POV-Ray : Newsgroups : povray.binaries.images : Involute spur gear Server Time
28 Nov 2026 18:59:52 EST (-0500)
  Involute spur gear (Message 1 to 33 of 33)
Subject: Involute spur gear
Date: 16 Dec 2018 22:54:17
Message: <5c171de9@news.povray.org>
I would like to make something with gears, but not sure what.
Three of the gears I've cut from sheet metal (thirteen in total) and
some I've modeled.
Comments welcome:
Stephen S
Download 'gears.png' (578 KB) Download 'gear_test0000.png' (33 KB)
Preview of image 'gears.png'
Preview of image 'gear_test0000.png'
Subject: Re: Involute spur gear
Date: 17 Dec 2018 02:25:35
Message: <5c174f6f$1@news.povray.org>
> some I've modeled.
> Comments welcome:
> Stephen S
An Aztec Calendar is what I would attempt.
Date: 17 Dec 2018 02:28:29
Message: <5c17501d$1@news.povray.org>
Is that in the real world you want to do it?
> some I've modelled.
What restrictions do you have in the physical world? Could you make the
gears fine enough to make a clock?
My first thought is an orrery, which could be a clock as well.
https://www.instructables.com/id/Orrery-a-Mechanical-Solar-System-Model-From-Plywoo/
Would you want it to be practical or decorative?
I can see why you are asking for comments. Ideas are not easy to come by.
Great project.
> Comments welcome:
> Stephen S
Regards
Date: 17 Dec 2018 06:41:53
Message: <5c178b81$1@news.povray.org>
Add to list for research ...
Stephen S
Date: 17 Dec 2018 06:47:12
Message: <5c178cc0$1@news.povray.org>
Yes
...Clock gears would be to fine, or the project would have to be to big.
The industrial equipment being used is more for power than detail. Drop
off material I have to work with is under 1 foot square each.
Stephen S
Date: 17 Dec 2018 06:56:23
Message: <5c178ee7$1@news.povray.org>
I had some site info a while back about a gear construct of the
calendar, but somehow the site disappeared or was renamed. I shall look
further...
Date: 17 Dec 2018 08:28:21
Message: <5c17a475$1@news.povray.org>
> Yes
>> the gears fine enough to make a clock?
> ....Clock gears would be to fine, or the project would have to be to big.
Are you sure?
https://www.youtube.com/watch?v=V1lHo8lGhWg
The centrepiece for any workshop
You are talking to someone who thinks a 0 ba spanner is a bit on the
hefty side.
I can't stop thinking about clocks now.
Regards
Date: 17 Dec 2018 09:15:00
Message: <web.5c17af1c540b848f48892b50@news.povray.org>
hi,
> some I've modeled.
(and, you wrote, you have access to further cut offs)
> Comments welcome:
I've always liked mobiles and such, so I'll suggest some kind of "kinetic art"
sculpture/structure/arrangement.
regards, jr.
Date: 17 Dec 2018 10:30:40
Message: <XnsA9BBA7F6DCCF4seed7@news.povray.org>
http://americanhistory.si.edu/collections/search/object/nmah_998869
ingo
Date: 17 Dec 2018 10:34:27
Message: <XnsA9BBA89B98EDBseed7@news.povray.org>
> ingo
http://americanhistory.si.edu/collections/search/object/nmah_861150
search the site for patent model,
ingo
Date: 17 Dec 2018 14:10:00
Message: <web.5c17f3fc540b848f765e06870@news.povray.org>
> some I've modeled.
Nice - good to see you've worked out the undercut on the small gear   :)
Clock
http://www.woodenclocks.co.uk/
Orrery
Antikythera mechanism
Search for Lego videos
centrifuge
thread/rope bobbin winder
apple peeler
hand / foot powered generator
hand drill / egg beater
cider press
pump
winch
cycloid drawing machine / Spirograph / harmonograph
knitting machine
https://www.google.com/search?q=creelman++knitting
paper / sheet metal corrugator
I'm thinking thee's gotta be a pantograph type drawing tool that uses geared
armatures
http://507movements.com/
Date: 17 Dec 2018 15:06:27
Message: <5c1801c3$1@news.povray.org>
Literally LOL.
