
Norbert
Ah! Thank you indeed. For a moment I thought it could be Steve Paget as
I have a bump_map with that name from him, but that is a very different
image, not related. The question remains unanswered for now.