There is a word for people like you. :P
Regards
Date: 17 Dec 2018 19:00:00
Message: <web.5c18379f540b848f765e06870@news.povray.org>
> Literally LOL.
It's probably in Scottish.  :D
He should still totally do it  :)
https://www.youtube.com/channel/UCworsKCR-Sx6R6-BnIjS2MA
Date: 17 Dec 2018 19:40:38
Message: <5c184206@news.povray.org>
> some I've modeled.
I'll need to wait for more material to show up.
I think I should start with something easier, planetary gears (epicyclic
gears). Then work my way up to something with more parts.
The gears are generated from a web site,
http://hessmer.org/gears/InvoluteSpurGearBuilder.html
I download the .dxf file, feed it into the Plasma Cutter, grind some of
the rough edges.
I model a gear tooth, from the .dxf file, into a prism{}.
Stephen S
Download 'gear_pic_.png' (1127 KB)
Preview of image 'gear_pic_.png'
Date: 17 Dec 2018 19:43:40
Message: <5c1842bc$1@news.povray.org>
The calendar looks like two rings that slide on each other, or am I
seeing it wrong? Gears in stone?
Stephen S
Date: 17 Dec 2018 19:45:28
Message: <5c184328$1@news.povray.org>
...Small arrangement to start I think.
Stephen S
Date: 17 Dec 2018 19:47:46
Message: <5c1843b2$1@news.povray.org>
> ingo
More gears and less other things to start I think.
Stephen S
Date: 17 Dec 2018 19:52:16
Message: <5c1844c0$1@news.povray.org>
I only worked out what web site to download from ;-)
...>... list longer than one life time to complete...
Stephen S
Date: 17 Dec 2018 21:08:51
Message: <5c1856b3@news.povray.org>
...30 tooth inside
4 x 10 tooth outside
Comments Welcome:
Stephen S
Download 'gear_test_a.png' (73 KB)
Preview of image 'gear_test_a.png'
Date: 17 Dec 2018 23:35:28
Message: <5c187910$1@news.povray.org>
StephenS schrieb:
> Comments Welcome:
The gears would be much more impressive if they were moving.
Gregor
Date: 18 Dec 2018 02:49:34
Message: <5c18a68e$1@news.povray.org>
I hate it when I am unable to find back what I am looking for :-/
If I remember well, it consists of three geared wheels, one involute. I
must have a picture somewhere as I intended years ago to make an
animation from it. I keep looking...
Date: 18 Dec 2018 03:05:22
Message: <5c18aa42$1@news.povray.org>
This is the sort of construction which I mean:
https://www.youtube.com/watch?v=BPbZNUd3Vy4
https://www.youtube.com/watch?v=qhWItvjk9Yg
Date: 18 Dec 2018 06:02:24
Message: <5c18d3c0$1@news.povray.org>
I like the first one. I would need to make the pictures for it to have
meaning, not my best area for modeling.
Stephen S
Date: 18 Dec 2018 07:40:56
Message: <5c18ead8$1@news.povray.org>
It looks perfect for what you have done.
> I would need to make the pictures for it to have meaning, not my best area for
modeling.
Plagiarize, let no one's work evade your eyes
https://maya.nmai.si.edu/calendar/reading-calendar-glyphs
https://maya.nmai.si.edu/sites/all/themes/mayatime/img/glyph-interactive/glyphs/overlay/b5.jpg
Regards
Date: 18 Dec 2018 12:03:04
Message: <5c192848$1@news.povray.org>
>> (epicyclic gears). Then work my way up to something with more parts.
> ...30 tooth inside
> Comments Welcome:
> Stephen S
Margins are missing.
The head of tooth should not touch the foot of the opposite gear.
The part of teeth which get in contact should follow Euler's work, the
remaining part is irrelevant as long as it does not block the movement.
For less noise, consider a slanted rolling profil along depth (missing
the english word for that), and possibly a mirrored construction like
Citroën.
contact between any two gears should be limited to one pair of teeths,
one tooth per gear. (make teeth smaller).
Spur gear NEED a holding axis artefact.
Date: 19 Dec 2018 11:30:22
Message: <5c1a721e@news.povray.org>
>> ...30 tooth inside
>> Comments Welcome:
>> Stephen S
> Citroën.
Slanted in one direction : Helical
Double slant à la Citroën : Chevron
Date: 19 Dec 2018 12:34:47
Message: <5c1a8137$1@news.povray.org>
>> ...30 tooth inside
>> Comments Welcome:
>> Stephen S
> Citroën.
You are right in what you say and the Blacksmith should know. :)
A couple of years ago I was building gear drives in Blender. There is a
lot of theory behind designing the gears. Also the default values on the
page Stephen posted. Gave a result that fitted where they touched. :)
Thinking of the Tri_top Stephen cut and that he has access to a CNC
plasma cutter. I assume the ring gear was a test cut and the gears just
fit together for display.
I think that the sheet metal is too thin to put a slant on it.
But what do I know. I once had a plater pull a hacksaw from my hands. As
he could not stand to watch the way I used it. Yip! I cut on the backstroke.
Regards
Date: 19 Dec 2018 18:39:25
Message: <5c1ad6ad$1@news.povray.org>
On 2018-12-19 12:34 p.m., Stephen wrote:
> ... There is a
...More coal, full steam ahead, blast the "theory". We'll make it fit
with a bigger hammer :-)
Stephen S
Date: 20 Dec 2018 03:43:25
Message: <5c1b562d@news.povray.org>
>> ... There is a lot of theory behind designing the gears.
> ....More coal, full steam ahead, blast the "theory". We'll make it fit
If it works for you. It works for me.
I’m quite envious of your access to any CNC Machine. I reckon that if
you chrome plated your Triceratops. You could sell it for thousands.
I’ll only take 5% for the idea. ;)
Okay you talked me down to 2.5%. Hand crafted by an artisan, must surely
sell. :)
If I had any money I would ask you to build me one.
Regards
Date: 20 Dec 2018 16:45:01
Message: <web.5c1c0c56540b848f48892b50@news.povray.org>
hi,
so agree, it'd be natty.
StephenS:
looking at "gear_pic_.png" (18 Dec 2018 00:40:38), if you'd bend the rails to
half-circles, I can see a bear trap in the making.  :-)
regards, jr.
Date: 24 Dec 2018 10:25:25
Message: <5c20fa65@news.povray.org>
I have about 30 pieces now, half modeled. The gears came out rough and
often catch, more filing needed.
Comments welcome:
Stephen S
Download 'gear_test0000.png' (56 KB) Download 'gear_test0001.png' (55 KB) Download 'gear_test0002.png' (56 KB) Download 'gear_test0003.png' (56 KB) Download 'planetary_test.png' (521 KB)
Preview of image 'gear_test0001.png'
Preview of image 'gear_test0002.png'
Preview of image 'gear_test0003.png'
Preview of image 'planetary_test.png'
Date: 24 Dec 2018 13:55:00
Message: <web.5c212b1b540b848f765e06870@news.povray.org>
> Comments welcome:
Nice!  :)
Have you thought about motor-driving them and lapping them with abrasive to
automate the smoothing?
They also use a grease with particulate copper in it for Glocks and other such
items - perhaps a quick electroplating or just dumping the iron parts into a
copper sulfate solution (bluestone) to do a non-galvanic plating via a surface
redox reaction would give you slightly copper-plated gears which might run more
smoothly...   or not.  ;)
Date: 24 Dec 2018 14:33:19
Message: <5c21347f$1@news.povray.org>
>> Comments welcome:
> Nice!  :)
I was going to say that as a joke.
> Just put some grinding paste on it and run it until it stops squeeling. ;)
Copper sulfate crystals. Ah!
Or you could varnish areas beforehand and have an image as an effect.
Regards
